Page 2 of 3
Re: The diagnostics tests for multivariate GARCH
Posted: Tue Nov 28, 2023 7:53 am
Switch to METHOD=BFGS. (That's generally superior to BHHH---the original paper uses BHHH, but it may be a better-behaved data set).
You have only 3254 data points, not 3255. (There are 3255 rows, but one row is the labels).
Posted: Tue Nov 28, 2023 8:11 am
by jack
I did those steps, but it didn’t converge. Here is result:
MAXIMIZE - Estimation by BFGS
NO CONVERGENCE IN 47 ITERATIONS. FINAL NORMED GRADIENT    0.20463
TRY DIFFERENT SETTING FOR EXACTLINE, DERIVES OR ALPHA ON NLPAR
RESTARTING ESTIMATION FROM LAST ESTIMATES OR DIFFERENT INITIAL GUESSES/PMETHOD OPTION MIGHT ALSO WORK
Usable Observations                      3251
Function Value                     -3400.1645
1.  B0                            0.392044744  0.015311012     25.60541  0.00000000
2.  B1                            0.033797151  0.020644514      1.63710  0.10160940
3.  B2                           -0.078834171  0.017698086     -4.45439  0.00000841
4.  B3                            0.064691553  0.016176078      3.99921  0.00006355
5.  B4                            0.061559302  0.018073991      3.40596  0.00065932
6.  B5                            0.067709720  0.013656368      4.95811  0.00000071
7.  W1                            3.855376045  0.020445646    188.56709  0.00000000
8.  W2                            3.770226524  0.011883274    317.27171  0.00000000
9.  W3                            3.754657948  0.010795293    347.80511  0.00000000
10. W4                            3.764295221  0.012284852    306.41764  0.00000000
11. W5                            3.754595802  0.011469702    327.34903  0.00000000
12. W6                           -0.003595986  0.011690666     -0.30759  0.75839082
13. W7                            0.003676594  0.011898396      0.30900  0.75732219
14. ALPHA1                        0.163425026  0.014391228     11.35588  0.00000000
15. BETA1                         0.834769915  0.014709968     56.74859  0.00000000
16. RNU                           0.180742894  0.011195424     16.14435  0.00000000
Posted: Wed Nov 29, 2023 1:42 am
by jack
I've even made other changes randomly to the program, but it still doesn't converge.
Posted: Wed Nov 29, 2023 10:27 am
With your data, the GARCH model is borderline I-GARCH (the GARCH coefficients sum to .998). When those sum to 1, the level of the W's becomes unidentified (you can add a constant to each of the W1 to W5 and get the same fit) so that's interfering with convergence.
I've attached a recoding of the original paper which handles the W's differently (an overall level W0 then W1 to W5 which sum to zero). There will still be a potential issue with W0 not being fully identified, but the day-of-week shifts will be, which is what you really need.
bbjbes.rpf
(8.73 KiB) Downloaded 1115 times
Posted: Thu Nov 30, 2023 3:34 am
by jack
I really appreciate your kind help and guide.
I edited it for one variable and run it. It still does not converge for my data:
* Replication file for Baillie and Bollerslev, "The Message in Daily
* Exchange Rates: A Conditional Variance Tale", JBES 1989, vol 7, pp
* 297-305
open data tom1.xlsx
data(format=xlsx,org=columns) 1 3254 sto dow
labels sto
# "Stock"
log sto
* Unit root tests
* Table 1
source ppunit.src
report(action=define)
dofor s = sto
   report(col=new,atrow=1) %l(s)
   @ppunit(lags=22,det=trend) s
   report(col=current,atrow=2) %cdstat
   @ppunit(lags=22) s
   report(col=current,atrow=3) %cdstat
end dofor
report(action=format,picture="*.###")
report(action=show)
* Table 2 estimates
dofor s = sto
   set dx = 100.0*(s{0}-s{1})
   linreg(noprint) dx
   # constant dx{1}
   report(col=curr,atrow=2) %beta(1)
   report(col=curr,atrow=3,special=parens) %stderrs(1)
   report(col=curr,atrow=4) %sigmasq
   report(col=curr,atrow=5) %logl
   set ustd = %resids/sqrt(%seesq)
   corr(print,qstats,number=15,method=yule) ustd
   report(col=curr,atrow=6) %qstat
   set usqr = ustd^2
   corr(print,qstats,number=15,method=yule) usqr
   report(col=curr,atrow=7) %qstat
   stats(noprint) %resids
   report(col=curr,atrow=8) %skewness
   report(col=curr,atrow=9) %kurtosis
end dofor s
report(action=format,picture="*.###",align=decimal)
report(action=show)
* Table 3
* The DOW series is 1 for Saturday,...,5 for Wednesday. Create dummies for
* each day of the week.
