Page 2 of 3
Re: Question about replication of Filardo(1994)
Posted: Wed Aug 03, 2016 5:31 pm
by fan
TomDoan wrote:Multiplying the log by the inflation factor is *really* not the right thing to do. The first part of that is actually computing v^(-.5) (using exp(-.5*log(v)) so you either divide the whole factor by sqrt(1+alfa*dummy) or add log(1+alfa*dummy) to the v before it gets multiplied by the -.5.
Thank you for the advice. is now correct?
compute %MSVARFVec(i)=exp(-.5*MSVARLogDetV(state)/sqrt(1+alfa*dummy(t))-.5*%qform(MSVARSigmaInv(state)/(1+alfa*dummy(t)),u)
Posted: Wed Aug 03, 2016 7:04 pm
No. You're dividing in the first term inside the exp, not outside.
Posted: Thu Aug 04, 2016 9:30 am
by fan
TomDoan wrote:No. You're dividing in the first term inside the exp, not outside.
Thank you for pointing out the mistake.
compute %MSVARFVec(i)=exp(-.5*(MSVARLogDetV(state)+Log(1+alfa*dummy(t)))-.5*%qform(MSVARSigmaInv(state)/(1+alfa*dummy(t)),u)
Posted: Thu Aug 04, 2016 11:34 am
At some point you lost the integrating constant (iconst) so your log likelihood won't be comparable with the regular calculation. That has no effect on the estimation, but you probably want to put it back in.
Posted: Sat Aug 06, 2016 2:41 am
by fan
[quote="TomDoan"]At some point you lost the integrating constant (iconst) so your log likelihood won't be comparable with the regular calculation. That has no effect on the estimation, but you probably want to put it back in.[/quot]
Thank you for the advice. If it is possible, could you please kindly check my full code?
cal(m) 1948
open data filardo.dat
set g = ipgr
* Transform the information variables
set cligr   = 100.0*log(cli/cli{1})
set spgr    = 100.0*log(sp/sp{1})
set xlidiff = xli-xli{1}
set ffdiff  = fed-fed{1}
* And center them to zero means
   diff(center) s
end dofor s
* Common setup
compute nlags=4
source msvarsetup.src
@MSVARSetup(lags=nlags)
# g
nonlin(parmset=common) mu phi sigma alfa
@MSVARinitial gstart gend
* Time varying probabilities
dec equation p1eq p2eq
dec vector   v1   v2
nonlin(parmset=tv) v1 v2
* This overrides the standard fixed definition
function  %MSVARPmat  time
type rect %MSVARPmat
type int  time
local integer i j
local rect    pexpand
local real    z
if nexpand==nstates {
   compute %MSVARPmat=pexpand*p
else {
* Initialize the probabilities using only the intercepts
function TVPInit
type vector TVPInit
local rect a
local integer i j
compute TVPInit=%MSVARInit()
set dummy = t<=1959:12
dec real alfa
* Override the %MSVARFVec function. This returns the expanded set of
* likelihood functions across all state combinations.
function %MSVARFVec time
type vector  %MSVARFVec
type integer time
local integer i j state
local vect    u
local real    iconst
dim %MSVARFVec(nexpand)
compute iconst=(2*%pi)^(-.5*nvar)
do i=1,nexpand
   compute state=MSVARLagState(i,1)
   compute u=%xt(y,time)-mu(state)(1)
   do j=1,nlags
      compute statej=MSVARLagState(i,j+1),$
        u=(u-phi(j)*(%xt(y,time-j)-mu(statej)(1))
   compute %MSVARFVec(i)=iconst*exp(-.5*(MSVARLogDetV(state)+Log(1+alfa*dummy(t)))-.5*%qform(MSVARSigmaInv(state)/(1+alfa*dummy(t)),u)
frml msvarf = %MSVARPMat(t),log(%MSVarProb(t))
* Define the logistic index for the transitions
equation p1eq *
# constant cligr{1}
equation p2eq *
# constant cligr{1}
* Standard guess values aiming to make state 1 the low growth state.
compute v1=log(.7/.3)~~0.0
compute v2=log(.95/.05)~~0.0
compute mu(1)=-1.7,mu(2)=.3
 method=bhhh,iters=20) logltvtp gstart gend
Posted: Mon Aug 08, 2016 11:22 am
That looks fine. You can do an obvious check by pegging alfa to zero and seeing whether you get the same results as you do for the model without the heteroscedasticity correction.
