Style
Style
Unread postby msrahman » Tue Oct 19, 2021 4:50 pm
I am trying to make the line in graphs a little thicker using a script (color line.txt). But I do not see any effects on thickness although the program runs well without any error message.
Any advice.
Sincerely,
Sajjadur Rahman
Combined_One_U.xls
(389.5 KiB) Downloaded 117 times
experiment.rpf
(6.34 KiB) Downloaded 118 times
colorline.txt
(429 Bytes) Downloaded 127 times
msrahman
Re: Style
Unread postby TomDoan » Wed Oct 20, 2021 9:44 am
Your program is using thicklines.txt (which changes the width of B&W lines), not colorline.txt. And your colorline.txt file is designed as a source file, not as a style file and it doesn't put the color codes (the RGB codings of the colors). This is more like what you would want:
grparm(define="LINE_COLOR_01=0,000000,10.0")
grparm(define="LINE_COLOR_02=0,0000ff,10.0")
grparm(define="LINE_COLOR_03=0,00ff00,10.0")
grparm(define="LINE_COLOR_04=0,ff0000,10.0")
grparm(define="LINE_COLOR_05=0,00ffff,10.0")
grparm(define="LINE_COLOR_06=0,ff00ff,10.0")
grparm(define="LINE_COLOR_07=0,ffff00,10.0")
grparm(define="LINE_COLOR_08=0,808080,10.0")
grparm(define="LINE_COLOR_09=0,804000,10.0")
grparm(define="LINE_COLOR_10=0,804000,10.0")
and in the program you want
source colorline.txt
not GRPARM with IMPORT. Note, however, that you will probably find the 10 is way too thick.
Re: Style
Unread postby msrahman » Wed Oct 20, 2021 6:26 pm
Thanks for your help.
On another note, I am trying to insert marker (circles) on several colored impulse responses to show the significance (files attached). I successfully did it in the attached black and white pdf file. I added the following in the text file but it is not working.
grparm(define="SYMBOL_COLOR_01=0,FF0000,1")
Any help?
Sincerely,
Sajjadur.
colorline_exp.txt
(486 Bytes) Downloaded 127 times
experiment_one.rpf
(6.53 KiB) Downloaded 125 times
marker.pdf
(70.56 KiB) Downloaded 115 times
Combined_One_U_Experiment.xls
(391 KiB) Downloaded 114 times
msrahman
Re: Style
Unread postby TomDoan » Wed Oct 20, 2021 10:13 pm
The PDF wasn't done with RATS was it? It doesn't look like a RATS graph.
Re: Style
Unread postby msrahman » Thu Oct 21, 2021 7:11 am
The PDF was done using RATS. I attached the files here.
Any advice how can I place marker on multiple colored lines (files attached before)?
Sincerely,
Sajjadur.
Fig_Groups.xls
(32.5 KiB) Downloaded 118 times
Fig_1_a.xls
(39.5 KiB) Downloaded 115 times
groups_portfolio_combined.rpf
(2.84 KiB) Downloaded 121 times
msrahman
Re: Style
Unread postby TomDoan » Thu Oct 21, 2021 12:18 pm
STYLE=DOTS actually uses the "fill" styles, not the symbol styles (since you have no choice but to use color or grayscale). If you switch your styles on the overlays to 1 and 2 from 5 and 5, the color will do what you want. To get the B&W correct, add
grparm(define="fill_bw_02=0,0.0")
to redefine the style 2 fill to also be full black.
Re: Style
Unread postby msrahman » Thu Oct 21, 2021 4:28 pm
Thanks for your help again. One more thing. Is it possible to add any instruction in SPGRAPH to generate just one set of key instead of three set (as in the attached pdf file)?
Sincerely,
Sajjadur.
Exp_one.pdf
(46.45 KiB) Downloaded 122 times
msrahman
Re: Style
Unread postby TomDoan » Thu Oct 21, 2021 5:17 pm
See "Options for Adding a Key" in the description of SPGRAPH.
Re: Style
Unread postby msrahman » Fri Oct 22, 2021 11:54 am
Thanks again.
I replaced the yellow with teal (008080). The line is showing as teal but marker remains yellow as in the pdf files. Any thought?
source file:
grparm(define="LINE_COLOR_01=0,000000,2.0")
grparm(define="LINE_COLOR_02=0,0000ff,2.0")
grparm(define="LINE_COLOR_03=0,00ff00,2.0")
grparm(define="LINE_COLOR_04=0,ff0000,2.0")
grparm(define="LINE_COLOR_05=0,00ffff,2.0")
grparm(define="LINE_COLOR_06=0,ff00ff,2.0")
grparm(define="LINE_COLOR_07=0,008080,2.0")
grparm(define="LINE_COLOR_08=0,808080,2.0")
grparm(define="LINE_COLOR_09=0,ff8000,2.0")
grparm(define="LINE_COLOR_10=0,800000,2.0")
Experiment.pdf
(45.82 KiB) Downloaded 122 times
experiment_one.rpf
(6.6 KiB) Downloaded 115 times
msrahman
Re: Style
Unread postby TomDoan » Fri Oct 22, 2021 2:59 pm
The dots use the fill color, not the line color.
Return to Graphics, Reports, and Other Output
Users browsing this forum: No registered users and 2 guests
