Help with Labelling-please
Unread postby Ozmando » Thu Dec 23, 2021 3:38 am
Hi, trying to label each of the individual graphs (ifrs) based on a 3 variables VARS/llp. What I please need is to have a heading for each of the computed graphs.
The code is a modified version of the original Jorda (2005) where the results of the VAR have been removed.
The code is below:
Oz
* Replication file for Jorda(2005), "Estimation and Inference of
* Impulse Responses by Local Projections", American Economic
* Review, vol 95, no 1, 161-182.
* New Keynesian Model
open data "is_new.csv"
calendar(q) 1955:1
data(format=prn,nolabels,org=columns) 1955:01 2003:01 ygap infl rate
@nbercycles(down=down)
spgraph(vfields=3,footer="Figure 4 Time Plots of Output Gap, Inflation, Federal Funds Rate")
 graph(key=below,klabel=||"Output Gap"||,shade=down,picture="##.#")
 # ygap
 graph(key=below,klabel=||"Inflation"||,shade=down,picture="##.#")
 # infl
 graph(key=below,klabel=||"Federal Funds Rate"||,shade=down,picture="##.#")
 # rate
@varlagselect(lags=8,crit=sbc)
# ygap infl rate
@varlagselect(lags=8,crit=aic)
# ygap infl rate
compute nlags=4
system(model=basevar)
variables ygap infl rate
lags 1 to nlags
compute varlabels=||"Y-Gap","Inflation","Fed Funds"||
estimate
compute nregeqn=%nreg
* This sets the shocks to be used and the labels for the graph. In
* this case, the shocks are Cholesky shocks, so they are associated
* 1-1 with the variables. To use different shocks, change the way
* <<fshock>> is computed and make the required adjustment to the
* <<shocklabels>>
compute nstep=12
compute fshock=%decomp(%sigma)
compute nshock=%cols(fshock)
compute shocklabels=||"Y-Gap","Inflation","Fed Funds"||
* Do the shocks using the standard VAR methods, saved into baseirf
impulse(steps=nstep+1,factor=fshock,model=basevar,results=baseirf)
dec rect pix(%nvar,%nvar) pixvar(%nvar,%nvar)
dec rect[series] linprjirf(%nvar,nshock)
dec rect[series] linprjstderr(%nvar,nshock)
clear(length=nstep+1) linprjirf linprjstderr
dec rect deltawt(%nregsystem,%nvar)
dec integer k
* The impacts are the ones specified by the choice of the <<fshock>>
* matrix. Because RATS series are based at entry 1, the impacts go
* in entry 1 and the h step responses into h+1.
compute %pt(linprjirf,1,fshock)
do h=1,nstep
   system(model=linvar)
   lags h to h+nlags-1
   * Estimate by SUR with system Newey-West covariance matrix
   sur(model=linvar,robust,lwindow=newey,lags=h-1,noprint)
   * Pull out the leading lag matrix and post-multiply by the
   * desired factor of the covariance matrix.
   compute pix=%modellagmatrix(linvar,h)
   compute %pt(linprjirf,h+1,pix*fshock)
   do i=1,%nvar
      do j=1,%nvar
         ewise deltawt(k,j)=(k==(i-1)*nregeqn+(j-1)*nlags+1)
      compute pixvar=%mqform(%xx,deltawt)
      do j=1,nshock
         compute linprjstderr(i,j)(h+1)=sqrt(%qform(pixvar,%xcol(fshock,j)))
end do h
dec vect[series] lower(nshock) upper(nshock)
*spgraph(hfields=nshock,vfields=%nvar,xlabels=varlabels,ylabels=shocklabels,$
*   footer="Figure 5. Impulse Responses for the New Keynesian Model based on a VAR and Linear Projections")
 do i=1,%nvar
   * Compute the upper and lower bounds for each of the responses
   * for variable i, then find the max and min across all the shocks
   do j=1,nshock
      set lower(j) 1 nstep+1 = linprjirf(i,j)-2.0*linprjstderr(i,j)
      set upper(j) 1 nstep+1 = linprjirf(i,j)+2.0*linprjstderr(i,j)
   table(noprint) 1 nstep+1 lower upper
   do j=1,nshock
      graph(row=i,col=j,number=0,min=%minimum,max=%maximum) 3
      *# baseirf(i,j)
      # linprjirf(i,j) /4
      # lower(j) / 3
      # upper(j) / 3
*spgraph(done)
Ozmando
Re: Help with Labelling-please
Unread postby TomDoan » Thu Dec 23, 2021 11:34 am
If I understand you correctly, you want to replace the graph instruction in the inner loop with
compute header="Response of "+varlabels(1,i)+" to "+shocklabels(1,j)
graph(row=i,col=j,number=0,min=%minimum,max=%maximum,header=header) 3
(or something like that with the compute header=...)
Unread postby Ozmando » Fri Dec 24, 2021 8:48 am
TomDoan wrote:If I understand you correctly, you want to replace the graph instruction in the inner loop with
Thanks for the help.
works perfectly now.
Oz
Ozmando
Return to Graphics, Reports, and Other Output
Users browsing this forum: No registered users and 2 guests
