Page 2 of 2
Re: Reading several data arrays and performing Monte Carlo S
Posted: Tue May 28, 2019 1:35 pm
All instructions are described in the Help:
https://estima.com/ratshelp/sourceinstruction.html
The use of SOURCE for pulling in procedures is covered in the Introduction.
Posted: Wed May 29, 2019 11:25 am
by pedrocm
Thanks Tom.
It did work after sourcing the procedure.
I am not sure why, but when evaluating a different dataset, I am having the following problem after setting the @MSSysRegression(states=2,switch=ch):
The Error Occurred At Location 62, Line 9 of MSSYSREGINITIAL
C:\Users\Public\Documents\Estima\WinRATS Std 9.0\mssysregression.src Line 209
It happens only when I have the data imported in the loop. Any guess what is causing it?
Thanks in advance.
Posted: Wed May 29, 2019 5:07 pm
Aren't you changing the number of lags from sample to sample? This is setting the range based upon whatever was just done (which when i=2 is the estimation at the end of i=1). You probably need to move the non-switching VECM estimation inside the loop so it will adapt to the change in lags.
do i=1,4
Posted: Thu May 30, 2019 11:48 am
by pedrocm
Hi Tom.
Thanks for the advice. Indeed, I suspected that was the problem. I tried that yesterday and it did work. Just wanted make sure I was doing the right thing.
Thanks a lot.
