Graph editting
Graph editting
Unread postby tyzellar » Sat Jun 25, 2022 6:00 am
Dear Tom, Could you please tell me how could I edit the impulse response functions graphs, in order to be able to clearly distinguish between the two IRF functions and the standard errors. Attached to his post you will also find the code and the dataset.
spgraph(vfields=1,hfields=5)
do j=1,1
dofor i=1 2 4 5
compute factor76 = acresp76(j,j)(1)
set respons76 = acresp76(i,j)/factor76
set stde = sqrt(seconda(t,i+(j-1)*nvars))/factor76
set upp = respons76 + band * stde
set low = respons76 - band * stde
graph(header=implabel(i),hlabel="horizon",number=1) 3
# upp 1 nsteps 2
# low 1 nsteps 2
# respons76 1 nsteps 1
print / respons76 upp low
compute j=1
set respons76 = resp76(3,j)/factor76
set stde = sqrt(second(t,3+(j-1)*nvars))/factor76
graph(header=implabel(3),hlabel="horizon",number=1) 3
# upp 1 nsteps 2
# low 1 nsteps 2
tyzellar
Re: Graph editting
Unread postby TomDoan » Sun Jun 26, 2022 9:34 pm
What was it that you wanted to change. The black line with blue upper and lower is pretty standard.
Re: Graph editting
Unread postby tyzellar » Mon Jun 27, 2022 2:36 am
In the last part of the code, I insert in one graph two impulse response functions and I get this graph, which is not so clear. I run this code and I receive the following graph. I would like to have two different colors for the IRFs and one color for the confidence bands. Thank you in advance!
do j=1,1
dofor i=1 2 4 5
compute factor85 = acresp85(j,j)(1)
do n=1,nsteps
compute respons85(n) = acresp85(i,j)(n)/factor85
compute respons76(n) = acresp76(i,j)(n)/factor76
compute stde(n) = sqrt(seconda(n,i+(j-1)*nvars))/factor85
end do n
set upp = respons85 + band * stde
set low = respons85 - band * stde
graph(header=implabel(i),hlabel="horizon",number=1) 4
# upp 1 nsteps 1
# low 1 nsteps 1
# respons85 1 nsteps 1
# respons76 1 nsteps 2
compute j=1
set respons85 = resp85(3,j)/factor85
graph(header=implabel(3),hlabel="horizon",number=1) 4
# upp 1 nsteps 1
# low 1 nsteps 1
tyzellar
Re: Graph editting
Unread postby TomDoan » Mon Jun 27, 2022 8:01 am
You are using 1 (i.e. black) for upp, low and respons85, while 2 (i.e. blue) for respons76. I would think that using respons85 and respons76 should be something different from each other and from upp and low.
# upp 1 nsteps 1
# low 1 nsteps 1
Re: Graph editting
Unread postby tyzellar » Mon Jun 27, 2022 8:40 am
You are totally right. Thank you very much. I really appreciate your help!
tyzellar
Return to Graphics, Reports, and Other Output
Users browsing this forum: No registered users and 2 guests
