Re: Obtain residuals and IRF
Posted: Mon Dec 02, 2013 6:59 am
Hello! I would like, once more, to ask for your advice regarding residuals and impulse responses.
Regarding residuals, I would like to thank you, for your help and your suggestions on the autocorrelation test. However, I would like to ask you, since the residuals of a switching model cannot be checked for autocorrelation, heteroskedasticity and normality, then shall we stop writing in the papers that we assume that the residuals are normally distributed without autocorrelation and heterskedasticity. After, a quick check in the literature, I observed that authors declare with their MSVEC model that the residuals are Gaussian. What is your suggestion on this?
Regarding impulse responses, since I am estimating a Markov Switching VEC model with asymmetries, I am trying to estimate non-linear impulse responses using the command FORECAST. I have studied your discussion with nazif on the non-linear IRFs of Balke and Fomby code as well as your discussion with cu_student on an asymmetric error correction model. However, I need your help. I am attaching you the code that I am working on, so as to ask for your suggestion on whether I am on the right path or not. I have used your proposition about definitional identities but I am not sure how to proceed with the rest of the code as is proposed to Balke and Fomby file. The error message I get is: “## SX22. Expected Type EQUATION, Got VECTOR[SERIES[REAL]] Instead. The Error Occurred At Location 186, Line 6 of loop/block”.
Moreover, I would like to ask you, do you think that, I should avoid using the PATH option (or any other) for creating a shock to my model since the asymmetries are already modelled.
Once more, I have a huge inquiry for you. I hope that I will not take much of your time.
I am looking forward to your suggestions. Your help is always valuable to us.
Best Regards.
Best Regards.
