Page 4 of 4
Re: Diebold-Yilmaz EJ 2009
Posted: Wed Jun 15, 2016 11:47 am
What does "These variables could be analyzed in a simple panel framework that inflation for example, refers to all emerging countries " mean? If you're talking about some type of more standard macro VAR including several different macro series in a single model, then you shouldn't be looking at DY as the guide.
If you are talking about one model for inflation, and a different one for industrial production, etc. then the DY calculations would allow you to aggregate either sources or targets. You can calculate the total spillover from the G7 to (say) Greece in a 20 country VAR.
Posted: Fri Dec 07, 2018 10:25 am
by smgrilli
I got a similar issue while using DY. Error message:
The Error Occurred At Location 23, Line 4 of FACTORMATRIX
Called From Location 172, Line 11 of loop/block
The spillover index can be computed, but I encounter this error in the rolling estimation. I'm iterating the same code for different measures, but the number of missing values changes substantially between variables. In particular, one variable has almost half of the observations missing. The code is as follows:
* Rolling window analysis
compute nspan=200
set spillreturns rstart+nspan-1 rend = 0.0
do end=rstart+nspan-1,rend
estimate(noprint) end-nspan+1 end
* Skip any data points where the rolling VAR has an explosive root.
eigen(cvalues=cv) %modelcompanion(returnvar)
if %cabs(cv(1))>=1.0 {
compute spillreturns(end)=%na
next
compute gfactor=FactorMatrix()
errors(model=returnvar,steps=nsteps,factor=gfactor,stderrs=gstderrs,noprint,results=gfevd)
compute gfevdx=%xt(gfevd,nsteps)
ewise tovar(i)=%sum(%xcol(gfevdx,i))-gfevdx(i,i)
compute spillreturns(end)=100.0*%sum(tovar)/%nvar
end do end
graph(footer="Spillover plot. Returns. 200-weeks window. 10 step horizon")
# spillreturns
Based on previous threads, I have reduced the window to 20 observations just to try, but I get the same error.
Any suggestions about how to overcome this issue?
Posted: Fri Dec 07, 2018 11:12 am
Going to a very short window is exactly the wrong thing to do. You run into that problem when there isn't enough data in a span to estimate the model. How many variables do you have and how many lags?
Posted: Fri Dec 07, 2018 12:34 pm
by smgrilli
I have 10 variables and 1353 observations, with many missing values. The VAR is defined as
system(model=returnvar)
variables returns
lags 1 2
I attached a sample .xls file
Posted: Fri Dec 07, 2018 1:21 pm
You can't do moving windows analysis when entire windows are missing data. Figure out what range actually works for that part and restrict yourself to the appropriate subsample.
Posted: Sat Dec 08, 2018 3:30 am
by smgrilli
That's clear, thanks Tom. I thought the command does compute the rolling window only for the available data automatically. I trim the file and run it again.
Posted: Tue Jun 16, 2020 10:15 pm
by curiousresearcher
Can anyone tell how has the volatility series been generated as return series can be quickly computed from price data?
Also, can we get these volatility information series from Thomson Eikon database or we need to compute it?
Posted: Wed Jun 17, 2020 7:58 am
vicky007 wrote:Can anyone tell how has the volatility series been generated as return series can be quickly computed from price data?
That's described in the 2009 paper---it's computed from the high/low/open/close for the week. However, if you have estimates (remember that volatility isn't observable, so has to be estimated somehow) from a well-known database, there's no reason you can't use that.
Posted: Fri Jun 19, 2020 11:04 pm
TomDoan wrote:vicky007 wrote:Can anyone tell how has the volatility series been generated as return series can be quickly computed from price data?
Thanks a lot i am using thomson eikon databse and it is allowing me the option of volatility (1 month), volatility (2 month), volatility (3 month), volatility (6 month), volatility (1 year) and volatility (2 days).
So should i be using volatility (2 days) for daily dates as most appropriate measure for DY method . I am attacing the data file taken from Thomson EIKON
Posted: Thu Aug 31, 2023 8:12 pm
They have two day, one month and not one week? That seems very odd. Two day volatility estimates with daily data will have an overlap problem.
Can't you get the high/low/open/close information to generate your own volatility estimates?