dec vect[series] dd(5)
do i=1,5
   set dd(i) = dow==(i)
* SKIP is a dummy variable which will be 1 if and only if there is a
* skipped weekday.
set(first=1.0) skip = .not.(dow{1}+1==dow.or.(dow{1}==5.and.dow==1))
nonlin(parmset=meanparms) b0 b1 b2 b3 b4 b5=-(b1+b2+b3+b4)
nonlin(parmset=garchshifts) w0 w1 w2 w3 w4 w5=-(w1+w2+w3+w4) w6 w7
nonlin(parmset=garchparms) alpha1 beta1 rnu
declare series uu h u
frml varf = w0+w1*dd(1)+w2*dd(2)+w3*dd(3)+w4*dd(4)+w5*dd(5)+w6*skip+w7*skip{1}
frml meanf = b0*dx{1}+b1*dd(1)+b2*dd(2)+b3*dd(3)+b4*dd(4)+b5*dd(5)
frml logl = (u=dx-meanf),(uu(t)=u^2),(h(t)=varf(t)),%logtdensity(h,u,1./rnu)
* Create two parallel reports, one for the model estimates, one for the summary statistics
report(action=define,use=garchestimates)
report(action=define,use=garchsummary,hlabels=||"","Stock"||)
report(use=garchsummary,atrow=1,atcol=1,fillby=columns) "$Log L$" "$Q(15)$" "$Q^2(15)$" "$m_3$" "$m_4$" $
   "$3(\hat \nu  - 2)(\hat \nu  - 4)^{ - 1}$"
dofor s = sto
   * * Get preliminary guess values for the mean parameters estimating just the mean model
   nlls(parmset=meanparms,frml=meanf) dx
   * Use the variance of the estimation to initialize the uu and h series
   compute hinit=%seesq
   set uu = %resids^2
   set h  = hinit
   set u  = %resids
   * * Estimation of the full GARCH model will use 1 less data point than
   * the mean model.
   compute gstart=%regstart()+1,gend=%regend()
   * Use base guess values for the variance mean function to avoid
   * problems with negative variances.
   compute w0=hinit,w1=w2=w3=w4=w5=w6=w7=0.0
   * Set initial guess values for the reciprocal degrees of freedom, and
   * the GARCH parameters.
   compute rnu=.10
   compute alpha1=.1,beta1=.8
   maximize(parmset=meanparms+garchshifts+garchparms,pmethod=simplex,piter=10,method=bhhh) logl gstart gend
   report(use=garchestimates,regressors,extra=stderrs)
   report(use=garchsummary,col=new,atrow=1) %funcval
   stats u gstart gend
   set ustd gstart gend = u/sqrt(h)
   corr(print,qstats,number=15,method=yule) ustd gstart gend
   report(use=garchsummary,col=current,atrow=2) %qstat
   set usqr gstart gend = ustd^2
   corr(print,qstats,number=15,method=yule) usqr gstart gend
   report(use=garchsummary,col=current,atrow=3) %qstat
   stats(noprint) ustd
   report(use=garchsummary,col=current,atrow=4) %skewness
   report(use=garchsummary,col=current,atrow=5) %kurtosis
   report(use=garchsummary,col=current,atrow=6) 3.0*(1.0/rnu-2.0)/(1.0/rnu-4.0)
end dofor
report(action=define,use=Table3,title="Table 3 Daily GARCH Models",$
Posted: Thu Nov 30, 2023 7:32 am
In adding the AR(1), you lost the overall intercept (the original B0) in the mean model.
Switch to BFGS.
