Fractional Cointegration- LM test Robinson 1994
Unread postby arvo » Tue Jul 10, 2012 8:32 pm
Dear all,
Does anyone have the procedure code for Robinsons LM test in his 1994 paper " Efficient tests of nonstationary hypotheses"
Thanks very much,
arvo
Re: Fractional Cointegration- LM test Robinson 1994
Unread postby TomDoan » Wed Jul 11, 2012 3:23 pm
This looks like it does the Q=0 test for first differencing.
* Robinson, JASA, December 1994
* Series B (Box-Jenkins IBM stock data)
open data "ibm-stock.txt"
data(format=free,org=var) 1 369 ibmstock
* Make the hypothesized difference of the data (1-L)^1 to create U-tilde
diff ibmstock / dseries
* Compute the variance of U-tilde
stats dseries
compute sigsq=%variance
compute endl=369,startl=2
compute n = endl-startl+1
freq 1 n
rtoc startl endl 1
# dseries
# 1
* Compute the periodogram and the psi function
fft 1
cmult(scale=1.0/(2*%pi*n)) 1 1
set pgram 1 n = %real(%z(t,1))
set psi   1 n = log(2 * abs(sin(-%pi*(t-1)/n)))
* Compute the sums of lambda to make small a-tilde and big A-tilde.
* Avoid the undefined value for psi at t=1 (zero frequency)
sstats 2 n  2.0*psi^2>>bigA
sstats 2 n -2.0*%pi*psi*pgram>>smallA
compute bigA=bigA/n,smallA=smallA/n
* This is closed form value rather than the value approximated off the sum
*compute bigA=%pi^2/6.0
* This is the chi-squared statistic
compute r=n*smalla^2/(bigA*sigsq^2)
* This is the one-tailed equivalent
compute onetail=sqrt(n)*smalla/(sqrt(bigA)*sigsq)
disp "Chi-Squared" r "One-tail" onetail
ibm-stock.txt
Data file
(1.47 KiB) Downloaded 1123 times
Unread postby arvo » Wed Jul 11, 2012 9:03 pm
Thank you very much for the fast reply!
Now I just have to figure out how to include intercept and intercept and trend when computing.
I am assuming this code above is for no regressors? Or have I read it incorrectly.
Once again thank you!
arvo
Unread postby TomDoan » Thu Jul 12, 2012 9:45 am
The regression variant is y(t)=z(t)beta+x(t), phi(L)x(t)=u(t), where phi(L) is typically (1-L)^(1+theta) so you're testing a fractional alternative to first differencing. Under the null, that would mean estimating
(1-L)y=((1-L)z(t))beta+u(t)
If z is 1 and t, you would first difference the data and regress on a constant only, since the 1 drops out when differenced and the t converts to a constant.
Unread postby arvo » Thu Jul 12, 2012 8:33 pm
Once again thank you for the quick reply.
I am looking to present 3 cases - no regressors, constant, constant and trend for different values of the differencing parameter.
With the code you have shown me, I am unsure how to adjust for the other 2 cases.
Your help is much appreciated, thank you.
arvo
Unread postby TomDoan » Fri Jul 13, 2012 2:22 pm
Just detrend the data first, and fractionally difference the results using DIFF with the D option with D=.5 or whatever is your differencing parameter under the null. Fractional differencing can't eliminate a trend, so you have to get it out of the data first.
Unread postby mskare69 » Sat Aug 04, 2012 11:47 am
Could you provide a rats code for replicating the results in TESTING THE ORDER OF INTEGRATION OF THE U.K. UNEMPLOYMENT - Gil Alana or guide me how to do it in rats to replicate the results so I can do it on myself for the data I have.
Fondly,
Marinko
mskare69
Unread postby arvo » Sat Aug 04, 2012 9:28 pm
Marinkos request would also be of significant use.
In addition when I said 3 cases,I meant on u(t), so u(t) would have no constant no trend, constant, constant and trend. Like in the paper Marinko states.
So given a process how would I consider these cases.Sorry if this is just what you have stated , I just obtained odd results before.
Thank you,
arvo
Unread postby TomDoan » Tue Aug 14, 2012 3:25 pm
If you read the paper, in all cases, you simply apply the difference operator under the null to the dependent variable and the regressors, run a regression to get the residuals, and apply the calculation in my original post to the resulting series, with the residuals replacing my "dseries". If d=1, the constant would disappear and the trend would downgrade to a constant. If d<1, the constant would remain as is. I have no idea how Prof. Gil-Alana handles the model with constant and trend with a hypothesized d<1 since a fractional difference applied to a trend (theoretically) generates a non-convergent sum.
Unread postby vtsa » Sat May 30, 2020 12:50 am
Could you provide above mentioned Robinson(1994) LM test with autocorrelated Bloomfield errors (q=1, q=2, q=3, etc)...
I appreciate your responce.
Thank you in advance
vtsa
Return to Looking for Code?
Users browsing this forum: No registered users and 2 guests
