Page 2 of 2
Re: Hafner Herwartz 2006
Posted: Wed Dec 19, 2018 10:57 am
Jules89 wrote:Dear Tom,
I have two questions regarding MCMC estimation of the BEKK model:
1)
I went through the MCMC code for the DCC-GARCH. Wouldn't it be possible to estimate a BEKK model with the similar procedure? I start with the ML estimates, then I generate candidate draws with the t-distribution and evaluate it using:
compute btest=blast+%ranmvt(fxx,nuxx)
garch(p=1,q=1,mv=bekk,initial=btest,method=eval,$
rvectors=rv,hmatrices=htest) / xjpn xfra xsui
compute logptest=%logl
The rest should be the same.
Correct. You might need to experiment with the scale on FXX and the degrees of freedom, but the process is the same.
Jules89 wrote:
2)
Above would be Random Walk MH, why do you think that independence MH is better suited?
If an independence chain works, it's generally superior to random walk---if the asymptotic distribution is fairly accurate (which is likely if you have enough data), independent draws use that while the RW draws ignore it.
Posted: Wed Jan 09, 2019 7:23 am
by Jules89
i have another question regarding the implementation of independence chain MH for the MV GARCH. I wanted to use codeparts of the ARMAGIBBS.RPF, as it is also doing IC-MH.
Given that the draws are done with
compute btest=blast+%ranmvt(fxx,nuxx) (adjusted for the example above)
it looks to me like a RW-MH draw. The only difference is that the acceptance probability is calculated as
compute alpha=%if(%valid(logptest),exp(logptest-logplast-logqtest+logqlast),0.0)
instead of
compute alpha=%if(%valid(logptest),exp(logptest-logplast),0.0)
Shouldn't for IC-MH the draw be somethin like
compute btest=%ranmvt(fxx,nuxx) (adjusted for the example above)
thank you
Best
Julius
Posted: Wed Jan 09, 2019 11:23 am
You're missing the mean in the IC proposal density (generally the point estimates from maximum likelihood).
Posted: Wed Jan 09, 2019 1:47 pm
by Jules89
You are right... I totally oversaw that for the draw the "blast" is fixed at the ml estimates.... The "blast " shifts the draw from %ranmvt towards a mean which corresponds to the ml estimates. Otherwise it would be always a zero mean draw, right?
Best
Jules
Posted: Wed Jan 09, 2019 1:55 pm
Jules89 wrote:You are right... I totally oversaw that for the draw the "blast" is fixed at the ml estimates.... The "blast " shifts the draw from %ranmvt towards a mean which corresponds to the ml estimates. Otherwise it would be always a zero mean draw, right?
Best
Jules
Correct.
Posted: Wed May 27, 2020 3:52 pm
by ege_man
I have an idea to investigate the impact of COVID-19 on the variables such as exchange rates, stock returns and interest rates available at five-working day frequency. Does it make sense to use VIRFs for this research? Do you have any suggestion?
Best
Posted: Wed May 27, 2020 6:01 pm
I don't see how that would work. Wouldn't covid have to be exogenous to the other variables? The VIRF's are for a set of variables that are jointly modeled using a GARCH model.
Posted: Wed May 27, 2020 7:41 pm
by ege_man
I know it is exogenous but can we treat covid similar to financial crisis which is also exogenous if we do not explicitly introduce any proxy variable?
Posted: Thu May 28, 2020 7:58 am
If you're talking about using it to date the time of a shock, you could, except there is not going to be a single obvious shock date.
Posted: Sun May 31, 2020 3:15 pm
by ege_man
Yes you are right. I would like to compute set of responses for important dates, i.e. first case, highest number of cases. Does it make sense?
Regards
Posted: Mon Jun 01, 2020 8:47 am
I'm not sure what question you think that's answering. The VIRF is to give an example of the out-of-sample behavior of the variance model in question (a BEKK in the case of HH). HH choose the particular incidents because they are locations where the variances are actually "shocked"---that is, the residuals are larger than the BEKK model predicts. They're not saying "this is what happens if xxx".
Posted: Fri Nov 13, 2020 3:21 am
by apogio
I'm estimating a M BEKK-GARCH-X model including 2 shift dummies for stock indices series. Can I use HH to calculate the VIRFs for 2 shocks in time?
garch(model=basevecm,mv=bekk, stdresids=stdu,factorby=eigen, hmatrices=hh,rvectors=rr, $
pmethod=simplex,piters=10,method=bfgs,iters=2000,vechmat=vechcomps,robust,distrib=t,xreg)
# dto381 dto631
Posted: Sat Mar 01, 2025 4:36 am
Yes. The variance shift dummies have no effect on the calculations of the VIRF's.
