## MAT5. Needed Matrix with Dimensions 47 x 5, Got 210 x 5 I
Unread postby tyzellar » Wed Jun 29, 2022 6:25 am
When I run the code below, I receive the following error message. Could you please tell me what I do wrong? Attached to this post you will find the dataset and the code.
Thank you in advance!
compute optlag=3
system(model=panelmod)
variables gdp cpi ir hp dc
lags 1 to optlag
det gdpdum{1 to optlag} cpidum{1 to optlag} irdum{1 to optlag} $
hpdum{1 to optlag} dcdum{1 to optlag} $
audum bedum cadum chdum dkdum esdum fidum nzdum gedum iedum itdum jpdum sadum nodum swedum ukdum usdum
estimate(print,outsigma=omegares) start end resids(1) coeffs(1)
compute starte=1977:2
compute ende=2017:4
compute nobs=ende-starte+1
dis nobs
compute nreg=nvars*optlag
compute nregt = nreg*2.0+17+nobs
dec rect coefm(fix(nregt),nvars)
dec rect coefmm(fix(nregt),nvars)
ewise coefm(i,j) = %modelgetcoeffs(panelmod)(i,j)
do j=1,nvars
do i=1,fix(nreg)
compute coefmm(i,j) = coefm(i,j)+coefm(nreg+i,j)
do j=1,nvars
do i=fix(nreg+1),fix(nregt)
compute coefmm(i,j) = 0.0
compute %modelsetcoeffs(panelmod,coefmm)
Could you please help me with this issue?
tyzellar
Re: ## MAT5. Needed Matrix with Dimensions 47 x 5, Got 210 x
Unread postby TomDoan » Mon Jul 04, 2022 11:50 am
lags 1 to optlag
compute ende=2017:4
dis nobs
Where are you getting the value for NREGT? I don't see where you get NREG*2 and there isn't anything with a NOBS dimension in the definition for PANELMOD.
Unread postby tyzellar » Mon Jul 04, 2022 2:48 pm
Dear Tom, I found the mistake. Thank you a thousand times for your reply!! I really appreciate it!
tyzellar
Users browsing this forum: No registered users and 3 guests
