Page 2 of 2
Re: independent Normal-Wishart prior
Posted: Wed Jul 24, 2013 1:59 pm
The vast majority of empirical work done with VAR's uses flat priors on the coefficients and Jeffrey's prior for the covariance matrix.
Posted: Wed Jul 31, 2013 6:22 pm
by AhmedSahlool
I hope this finds you well,
When I run the procedure @FEVDTABLE I got the following message:
"## M4. A memory request for an additional 32768 bytes cannot be satisfied"
Is that a problem of my PC, I run it for only one variable and for only two periods;
@MCFEVDTable(model=SNVAR_EG1,INCLUDE=||3||,horizons=||1,10||)
another question, What is the main gain of estimating a full VAR model using the SURGibbsSetup procedure? Is this related to the prior type or the structure of the Variance Covariance matrix?
Last question: I try to estimate the same model with Minnesota prior using the SURGibbsSetup procedure, I don't know if there is a code for this, I tried using the procedures @BVARBuildPriorMN and @BVARFinishPrior, but I don't know how to manage these procedures with SURGibbsSetup, but I'm not sure of what I'm doing.
Last thing: I can't find the procedure @BVARFinishPrior in the material sent.
Thank you in advance
Posted: Mon Aug 05, 2013 8:04 am
by AhmedSahlool
I'm really sorry to nag, but do you have some guidance for my questions.
Thank you
Posted: Fri Aug 09, 2013 10:17 am
by AhmedSahlool
I tried running the procedure @FEVDTABLE on more powerful PCs, but I continue getting the following message:
Would you kindly guide me.