Posted: Mon Aug 08, 2016 12:36 pm
by fan
TomDoan wrote:That looks fine. You can do an obvious check by pegging alfa to zero and seeing whether you get the same results as you do for the model without the heteroscedasticity correction.
Thank you so much for your help.
Posted: Wed Aug 17, 2016 6:43 pm
by fan
Dear Tom, sorry for posting question again. After applying the code to my own exercise, I got an error message says: ## MAT13. Store into Out-of-Range Matrix or Series Element
The Error Occurred At Location 292, Line 18 of %MSVARFVEC
Called From Location 26, Line 11 of %MSVARPROB
I am not sure how I can fix the error. Could you please kindly help me? Following is my exercise code.
CALENDAR(Q) 1875:1
DATA(FORMAT=XLSX,ORG=COLUMNS) 1875:01 2010:04 quarter recession rgdp rep yr34
set demo = 1-rep
set yr12 = 1-yr34
set grgdp = 100.0*log(rgdp/rgdp{1})
graph(footer="Figure 1. Log Growth Rate of Quarter Real GDP")
# grgdp
states(smpl=yr34) grgdp
@nbercycles(up=ups,down=downs)
states(smpl=rep) ups 1950:01 *
set g = grgdp
sstats(mean,smpl=ups{1}) 1950:01 * ups>>pups
display pups
sstats(mean,smpl=downs{1}) 1950:01 * downs>>pdowns
display pdowns
stats(smpl=downs) g  /
* Common setup
compute nlags=4
compute gstart=1876:02,gend=2010:04
@MSVARSetup(lags=nlags,switch=m)
# g
dec vector   v1   v2
type int  time
local integer i j
local rect    pexpand
local real    z
else {
function TVPInit
type vector TVPInit
local rect a
local integer i j
set dummy = t<=1949:04
dec real alfa
type integer time
local vect    u
local real    iconst
do i=1,nexpand
   do j=1,nlags
      u=u-phi(j)*(%xt(y,time-j)-mu(statej)(1))
   compute %MSVARFVec(i)=iconst*exp(-.5*(MSVARLogDetV(state)+Log(1+alfa*dummy(t)))-.5*%qform(MSVARSigmaInv(state)/(1+alfa*dummy(t)),u))
equation p1eq *
# yr34 yr12
equation p2eq *
# yr34 yr12
sstats(mean,smpl=yr12.and.downs{1}) /  downs>>pdowns
display pdowns
sstats(mean,smpl=yr12.and.ups{1}) / ups>>pups
display pups
compute v1=log(.8/.2)~~log(.85/.15)
compute v2=log(.94/.06)~~log(.9/.1)
compute mu(1)=-0.8,mu(2)=1.5
 method=bhhh,iters=400,pmethod=simplex,piters=20) msvarf gstart gend
* Do graph of NBER recessions vs the probability of slow growth state
@NBERCycles(down=recession)
@MSVARsmoothed gstart gend psmooth
set pdown gstart gend = psmooth(t)(1)
graph(shade=recession)
# pdown
Posted: Wed Aug 17, 2016 6:59 pm
You never dimension %MSVARFVEC inside the function.
Posted: Wed Aug 17, 2016 9:44 pm
by fan
TomDoan wrote:You never dimension %MSVARFVEC inside the function.
