Page 3 of 4
Re: Diebold-Yilmaz, IJF 2012
Posted: Sat Jun 24, 2023 1:26 pm
by izymougoue2006
Hello, can I send you my database.
We made some modifications which allowed us to have the volatility spillover table.
I remind you that I am studying the financial contagion of African stock markets during the covid-19 pandemic. I work with 16 markets, that is to say 16 variables. so I ask with 16 variables what modification should I do to generate the graphs.
Posted: Sun Jun 25, 2023 10:54 am
TomDoan wrote:This is the replication file for Diebold and Yilmaz(2012), "Better to give than to receive: Predictive directional measurement of volatility spillovers," International Journal of Forecasting, vol. 28, no 1, 57-66. This is a companion piece to Diebold and Yilmaz(2009). The 2012 article uses "generalized" IRF's rather than the Cholesky IRF's used in the 2009 article, though the ability to use GIRF's has been included in the DY 2009 code for several years. The 2012 uses a much smaller set of series which makes several other types of measures feasible, such as rolling net pairwise spillovers. (Those could be computed in the 2009 data set, but there would be 171 pairs for that rather than 6 for the small set.)
Given the number of series you have, you probably need to look more to the calculations that are done in the 2009 paper (which is more similar in size) than the 2012 paper.
Posted: Tue Jun 27, 2023 11:25 am
by izymougoue2006
Good morning
Thank you for the explanations
After reviewing my database, I was able to get the graphics. Now my problem is the dates that do not appear in the x-axis but rather the totals of days that appear.
Posted: Tue Jun 27, 2023 12:29 pm
You would have to post the data and program so I could see why you aren't getting the dates.
Posted: Tue Jul 04, 2023 5:20 pm
by izymougoue2006
hello Tom, you are doing well I hope
Please find attached below the codes. Please find attached to this text, my database
open data C:\Users\PC\Desktop\COVIDSS.xlsx
data(format=xlsx,org=col) / TUN ZAN MAUR NIG MAR ZAM AFS EGY NAM BOS BRVM KEY FRA ALL USA CHINE
compute usegirf=1
*****************************return spillover***************************
dec vect[int] vols
enter(varying) vols
# TUN ZAN MAUR NIG MAR ZAM AFS EGY NAM BOS BRVM KEY FRA ALL USA CHINE
dec vect[string] longlabels(%size(vols))
enter longlabels
# "TUN" "ZAN" "MAUR" "NIG" "MAR" "ZAM" "AFS" "EGY" "NAM" "BOS" "BRVM" $
"KEY" "FRA" "ALL" "USA" "CHINE"
dec vect[string] shortlabels(%size(vols))
enter shortlabels
* Setup and estimate two lag VAR
system(model=volvar)
variables vols
lags 1 2
estimate(noprint)
* Save the full estimation range for later use
compute rstart=%regstart(),rend=%regend()
* Analyze the 10 step responses
compute nsteps=10
* Produce the appropriate "factor" matrix from %sigma
function FactorMatrix
type rect FactorMatrix
if usegirf
   compute FactorMatrix=%sigma*inv(%diag(%sqrt(%xdiag(%sigma))))
else
   compute FactorMatrix=%decomp(%sigma)
compute gfactor=FactorMatrix()
errors(model=volvar,steps=nsteps,factor=gfactor,stderrs=gstderrs,noprint,results=gfevd)
compute gfevdx=%xt(gfevd,nsteps)
* These are for computing the contributions from others, to others and
* to others including own for each variable.
