Page 4 of 4
Re: Recursive VECM - Johansen ML technique
Posted: Wed Mar 20, 2024 3:40 am
by ac_1
TomDoan wrote: Mon Mar 18, 2024 9:23 am
ac_1 wrote: Mon Mar 18, 2024 2:59 am (ii) To aid my understanding, given a VAR-in-levels with DET=NONE or DET=CONSTANT I can manually calculate the PI matrix
PI = - (I - GAMMA(1) - GAMMA(2) - ... - GAMMA(p))
where
I is the identity matrix
GAMMA's are the matrices of parameters up to the AR(pth) lag.
How to 'by-hand' calculate PI including the deterministic terms: DET=RC, DET=TREND, and SEASONAL?
DET=RC and DET=RTREND are the only ones that are more complicated, and that is only because they anticipate a restriction on the intercept (or trend). The adjusted "PI" matrix in rearranging the unrestricted VAR simply adds a column of the estimates on the constant (DET=RC) and trend term (DET=RTREND).
Probably easier to include
comp PI = loadings*tr(vectors))
to calculate PI in JohMLE.src
From, https://www.estima.com/ratshelp/index.h ... edure.html
DET=NONE/[CONSTANT]/TREND/RC, should be RTREND to get the additional column of estimates, although @JOHMLE accepts TREND as-well?
(vii) If I run my acmtsICRS.src procedure for plotting of the inverse roots.
I get an error
Dimension Companion matrix
## MAT1. Matrix COMPANION Has Not Been Dimensioned
Here
* AR roots
if (mts == 0)
   compute companion=%modelcompanion(mtsmodel)
   eigen(cvalues=mtsroots) companion
if (mts == 1)
   compute companion=%modelcompanion(%modelsubstect(mtsmodel))
acmtsICRS.src is to be used for any VAR and VECM.
How to declare the dimension of the Matrix beforehand?
Posted: Wed Mar 20, 2024 9:37 am
ac_1 wrote: Wed Mar 20, 2024 3:40 am (vii) If I run my acmtsICRS.src procedure for plotting of the inverse roots.
I get an error
Here
* AR roots
if (mts == 0)
if (mts == 1)
That's not how IF's work in RATS. You need braces around the controlled instructions.
Posted: Wed Mar 20, 2024 4:21 pm
by ac_1
TomDoan wrote: Wed Mar 20, 2024 9:37 am
I get an error
Here
* AR roots
if (mts == 0)
if (mts == 1)
* AR roots
if (mts == 0) {
   eigen(cvalues=mtsroots) companion }
if (mts == 1) {
I get the following error
## SX22. Expected Type VECTOR[REAL], Got INTEGER Instead
>>>>sroots) companion }<<<<
Posted: Wed Mar 20, 2024 7:21 pm
Put the close } on a new line.
Posted: Thu Mar 21, 2024 2:57 am
by ac_1
TomDoan wrote: Wed Mar 20, 2024 7:21 pm Put the close } on a new line.
Posted: Thu Mar 21, 2024 12:47 pm
ac_1 wrote: Wed Mar 20, 2024 3:40 am From, https://www.estima.com/ratshelp/index.h ... edure.html
We've updated that, but note well that DET=TREND means that 1 and t are included in the regressions which, in the presence of unit roots, will create a quadratic trend. Needless to say, there isn't much call for that. Trending data are usually handled reasonably with DET=CONSTANT. DET=RTREND is really only useful when there are trending data, but it's not clear if the series actually have unit roots. (Unit roots plus DET=CONSTANT creates trends, but stationary data will not).
Posted: Fri Mar 22, 2024 3:22 am
by ac_1
TomDoan wrote: Thu Mar 21, 2024 12:47 pm
Thanks! You may want to update the Output https://www.estima.com/ratshelp/index.h ... edure.html as these are the results with RATS 10.00 version c.
The Rank 0 row is for the differenced model
Likelihood Based Analysis of Cointegration
Variables:  FTBS3 FTB12 FCM7
Estimated from 1975:07 to 2001:06
Data Points 312 Lags 6 with Constant restricted to Cointegrating Vector
Unrestricted eigenvalues and -T log(1-lambda)
  Rank     EigVal  Lambda-max  Trace   Trace-95%  LogL
        0                                        20.2392
        1   0.0818    26.6264  41.2013   35.0700 33.5524
        2   0.0333    10.5567  14.5750   20.1600 38.8307
        3   0.0128     4.0183   4.0183    9.1400 40.8399
Cointegrating Vector for Largest Eigenvalue
FTBS3     FTB12    FCM7       Constant
-3.154123 3.132882  -0.321838 0.619010
Harris, R (1995) Using Cointegration Analysis in Econometric Modelling, Pearson Educaton Limited, Prentice Hall,
is a good book which uses CATS, amongst other packages (I would like CATS 2.0 at sometime in the future).
Posted: Fri Mar 22, 2024 7:17 am
We changed the format of the output to match the general CATS rank test statistics. We can't change help files on older software.
Posted: Tue Mar 26, 2024 6:04 am
by ac_1
To complement individual variable residual plots as in ARIMA models (i) time plot (ii) ACF (iii) histogram with normal density (iv) qplot (normal); regarding multivariate residual tests (as a 'generic' battery) for a VAR and VECM (e.g. 3 variable) are these exhaustive and with the correct options/parameters?