Thank you so much for pointing out the missing instruction for me. The code now works but the estimates on transition indices (V1(1), V2(1)) are surprisingly large. I guess this may be due to the initial values used for the estimation. I tried several initial values but none can fix the problem. Could you please kind take a look at my data (attached) and let me know how you will pick up the initial values? My data cover the period from 1875:Q1 to 2010:Q4, and based on the recessions and expansions defined by NBER, the average growth rate for recession period is -0.82 and is 2.1 for expansion,before WW2, up to 1949:Q4. while, the average growth rate for recession period is -0.54 and is 1.0 for expansion for the after-war period. It seems the gap between expansion and recession is getting smaller in the later period. Is it necessary to account this change into the estimation? Thank you in advance
MAXIMIZE - Estimation by BHHH
Convergence in 18 Iterations. Final criterion was 0.0000064 <= 0.0000100
Quarterly Data From 1876:02 To 2010:04
Usable Observations 53
Function Value -1518.0084
1. V1(1) -442.4565934 0.0000000 0.00000 0.00000000
2. V1(2) -0.9840729 1.2178426 -0.80805 0.41906408
3. V2(1) 31.5697815 0.0000000 0.00000 0.00000000
4. V2(2) 3.6862505 0.5051533 7.29729 0.00000000
5. MU(1)(1) -6.4422171 0.9493275 -6.78609 0.00000000
6. MU(2)(1) 0.8341408 0.0858809 9.71277 0.00000000
7. PHI(1)(1,1) 0.4303842 0.0402075 10.70407 0.00000000
8. PHI(2)(1,1) 0.0430398 0.0431374 0.99774 0.31840560
9. PHI(3)(1,1) 0.0283109 0.0424446 0.66701 0.50476710
10. PHI(4)(1,1) -0.1287053 0.0386235 -3.33230 0.00086130
11. SIGMA(1,1) 0.7865617 0.0565250 13.91529 0.00000000
12. ALFA 6.3003351 0.8173465 7.70828 0.00000000
OPEN DATA "C:\Users\Sam\Desktop\historyofrealgdp.xlsx"
CALENDAR(Q) 1875:1
set demo = 1-rep
set yr12 = 1-yr34
# grgdp
states(smpl=recession) grgdp 1950:01 *
states(smpl=.not.recession) grgdp 1950:01 *
set g = grgdp
display pups
display pdowns
* Common setup
compute nlags=4
# g
nonlin(parmset=common) mu phi sigma alfa mustar
dec vector   v1   v2
type int  time
local integer i j
local rect    pexpand
local real    z
else {
function TVPInit
type vector TVPInit
local rect a
local integer i j
dec real alfa
dec vect mustar(2)
type integer time
local vect    u
local real    iconst
do i=1,nexpand
   compute u=%xt(y,time)-mu(state)(1)-mustar(state)*dummy(t)
   do j=1,nlags
      u=u-phi(j)*(%xt(y,time-j)-mu(statej)(1)-mustar(statej)*dummy(time-j))
equation p1eq *
# yr34 yr12
equation p2eq *
# yr34 yr12
display pdowns
display pups
compute mu(1)=-0.8, mustar(1)=0.0
compute mu(2)=1.5,  mustar(2)=0.0
 method=bhhh,iters=100,pmethod=simplex,piters=5) msvarf gstart gend
# pdown
Posted: Thu Aug 18, 2016 9:42 am
There are all kinds of problems with what you posted. First, you have MUSTAR added to the parameter set before you've even declared it as a VECTOR. ALFA isn't given a guess value. But the main problem is that you are using (T) rather than (TIME) several times in your %MSVARFVEC function.
Posted: Thu Aug 18, 2016 11:01 am
by fan
TomDoan wrote:There are all kinds of problems with what you posted. First, you have MUSTAR added to the parameter set before you've even declared it as a VECTOR. ALFA isn't given a guess value. But the main problem is that you are using (T) rather than (TIME) several times in your %MSVARFVEC function.
