TomDoan wrote: ↑Mon Mar 11, 2024 1:12 pm
You can also do the VAR in differences with a blank ECT instruction using the same LAGS options.
Yes, that's useful as it's straightforward to be in levels and not experience the problems here
https://estima.com/forum/viewtopic.php?t=1724
Questions
(i) I have noticed if I have, e.g.
equation(coeffs=%xcol(cvectors,1)) D_ect1 *
# ftbs3 ftb12 fcm7 constant
equation(coeffs=%xcol(cvectors,2)) D_ect2 *
they will appear as just EC1{1} EC2{1} in the VECM after ESTIMATE regardless of the D_ in front. Why?
Presumably, if after the dynamic (D_) forecasts, within the same RPF file, I am generating static 1-step ahead VECM static forecasts and defining the ECT's as S_ECT1, S_ECT2 using EQUATION, and ESTIMATE, there will be an overwrite, and the latest ECT's i.e. S_ECT1 S_ECT2 will be used?
(ii) To aid my understanding, given a VAR-in-levels with DET=NONE or DET=CONSTANT I can manually calculate the PI matrix
PI = - (I - GAMMA(1) - GAMMA(2) - ... - GAMMA(p))
where
I is the identity matrix
GAMMA's are the matrices of parameters up to the AR(pth) lag.
How to 'by-hand' calculate PI including the deterministic terms: DET=RC, DET=TREND, and SEASONAL?
(iii) Does %VARLAGSUMS always = -PI?
(iv) I'll accept that I do not need to normalize the cointegrating vectors prior to forecasting, but I do not understand the normalization as in
https://www.estima.com/ratshelp/index.h ... edure.html, enders4p389.rpf and Enders (1996) RATS Handbook for Econometric Time Series Chapter 6? Why normalize?
JohMLE.src
(v) The
generalized evalues and evectors are calculated from submatrices of the s matrix and
not of the PI matrix.
Solving | s10_00_01 - (lambda*%%s11) | = 0
What is the relationship between PI and
(a) s10_00_01
(b) %%s00
(c) %%s11
(d) %%s01
(vi) Should the values of PI (long-run matrix of coefficients) be interpreted or it's factor matrices:
- alpha (speed of adjustment to equilibrium coefficients) and
- beta (long-run matrix of coefficients).
What do the sign and magnitude of the coefficients mean?
Further, how to interpret the PI*Y(t-1) term in the VECM UG-247 eqn(31) ?
(vii) DET=CONSTANT allows for a linear trend in the data; DET=RC does not. But exactly what is the RC? If DET=RC there is an additional ECT, e.g. 3 variables, 4 ECT's. I have read the explanation in ECT.RPF but am none the wiser. Please can you provide a simpler numerical explanation.