CROSS(qstats,org=columns,from=-8,to=8) resids(1) resids(2)
@CROSSCORR(number=20) resids(1) resids(2)
CROSS(qstats,org=columns,from=-8,to=8) resids(1) resids(3)
@CROSSCORR(number=20) resids(1) resids(3)
CROSS(qstats,org=columns,from=-8,to=8) resids(2) resids(3)
@CROSSCORR(number=20) resids(2) resids(3)
* multivariate residual heteroskedasticity test
* https://estima.com/ratshelp/index.html?archtestprocedure.html
* H0: is that the series are mean zero, not serially correlated and with a fixed covariance matrix
* p = 0 reject the null; p >= 0.05 cannot reject the null
@mvarchtest(lags=5)
# resids
* multivariate residual Hosking(1981) variant of the multivariate Q statistic
* https://estima.com/ratshelp/index.html?mvjbprocedure.html
* H0: No serial correlation
comp k=4; comp plag=4
@mvqstat(dfc=(plag*k^2),lags=12)
# resids
* multivariate residual stability test in Nyblom(1989) for a complete covariance matrix
* H0: null is that the covariance matrix of the series is constant vs an alternative of a structural break at some point in the sample.
@cvstabtest
# resids
* multivariate residual normality test
* H0: The null hypothesis is a joint hypothesis of the skewness being zero and the excess kurtosis being zero.
@mvjb(sigma=%sigma)
# resids
Posted: Tue Mar 26, 2024 12:46 pm
Exhaustive is a bit strong. Those look fine.
Posted: Fri Apr 05, 2024 3:11 am
by ac_1
(a) In a cointegrated VECM for I(1) variables:
- Is it worth plotting the IRF's as they are not mean reverting, as per unit roots relative to the complex unit circle?
- What about variance decompositions?
(b) I'd like to delve deeper into the 5 determininstic components in @JOHMLE
CASE 1: None
CASE 2: Constant
CASE 3: Trend
CASE 4: Restricted constant
CASE 5: Restricted trend
To aid my understanding, I can manually calculate the PI matrix from the levels estimation for CASE 1 and CASE 2 --- Constant calculation here, but not for the others. How? Although the PI matrix is formed from the residual product moment matrices, Box 5.1, Harris (1995).
* VAR (lag=1 to 6, DET=CONSTANT)
system(model=ratemodel)
variables ftbs3 ftb12 fcm7
lags 1 to 6
estimate(residuals=resids,noftests) 1975:07 2001:06-nsteps
disp %BETASYS
disp %VARLAGSUMS; * -PI matrix
dec rectangular ID A1 A2 A3 A4 A5 A6
dim ID(3,3) A1(3,3) A2(3,3) A3(3,3) A4(3,3) A5(3,3) A6(3,3)
disp %identity(3)
comp ID = || -1.0, 0.0, 0.0 | $
             0.0, -1.0, 0.0 | $
             0.0, 0.0, -1.0 ||
disp ID
comp A1 = || %BETASYS(1), %BETASYS(7), %BETASYS(13) | $
             %BETASYS(20), %BETASYS(26), %BETASYS(32) | $
             %BETASYS(39), %BETASYS(45), %BETASYS(51) ||
disp A1
comp A2 = || %BETASYS(2), %BETASYS(8), %BETASYS(14) | $
             %BETASYS(21), %BETASYS(27), %BETASYS(33) | $
             %BETASYS(40), %BETASYS(46), %BETASYS(52) ||
disp A2
comp A3 = || %BETASYS(3), %BETASYS(9), %BETASYS(15) | $
             %BETASYS(22), %BETASYS(28), %BETASYS(34) | $
             %BETASYS(41), %BETASYS(47), %BETASYS(53) ||
disp A3
comp A4 = || %BETASYS(4), %BETASYS(10), %BETASYS(16) | $
             %BETASYS(23), %BETASYS(29), %BETASYS(35) | $
             %BETASYS(42), %BETASYS(48), %BETASYS(54) ||
disp A4
comp A5 = || %BETASYS(5), %BETASYS(11), %BETASYS(17) | $
             %BETASYS(24), %BETASYS(30), %BETASYS(36) | $
             %BETASYS(43), %BETASYS(49), %BETASYS(55) ||
disp A5
comp A6 = || %BETASYS(6), %BETASYS(12), %BETASYS(18) | $
             %BETASYS(25), %BETASYS(31), %BETASYS(37) | $
             %BETASYS(44), %BETASYS(50), %BETASYS(56) ||
disp A6
comp PIVAR = ID + A1 + A2 + A3 + A4 + A5 + A6; disp 'PIVAR:' PIVAR
Posted: Fri Apr 05, 2024 7:55 am
ac_1 wrote: Fri Apr 05, 2024 3:11 am (a) In a cointegrated VECM for I(1) variables:
Yes and yes. While the variances diverge, the decomposition converges. See, for instance, the Hasbrouck paper, which does a long-run variance decomposition.
ac_1 wrote: Fri Apr 05, 2024 3:11 am (b) I'd like to delve deeper into the 5 determininstic components in @JOHMLE
CASE 1: None
CASE 2: Constant
CASE 3: Trend
lags 1 to 6
disp %BETASYS
disp %identity(3)
             0.0, -1.0, 0.0 | $
             0.0, 0.0, -1.0 ||
disp ID
disp A1
disp A2
disp A3
disp A4
disp A5
disp A6
Those have non-standard distributions so you can't use IC's to choose among them. I don't even know how much work anyone has done on comparisons among those---they are inextricably linked to the rank of cointegration. (For instance, DET=RC has only r "constants", rather than a full set). Because of that, you can only back out the estimates in certain cases. Note that CATS assumes the DET is known before going about the analysis.
