compute nvar = 3
compute nlags = 1
compute nsteps = 100
compute ndraws = 500
system(model=threevar)
var d2lrgdp dprivs dgovs
lags 1 to nlags
det
estimate(noprint,resids=resids)
compute vsigma=%sigma
@Varlagselect(lags=8,crit=aic)
# d2lrgdp dprivs dgovs
@Varlagselect(lags=8,crit=hq)
@Varlagselect(lags=8,crit=sbc)
dec rect lr(3,3) sr(3,3)
input lr
. 0 0
input sr
. 0 .
dec vect[strings] shocklabels varlabels
compute shocklabels=||"Output","Private Savings","Public Savings"||
compute varlabels=||"Real GDP","Private Savings Rate","Public Savings Rate"||
@ShortAndLong(lr=lr,sr=sr,masum=inv(%varlagsums)) %sigma f
compute fd=%xdiag(f)
ewise f(i,j)=f(i,j)/fd(j)
****Point Estimate*****
@varirf(model=threevar,steps=nsteps,factor=f,page=byshock,accum=||1,2,3||,$
shocks=shocklabels,varlabels=varlabels)
****Monte Carlo Simulation****
procedure SRLRDoDraws
option model model threevar
option integer draws 500
option integer steps 100
option vect[int] accum ||1,2,3||
option rect lr
option rect sr
local integer nvar
local rect fxx fwish fsigmad factor
local integer wishdof
local rect betaols betau betadraw
local vect ix
local symm sigmad
local integer i j draw
if .not.%defined(model) {
disp "###SRLRDoDraws(MODEL=model name,other options)"
return
compute nvar=%modelsize(model)
* Standard setup for drawing from an OLS VAR
compute fxx =%decomp(%xx)
compute fwish =%decomp(inv(%nobs*%sigma))
compute wishdof=%nobs-%nreg
compute betaols=%modelgetcoeffs(model)
local rect[series] impulses(nvar,nvar)
* These are global variables
declare vect[rect] %%responses(draws)
infobox(action=define,progress,lower=1,upper=draws) "Monte Carlo Integration"
do draw=1,draws
if %clock(draw,2)==1 {
compute sigmad =%ranwisharti(fwish,wishdof)
compute fsigmad =%decomp(sigmad)
compute betau =%ranmvkron(fsigmad,fxx)
else
compute %modelsetcoeffs(model,betadraw)
* Compute the short-and-long-run factor using the recalculated lag
* sums of the model.
@ShortAndLong(lr=lr,sr=sr,masum=inv(%modellagsums(model))) sigmad factor
impulse(noprint,model=model,factor=factor,results=impulses,steps=steps)
* Accumulate the responses as requested
do i=1,%rows(accum)
do j=1,nvar
acc impulses(accum(i),j) 1 steps
* Store the impulse responses
dim %%responses(draw)(nvar*nvar,steps)
infobox(current=draw)
end do draw
infobox(action=remove)
* Restore the original coefficients
compute %modelsetcoeffs(model,betaols)
end SRLRDoDraws
@SRLRDoDraws(accum=||1,2,3||,steps=nsteps,model=threevar,lr=lr,sr=sr)
*@MCGraphIRF(model=threevar,shocklabels=shocklabels,varlabels=varlabels,page=byshock)
@MCProcessIRF(model=threevar,percentiles=||.16,.84||,center=median,lower=lower,upper=upper,irf=irf)
copy(format=xls,org=columns) / irf lower upper