Thank you for your quick reply. I forgot to delete the MUSTAR I used in a different code to catch the narrowing gap between expansion and recession after WW2. Following your suggestion, I changed (T) to (TIME) in %MSVARFVEC function and gave a guess value (3.0) to ALFA. Unfortunately, the results are still strange. I have quarterly data from more than 100 years (1857:Q1 to 2010:Q4), and there are much more ups and downs in the early part of the sample period. I think that makes more difficult to describe the data through how to pick up the guess values and number of lags in autocorrelation part as the economy may behave very differently in first 50 years and remaining years. Could you please kindly let me know how you will solve the problems if you were having such data set? Many Thanks
Convergence in 25 Iterations. Final criterion was 0.0000093 <= 0.0000100
Usable Observations 539
Function Value -1520.2568
1. V1(1) 33.8150932 0.0000000 0.00000 0.00000000
2. V1(2) -1.2714243 1.3339100 -0.95316 0.34051105
3. V2(1) 366.8376554 0.0000000 0.00000 0.00000000
4. V2(2) 3.7540092 0.5310757 7.06869 0.00000000
5. MU(1)(1) -5.8227267 0.9338392 -6.23526 0.00000000
6. MU(2)(1) 0.8397575 0.0916063 9.16703 0.00000000
7. PHI(1)(1,1) 0.4440826 0.0406352 10.92851 0.00000000
8. PHI(2)(1,1) 0.0388758 0.0420744 0.92398 0.35549875
9. PHI(3)(1,1) 0.0538168 0.0414564 1.29815 0.19423484
10. PHI(4)(1,1) -0.1270546 0.0387383 -3.27982 0.00103873
11. SIGMA(1,1) 0.7891571 0.0570101 13.84242 0.00000000
12. ALFA 6.4359691 0.8385414 7.67520 0.00000000
Posted: Thu Aug 18, 2016 1:15 pm
First of all, you probably do want the MUSTAR's in there, as the ups and downs are clearly higher in the early part of the data set. (Simply correcting for heteroscedasticity won't change the fact that your model switches the mean and the means are different as well).
This model tends to pick up a relatively few really extreme down periods. If those all turn out to be in "year12" periods, then the transition probability to the low regime in the "year34" can be zero. To create zero (or one) in a logistic requires "infinity" index values. Even if there are some data points that are borderline regime 1 that aren't in "year12", the likelihood might be improved overall by effectively ignoring those: confusion as to the regime can hurt the likelihood, so it may be better for the likelihood to be certain and be "wrong".
Posted: Wed Aug 24, 2016 3:30 pm
by fan
TomDoan wrote:First of all, you probably do want the MUSTAR's in there, as the ups and downs are clearly higher in the early part of the data set. (Simply correcting for heteroscedasticity won't change the fact that your model switches the mean and the means are different as well).
Thank you for the detailed reply. can I ask one more question? In most cases, the variables used in the probability transition equation are exogenous. I am wondering whether endogenous variables can be used in the transition equation. In most political economic studies, authors seem to ignore the endogeneity between politics and economics. I would like to incorporate this endogeneity into my study. For example, in UK, government can call election based on recent past economic condition; and the recent past economic condition can influence the outcome of the election. In other words, the political variables used in the transition equation can be determined by the probability of the economic status in the recent past. Could you please kindly share your suggestion on how I can modify the codes to incorporate the endogeneity into my estimation? Many Thanks in advance
Posted: Wed Aug 24, 2016 4:43 pm
I don't think there's an issue with "endogeneity" of the transition variables as long as they're predetermined (i.e. lagged). In the Filardo article, for instance, it's probably safe to say that none of the variables used for the indicators are strictly exogenous in a statistical sense. Where you might run into a problem is where the indicator variable is also in the model or a close relative of it is in the model. The "switch" could then possibly end up simply proxying for some other form of non-linearity in the model.