Posted: Thu Nov 30, 2023 10:43 am
by jack
I did it. It converge now but there are some weird results for Ws and one error too:
he Error Occurred At Location 141, Line 7 of loop/block
## NL6. NONLIN Parameter B0 Has Not Been Initialized. Trying 0
The Error Occurred At Location 141, Line 7 of loop/block
## NL6. NONLIN Parameter B1 Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter B2 Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter B3 Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter B4 Has Not Been Initialized. Trying 0
Nonlinear Least Squares - Estimation by Gauss-Newton
Convergence in     2 Iterations. Final criterion was  0.0000000 <=  0.0000100
Dependent Variable DX
Usable Observations                      3252
Degrees of Freedom                       3247
Skipped/Missing (from 3253)                 1
Centered R^2                        0.1457618
R-Bar^2                             0.1447095
Uncentered R^2                      0.1647480
Mean of Dependent Variable       0.1580648655
Std Error of Dependent Variable  1.0485568659
Standard Error of Estimate       0.9697255177
Sum of Squared Residuals         3053.3735313
Log Likelihood                     -4511.9125
Durbin-Watson Statistic                1.9721
1.  B0                            0.403171477  0.016074203     25.08189  0.00000000
2.  B1                            0.041176919  0.034167888      1.20514  0.22823900
3.  B2                           -0.127392876  0.033930989     -3.75447  0.00017675
4.  B3                            0.054322923  0.034001676      1.59765  0.11021724
5.  B4                           -0.038554483  0.034077121     -1.13139  0.25797492
Convergence in    88 Iterations. Final criterion was  0.0000000 <=  0.0000100
Function Value                     -4089.9545
1.  B0                            0.341042560  0.016168294     21.09329  0.00000000
2.  B1                           -0.026224815  0.022630254     -1.15884  0.24652192
3.  B2                           -0.124552279  0.020565957     -6.05624  0.00000000
4.  B3                            0.049541654  0.020310555      2.43921  0.01471952
5.  B4                            0.051752399  0.019595823      2.64099  0.00826638
6.  W0                            9.907488251  9.796774087      1.01130  0.31187235
7.  W1                            3.515555966  3.631915604      0.96796  0.33306339
8.  W2                            0.709487698  1.105051581      0.64204  0.52084699
9.  W3                           -0.626615566  0.865447793     -0.72404  0.46904349
10. W4                           -1.280058279  1.374920884     -0.93101  0.35185095
11. W6                            3.170326275  3.917629793      0.80925  0.41837366
12. W7                            0.724226904  1.783292734      0.40612  0.68465606
13. ALPHA1                        0.135829128  0.000000000      0.00000  0.00000000
14. BETA1                         1.575463881  0.000000000      0.00000  0.00000000
15. RNU                           0.487274709  0.012874001     37.84952  0.00000000
Statistics on Series U
Observations                  3252
Sample Mean               0.104336      Variance                   0.935307
Standard Error            0.967113      SE of Sample Mean          0.016959
t-Statistic (Mean=0)      6.152238      Signif Level (Mean=0)      0.000000
Skewness                  0.164057      Signif Level (Sk=0)        0.000135
Kurtosis (excess)         4.234114      Signif Level (Ku=0)        0.000000
Jarque-Bera            2443.793706      Signif Level (JB=0)        0.000000
Correlations of Series USTD
Autocorrelations
   1         2          3         4        5        6        7        8        9        10
 0.06224   -0.07544    0.12648  0.05636  0.05543  0.05358  0.03993  0.01975  0.03293  0.06766
   11        12         13        14       15
-0.00124    0.07337    0.10935  0.04824 -0.02630
Ljung-Box Q-Statistics
    Lags  Statistic Signif Lvl
      15    204.438   0.000000
Correlations of Series USQR
Autocorrelations
0.263570   0.272336   0.262070 0.293715 0.275650 0.263236 0.248842 0.225105 0.242704 0.199915
   11        12         13        14       15
0.231811   0.173454   0.269518 0.171193 0.202813
      15   2877.059   0.000000
Re: GARCH Model with Day of Week Dummies
Posted: Thu Nov 30, 2023 9:38 pm
Add the option reject=(alpha1+beta1)>1.02 to your MAXIMIZE instruction.