dec vect tovar(%nvar) fromvar(%nvar) tototal(%nvar)
ewise fromvar(i)=%sum(%xrow(gfevdx,i))-gfevdx(i,i)
ewise tovar(i)=%sum(%xcol(gfevdx,i))-gfevdx(i,i)
ewise tototal(i)=tovar(i)+1-fromvar(i)
compute spillover=100.0*%sum(tovar)/%nvar
report(action=define,title="Table 4. Spillover Table for Global Market Volatility")
report(atrow=1,atcol=2,align=center,fillby=rows) shortlabels
report(atrow=2,atcol=1,fillby=cols) shortlabels
report(atrow=2,atcol=2) 100.0*gfevdx
report(atrow=%nvar+2,atcol=1,fillby=rows) "Contribution to others" 100.0*tovar
report(atrow=%nvar+3,atcol=1,fillby=rows) "Contribution including own" 100.0*tototal
report(atcol=%nvar+2,atrow=1) "From Others"
report(atcol=%nvar+2,atrow=2,fillby=cols) 100.0*fromvar
report(atrow=%nvar+2,atcol=%nvar+2,fillby=cols) 100.0*%sum(tovar)
report(atrow=%nvar+3,atcol=%nvar+2,align=right) %strval(spillover,"##.#")+"%"
report(atrow=2,atcol=2,torow=%nvar+1,tocol=%nvar+1,action=format,picture="*.#")
report(atrow=%nvar+2,torow=%nvar+3,atcol=1,tocol=%nvar+2,action=format,picture="###")
report(atcol=%nvar+2,atrow=2,torow=%nvar+2,action=format,picture="###")
report(action=show)
* Rolling sample analysis
compute nspan=200
dec series totalspill
dec symm pairvar(%nvar,%nvar) pair(%nvar,%nvar)
dec vect[series] fromspill(%nvar) tospill(%nvar) netspill(%nvar) own(%nvar)
dec symm[series] pairspill(%nvar,%nvar) pairpercent(%nvar,%nvar)
clear(zeros) fromspill topspill totalspill netspill pairspill paircent own
do end=rstart+nspan-1,rend
   estimate(noprint) end-nspan+1 end
   * Skip any data points where the rolling VAR has an explosive root.
   eigen(cvalues=cv) %modelcompanion(volvar)
   if %cabs(cv(1))>=1.0 {
      compute totalspill(end)=%na
      next
   errors(model=volvar,steps=nsteps,factor=gfactor,noprint,results=gfevd)
   ewise pairvar(i,j)=gfevdx(i,j)-gfevdx(j,i)
   ewise pair(i,j)=gfevdx(i,j)
   compute totalspill(end)=100.0*%sum(tovar)/%nvar
   compute %pt(fromspill,end,100.0*fromvar)
   compute %pt(tospill,end,100.0*tovar)
   compute %pt(netspill,end,100.0*(tovar-fromvar))
   compute %pt(own,end,100.0*(1-fromvar))
   compute %pt(pairspill,end,100.0*pairvar)
   compute %pt(pairpercent,end,100.0*pair)
end do end
graph(footer="Spillover plot. Volatility. 200 week window. 10 step horizon")
# totalspill rstart+nspan-1 rend
* With a 140 week span instead, using both the 2 week and 10 week
* forecast horizons.
compute nspan=140
set spillvols rstart+nspan-1 rend = 0.0
set spillvol2 rstart+nspan-1 rend = 0.0
      compute spillvols(end)=%na
      compute spillvol2(end)=%na
      next
   * Compute for 10 steps
   compute gfevdx=%xt(gfevd,10)
   compute spillvols(end)=100.0*%sum(tovar)/%nvar
   * Compute for 2 steps
   compute gfevdx=%xt(gfevd,2)
   compute spillvol2(end)=100.0*%sum(tovar)/%nvar
end do end
spgraph(vfields=2, Header="Figure 1. Spillover index plot. Currency volatilities" ,$
  footer="140 Week Rolling Windows")
graph(header="(a) 10 Week forecast horizon")
# spillvols  rstart+nspan-1 rend
graph(header="(b) 2 Week forecast horizon")
# spillvol2 rstart+nspan-1 rend
***************************Own-variable markets****************************
spgraph(vfields=4,hfields=4,$
  header="Figure 2. Own-variable market effects. volatility ")
 do i=1,%nvar
   graph(header=longlabels(i), style=bar)
   # own(i)
*********************Directional spillovers********************************
  header="Figure 3. Directional volatility Spillovers", footer="Black line for inward and blue line for outward")
 do i=1,%nvar
   graph(header=longlabels(i)) 2
   # fromspill(i)
   # tospill(i)
**************************Net spillovers***********************************
spgraph(vfields=4,hfields=4, $
  header="Figure 4. Net Volatility Spillovers")
 do i=1,%nvar
   # netspill(i)
  header="Figure 5. Net Volatility Spillovers Among Currencies")
 do i=1,%nvar
   graph(header=longlabels(i),style=bar)
   # netspill(i) rstart+nspan-1 rend
Posted: Wed Jul 05, 2023 9:43 am
The data file has a weird mix of numerically coded vs straight text dates. (We've seen that before, and I have no idea why anyone would ever do that). At any rate, the following will give you, so far as I can tell, the correct dates:
cal(d) 2020:01:02
data(format=xlsx,org=col,left=2) / TUN ZAN MAUR NIG MAR ZAM AFS EGY NAM BOS BRVM KEY FRA ALL USA CHINE
Note, however, that your final data point seems to be just 0's across the board, which I assume means that they were no longer keeping track, so you probably want to ignore that. (I would probably just delete it off the data set).
