I tried to modify the code to estimate a model with three-regime but get the following error.
* EEV_MCMC.RPF
* Estimation of the model from Ehrmann, Ellison, Valla (2003),
* "Regime-dependent impulse response functions in a Markov-switching
* vector autoregression model", Economics Letters, Vol. 78, pp. 295-299.
* The data set is a reconstruction rather than the author's original
* data set.
* Estimation by Gibbs Sampling
open data 2018_july_turkey_daily_oil_ret_usd.xlsx
calendar(d) 1997:01:03
data(format=xlsx,org=columns) 1997:01:03 2018:06:27
table
set ret = TKNATAL
stats(fractile) EIAEBRT
CMOMENT(print, corr)
# EIAEBRT TURKLI TKVIBON RET
@varlagselect(Lags=10,crit=hq)
@mssysregression(states=3,switch=ch)
# constant EIAEBRT{1 to 1} TURKLI{1 to 1} TKVIBON{1 to 1} RET{1 to 1}
gset pt_t = %zeros(nstates,1)
gset pt_t1 = %zeros(nstates,1)
gset psmooth = %zeros(nstates,1)
compute gstart=1997:01:05, gend=2018:06:27
@MSSysRegInitial gstart gend
compute p=%mspexpand(p)
gset MSRegime gstart gend = %ranbranch(||.5,.5||)
* Prior for transitions. Weak Dirichlet priors with preference for
* staying in a given regime.
dec vect[vect] gprior(nstates)
compute gprior(1)=||8.0,1.0,1.0||
compute gprior(2)=||1.0,8.0,1.0||
compute gprior(3)=||1.0,1.0,8.0||
dec vect tcounts(nstates)
* Hierarchical prior for sigmas
* Uninformative prior on the common component.
* Priors for the relative Wisharts
dec vect nuprior(nstates)
compute nuprior=%fill(nstates,1,6.0)
dec vect[series] vresids(nvar)
dec vect[symm] uu(nstates)
* Flat prior for the regressions.
dec symm hprior
dec vect bprior
compute hprior=%zeros(nvar*nreg,nvar*nreg)
compute bprior=%zeros(nvar*nreg,1)
compute nburn=1000, ndraws=1000
nonlin(parmset=allparms) betasys sigmav p
* For relabeling
dec vect voil(nstates)
dec vect[rect] tempbeta(nstates)
dec vect[symm] tempsigmav(nstates)
dec rect tempp(nstates,nstates)
* Bookkeeping arrays
dec series[vect] bgibbs
gset bgibbs 1 ndraws = %parmspeek(allparms)
set regime1 gstart gend = 0.0
* Bookkeeping information for impulse responses
declare vect[rect] %%responses
dim %%responses(ndraws)
compute steps=15
infobox(action=define,lower=-nburn,upper=ndraws,progress) $
"Gibbs Sampling"
do draw=-nburn,ndraws
* Draw sigma's given beta's and regimes
* Compute the regime-specific residuals
@MSSysRegResids(regime=MSRegime) vresids gstart gend
* Compute the sums of squared residuals for each regime.
ewise uu(i)=%zeros(nvar,nvar)
ewise tcounts(i)=0.0
do time=gstart,gend
compute uu(MSRegime(time))=uu(MSRegime(time))+$
%outerxx(%xt(vresids,time))
compute tcounts(MSRegime(time))=tcounts(MSRegime(time))+1
end do time
compute uucommon=%zeros(nvar,nvar)
do k=1,nstates
compute uucommon=uucommon+nuprior(k)*inv(sigmav(k))
end do k
* Draw the common sigma given the regime-specific ones.
compute sigma=%ranwishartf(%decomp(inv(uucommon)),%sum(nuprior))
* Draw the regime-specific sigmas given the common one.