Posted: Fri Dec 01, 2023 2:53 am
by jack
Thank you very much for your valuable guidance. There is only one issue here. When I open the WINRATS software and run the program, I receive an unusual estimation for the Ws. However, if I don't close the software and run the program again, I get a different result that is entirely inconsistent with the initial results. Nevertheless, in both cases, there seems to be a high correlation between the squared errors. Now, I don't know which result to consider as valid. I am sharing the results of both scenarios here:
First results:
Convergence in    91 Iterations. Final criterion was  0.0000000 <=  0.0000100
1.  B0                            0.341036632  0.015302880     22.28578  0.00000000
2.  B1                           -0.026227732  0.023087069     -1.13604  0.25594167
3.  B2                           -0.124548860  0.020772646     -5.99581  0.00000000
4.  B3                            0.049539334  0.018720660      2.64624  0.00813924
5.  B4                            0.051756212  0.020772103      2.49162  0.01271616
6.  W0                            9.953862589  6.603007798      1.50747  0.13168920
7.  W1                            3.532046029  2.529144511      1.39654  0.16255259
8.  W2                            0.712729598  0.798797611      0.89225  0.37225732
9.  W3                           -0.629041271  0.668342208     -0.94120  0.34660423
10. W4                           -1.286429101  1.226923771     -1.04850  0.29440848
11. W6                            3.184191841  2.883113082      1.10443  0.26940737
12. W7                            0.727386091  1.082084821      0.67221  0.50145128
13. ALPHA1                        0.129100986  0.000000000      0.00000  0.00000000
14. BETA1                         0.783594385  0.000000000      0.00000  0.00000000
15. RNU                           0.487335104  0.008525695     57.16075  0.00000000
Second results:
Convergence in    21 Iterations. Final criterion was  0.0000088 <=  0.0000100
Function Value                      3924.1427
1.  B0                            0.362020821  0.012651769     28.61425  0.00000000
2.  B1                           -0.001639036  0.002074886     -0.78994  0.42956273
3.  B2                           -0.011791114  0.001606696     -7.33874  0.00000000
4.  B3                            0.004651487  0.001716587      2.70973  0.00673379
5.  B4                            0.003955735  0.001839582      2.15035  0.03152793
6.  W0                            0.010338456  0.001673940      6.17612  0.00000000
7.  W1                            0.003310409  0.000973790      3.39951  0.00067506
8.  W2                            0.000658084  0.000418136      1.57385  0.11552222
9.  W3                           -0.000692358  0.000473082     -1.46351  0.14332906
10. W4                           -0.000972662  0.000640953     -1.51752  0.12913434
11. W6                            0.003721021  0.002014078      1.84751  0.06467377
12. W7                            0.000708294  0.001250341      0.56648  0.57106740
13. ALPHA1                        0.151416931  0.000000000      0.00000  0.00000000
14. BETA1                         0.834916582  0.000000000      0.00000  0.00000000
15. RNU                           0.390878811  0.022053321     17.72426  0.00000000
Correlations:
Autocorrelations
0.248439   0.213612   0.204320 0.214314 0.198324 0.192530 0.188234 0.159589 0.169366 0.132010
   11        12         13        14       15
0.164228   0.113017   0.184067 0.104515 0.132029
      15   1566.369   0.000000
Posted: Fri Dec 01, 2023 7:23 am
Do File---Clear Memory (or the wiping rag toolbar icon) before doing a re-run. The LABELS instruction (which is a holdover from the original coding of this) interferes with DATA instruction if the memory isn't clear.
Posted: Fri Dec 01, 2023 7:39 am
by jack
I still get weird results for Ws.
R-Bar^2                             0.1447095
Observations                  3252
Sample Mean               0.104337      Variance                   0.935308
t-Statistic (Mean=0)      6.152290      Signif Level (Mean=0)      0.000000
Skewness                  0.164056      Signif Level (Sk=0)        0.000135
Kurtosis (excess)         4.234107      Signif Level (Ku=0)        0.000000
Jarque-Bera            2443.785838      Signif Level (JB=0)        0.000000
Autocorrelations
 0.06225   -0.07543    0.12648  0.05637  0.05544  0.05358  0.03993  0.01975  0.03293  0.06766
   11        12         13        14       15
-0.00125    0.07337    0.10935  0.04824 -0.02630
      15    204.440   0.000000
Autocorrelations
0.263566   0.272332   0.262065 0.293708 0.275646 0.263230 0.248839 0.225104 0.242696 0.199913
   11        12         13        14       15
0.231807   0.173450   0.269514 0.171187 0.202811
      15   2876.955   0.000000
Posted: Fri Dec 01, 2023 10:00 am
You would need to re-post your current program, but I don't think you adapted the revised program correctly. The new code has an HMEANF which has the shifted means for the variance, and then a VARF which uses that to get the variance. Your VARF above just does the mean.
