Code for Unrestricted BEKK
Unread postby curiousresearcher » Mon Oct 28, 2019 11:17 am
Please share the code for unrestricted BEKK as used in this research paper - https://www.sciencedirect.com/science/a ... 2318308237
curiousresearcher
Re: Code for Unrestricted BEKK
Unread postby TomDoan » Mon Oct 28, 2019 1:00 pm
That paper is behind a paywall, but what is an "unrestricted" BEKK? A standard BEKK (MV=BEKK on the GARCH instruction) is unrestricted; TBEKK and DBEKK are restricted forms.
You might want to read the article from the April 2019 newsletter:
Spillover/Causality-in-Variance Tests
In BEKK models the "spillover" is sometimes just an artifact of how BEKK handles the covariances.
Unread postby curiousresearcher » Wed Oct 30, 2019 12:11 am
Hello Tom,
When i am using the normal BEKK command as suggested, the results are showing no spillover at all between the cryptocurrencies.
But this paper is showing bi-directional spillover among the
The data i am using matches with that of the paper. So it seems the problem relates to the code used
I am also attaching the data for bitcoin and ether for your reference here used in the paper.
Will appreciate if i can get the code which gets me the result in this paper.
Thanks a lot in advance
* code used is
garch(p=1, q=1,mv=bekk,robusterrors,stdresids=rstd) / BTC ETH
data for estima forum.xlsx
(54.41 KiB) Downloaded 423 times
curiousresearcher
Unread postby TomDoan » Wed Oct 30, 2019 9:59 am
Do you actually have the data that they used, or do you have what you think is the same data (based upon their description)?
Unread postby curiousresearcher » Mon Nov 04, 2019 1:23 am
I have the data they have used as i have matched by descriptive statistics - mean/median/no of obs. etc with their summary stats in the paper.
curiousresearcher
Return to Looking for Code?