do k=1,nstates
compute sigmav(k)=%ranwisharti(%decomp(inv(uu(k)+nuprior(k)*sigma)),$
tcounts(k)+nuprior(k))
end do k
* Draw beta's given sigma's and regimes
do i=1,nstates
cmom(smpl=(MSRegime==i),model=MSSysRegModel) gstart gend
compute betasys(i)=%reshape($
%ranmvkroncmom(%cmom,inv(sigmav(i)),hprior,bprior),nreg,nvar)
ewise voil(i)=sigmav(i)(3,3)
compute swaps=%index(voil)
if swaps(1)==2
disp "Draw" draw "Executing swap"
* Relabel the beta's
ewise tempbeta(i)=betasys(i)
ewise betasys(i)=tempbeta(swaps(i))
* Relabel the sigma's
ewise tempsigmav(i)=sigmav(i)
ewise sigmav(i)=tempsigmav(swaps(i))
* Relabel the transitions
compute tempp=p
ewise p(i,j)=tempp(swaps(i),swaps(j))
* Draw the regimes
:skipbeta
@MSSysRegFilter gstart gend
:redrawregimes
@%mssample(start=gstart,end=gend) p pt_t pt_t1 MSRegime
do i=1,nstates
sstats gstart gend MSRegime==i>>tcounts(i)
if %minvalue(tcounts)<5 {
disp "Draw" draw "Redrawing regimes with regime of size" $
%minvalue(tcounts)
goto redrawregimes
* Draw p's
do j=1,nstates
do i=1,nstates
sstats(smpl=(MSRegime{1}==j.and.MSRegime==i)) gstart+1 gend $
1>>tcounts(i)
compute pdraw=%randirichlet(tcounts+gprior(j))
do i=1,nstates
compute p(i,j)=pdraw(i)
infobox(current=draw)
if draw>0 {
* Do the bookkeeping
set regime1 gstart gend = regime1+(MSRegime==1)
compute bgibbs(draw)=%parmspeek(allparms)
* Save IRF's for regime 1. Choleski factor standardized to unit
* shock is used.
@MSSysRegSetModel(regime=1)
compute factor=%decomp(sigmav(1)),factor=factor*inv(%diag(%xdiag(factor)))
impulse(noprint,model=MSSysRegModel,results=impulses1,steps=steps,factor=factor)
* Save IRF's for regime 2
@MSSysRegSetModel(regime=2)
compute factor=%decomp(sigmav(2)),factor=factor*inv(%diag(%xdiag(factor)))
impulse(noprint,model=MSSysRegModel,results=impulses2,steps=steps,factor=factor)
@MSSysRegSetModel(regime=3)
compute factor=%decomp(sigmav(3)),factor=factor*inv(%diag(%xdiag(factor)))
impulse(noprint,model=MSSysRegModel,results=impulses3,steps=steps,factor=factor)
* This will interleave the shocks from the two regimes.
dim %%responses(draw)(%rows(impulses1)*%cols(impulses1)*2,steps)
ewise %%responses(draw)(i,j)=ix=%vec(%xt(impulses1,j)~~%xt(impulses2,j)~~%xt(impulses3,j)),ix(i)
end do draw
infobox(action=remove)
@mcmcpostproc(ndraws=ndraws,mean=bmeans,stderrs=bstderrs) bgibbs
report(action=define)
report(atrow=1,atcol=1,fillby=cols) %parmslabels(allparms)
report(atrow=1,atcol=2,fillby=cols) bmeans
report(atrow=1,atcol=3,fillby=cols) bstderrs
report(action=show)
set regime1 gstart gend = regime1/ndraws
graph(header="MCMC Probability of Regime 1")
# regime1
set regime2 gstart gend = regime2/ndraws
graph(header="MCMC Probability of Regime 2")
# regime2
set regime3 gstart gend = regime3/ndraws
# regime3
@MCProcessIRF(model=MSSysRegModel,lower=lower,upper=upper,irf=irf,percentile=||.10,.90||)
table
set irf4_1 = IRF(4,1)
set lower4_1 = LOWER(4,1)
set upper4_1 = UPPER(4,1)
set irf4_2 = IRF(4,2)
set lower4_2 = LOWER(4,2)
set upper4_2 = UPPER(4,2)
set irf4_3 = IRF(4,3)
set lower4_3 = LOWER(4,3)
set upper4_3 = UPPER(4,3)
set irf4_4 = IRF(4,4)
set lower4_4 = LOWER(4,4)
set upper4_4 = UPPER(4,4)
* *******************************************EIAEBRT TURKLI TKVIBON TKNAT30
spgraph(hfields=4,vfields=1)
graph(nodate, header ="Responses of ret to Oil Shocks: Regime 1") 3
# irf4_1 * 15
# lower4_1 * 15 2
# upper4_1 * 15 2
graph(nodate,header ="Responses of ret to oil Shocks: Regime 2") 3
# irf4_2 * 15
# lower4_2 * 15 2
# upper4_2 * 15 2
graph(nodate,header ="Responses of ret to oil Shocks: Regime 3") 3
# irf4_3 * 15
# lower4_3 * 15 2
# upper4_3 * 15 2
# irf4_4 * 15
# lower4_4 * 15 2
# upper4_4 * 15 2