Posted: Fri Dec 01, 2023 10:23 am
by jack
Appreciate your help:
* 297-305
open data tom1.xlsx
data(format=xlsx,org=columns) 1 3255 sto dow
labels sto
# "Stock"
log sto
* Unit root tests
* Table 1
source ppunit.src
dofor s = sto
   @ppunit(lags=22) s
end dofor
report(action=show)
* Table 2 estimates
dofor s = sto
   linreg(noprint) dx
   # constant dx{1}
   set usqr = ustd^2
end dofor s
report(action=show)
* Table 3
* The DOW series is 2 for Saturday,...,5 for Wednsday. Create dummies for
do i=1,5
* skipped weekday.
nonlin(parmset=garchshifts) w1 w2 w3 w4 w5 w6 w7
frml varf = alpha1*uu{1}+beta1*h{1}+$
   w1*dd(1)+w2*dd(2)+w3*dd(3)+w4*dd(4)+w5*dd(5)+w6*skip+w7*skip{1}-$
   (alpha1+beta1)*(w1*dd(1){1}+w2*dd(2){1}+w3*dd(3){1}+w4*dd(4){1}+w5*dd(5){1}+w6*skip{1}+w7*skip{2})
report(action=define,hlabels=||"","Stock"||)
dofor s = sto
   * Get preliminary guess values for the mean parameters off an OLS
   * regression on the mean dummies.
   linreg(noprint) dx
   # dd dx{1}
   set uu = %resids^2
   set h  = hinit
   set u  = %resids
   * Poke those into the meanparms.
   compute %parmspoke(meanparms,%beta)
   * Get preliminary guess values for the dummy terms in the variance
   * equation by an OLS regression of the squared residuals on the
   * dummies.
   linreg uu
   # dd skip skip{1}
   * Poke those into the shift parameters
   compute %parmspoke(garchshifts,%beta)
   compute rnu=.10
   set test 4 * = logl(t)
   sstats 4 * .not.%valid(test)>>nmiss
   if nmiss>0.0
      compute w1=w2=w3=w4=w5=hinit,w6=w7=0.0
   maximize(parmset=meanparms+garchshifts+garchparms,pmethod=simplex,piter=10,method=bhhh) logl 4 *
   report(regressors,extra=stderrs)
   report(col=current,atrow=2*%nreg+2) %funcval
   stats u 4 *
   set ustd 4  * = u/sqrt(h)
   corr(print,qstats,number=15,method=yule) ustd 4 *
   report(col=current,atrow=2*%nreg+3) %qstat
   set usqr 4 * = ustd^2
   corr(print,qstats,number=15,method=yule) usqr 4 *
   report(col=current,atrow=2*%nreg+4) %qstat
   stats(noprint) ustd
   report(col=current,atrow=2*%nreg+5) %skewness
   report(col=current,atrow=2*%nreg+6) %kurtosis
   report(col=current,atrow=2*%nreg+7) 3.0*(1.0/rnu-2.0)/(1.0/rnu-4.0)
end dofor
report(action=show)
Posted: Fri Dec 01, 2023 10:42 am
That looks like an old copy of your program.
Posted: Fri Dec 01, 2023 11:33 am
by jack
So sorry, I edited it, still have the error:
* 297-305
open data tom1.xlsx
labels sto
# "Stock"
log sto
* Unit root tests
* Table 1
source ppunit.src
dofor s = sto
   @ppunit(lags=22) s
end dofor
report(action=show)
* Table 2 estimates
dofor s = sto
   linreg(noprint) dx
   # constant dx{1}
   set usqr = ustd^2
end dofor s
report(action=show)
* Table 3
do i=1,5
* skipped weekday.
dofor s = sto
   set uu = %resids^2
   set h  = hinit
   set u  = %resids
   * the mean model.
   compute rnu=.10
   maximize(parmset=meanparms+garchshifts+garchparms,pmethod=simplex,piter=10,method=bfgs,reject=(alpha1+beta1)>1.02) logl gstart gend
   stats u gstart gend
   stats(noprint) ustd
end dofor