What exactly are your data? I assume something Covid related, but I can't really tell what (most of the series start high in 2020). The estimated VAR's tend to be unstable, which is why you end up with so few data points in the graphs for the rolling window analysis.
Posted: Fri Jul 07, 2023 6:32 am
by izymougoue2006
hello Tom
Thanks for the relevant feedback and comments.
yes obviously my data is originally for stock prices during the covid-19 period. the data starts high in 2020 which can be explained by the stock market panic at the start of the pandemic.
I recall that the objective of this study is to see the transmission of volatility within the African stock markets and also some world stock markets.
Posted: Fri Jul 07, 2023 10:20 am
But what are they? Why are they zero in the last period (for every country)? You can't just throw poorly prepped data into a VAR and hope you will get reasonable results.
Posted: Sat Jul 08, 2023 2:04 pm
by izymougoue2006
Countries are South Africa, Tunisia, Nigeria, BRVM, Zambia, Morocco, Mauritius, Tanzania, Egypt, Namibia, Botswana and Keyna and non-African countries are China, France, Germany and the United States.
I specify that the last year I removed it from my base. The fact that the last years are equal to zero is explained by the fact that when calculating the returns (before calculating the volatility) I had limited myself to the date of 30/12/2022. But after I calculated the volatility with the performance data (stopped at 30/12/2022) which makes the last year equal to zero.
Posted: Sun Jul 09, 2023 1:04 pm
These are supposed to be volatility estimates? Why are they not exploding in March 2020 when the stock market was crashing?
Posted: Mon Jul 10, 2023 8:33 am
by izymougoue2006
YES of course these are volatility estimates.
I myself am surprised by the results what I am seeing which could explain the fact that the markets do not explode in March 2021.
Do you think it's a data problem?
Also, I calculated the volatility with excel.
If there are, can you tell me the codes that can calculate the volatility?
Posted: Mon Jul 10, 2023 8:58 am
How did you calculate the volatility using Excel? In the two DY papers, they calculate volatility using daily max and min's of the prices. Do you have those?
If you are doing some type of rolling estimates of the standard deviation of returns
(a) Something is going wrong, since they should be spiking at times when the returns are sharply negative. (Perhaps the Excel calculation is computing the sample standard deviation based upon squares around the mean of the short sample, which might cause a small "volatility" value if the returns are consistently negative during that range).
(b) Even if those are done correctly, they will have very different dynamics than the volatility estimates in the DY papers because they are based upon rolling samples and thus will (by construction) be quite persistent, while DY's are independently estimated in each period.
Posted: Thu Jul 13, 2023 8:47 am
by izymougoue2006
I calculated the volatility on Excel.
well, I don't have the DY volatility calculation codes with me. Can you send them to me.
Posted: Thu Jul 13, 2023 11:51 am
izymougoue2006 wrote:I calculated the volatility on Excel.
The code is very simple (it's a one-line calculation, shown in both of the papers). But you have to have the daily max and min for each of the price series. It uses a formula for estimating the underlying variance of a (unit length) Brownian motion (the calculation of sigsq) from the range, which is then annualized (if it's a daily calculation) and scaled to percentages:
set sigsq = .361*(log(pmax)-log(pmin))^2
set vol = 100*sqrt(365*sigsq)
Posted: Fri Jul 21, 2023 2:09 pm
I'm going to guess that the formula you were using in Excel is taking a moving window variance estimate for the returns. There are two problems with that:
  1. A sample "variance" estimate is based upon variation around a sample mean. The volatility, however, is generally defined to be the variance of a non-drifting Brownian motion, so you would not want means subtracted. (Mean should be assumed zero). That way be why you aren't seeing a spike during the early Covid period since the sample variance is taken around negative means rather than zero.
  2. The moving window estimates will have (by construction) a great deal of persistence. Most of the dynamics in the VAR will going into unwinding that, so it's not clear whether the DY spillover statistic will show much besides that.
If you don't have the per-period range of the underlying price, the closest thing you have is the series of squared returns. That will be a noisy data series (much noisier than the range), but will at least not be strongly autocorrelated by construction.
