Missing values
Missing values
Unread postby vtsa » Thu Oct 28, 2021 1:10 pm
When I run the program attached below, error occurs. I couldn't fix the error. Could you help me to fix the error in the program.
I will appreciate your response,
Kind regards!
prog.RPF
(1.45 KiB) Downloaded 153 times
vtsa
Re: Missing values
Unread postby TomDoan » Thu Oct 28, 2021 2:05 pm
It's hard to tell without the data, but you're using a standard deviation to scale what's basically a square in the threshold, so there could be a serious issue with scale in the exponent. Before you try putting that into a triple loop, you should try estimating the model with just a single reasonable value for C1, C2 and GAMMA. (And note that GAMMA should be on the order of the variance, not the standard deviation).
Return to Structural Breaks and Switching Models
Users browsing this forum: No registered users and 2 guests
