Page 5 of 7
Posted: Mon Sep 07, 2009 4:34 pm
TL wrote:Dear Tom,
Thank you very much for your reply. However, I still have one more question I would like to ask you. Sorry for not making the question clear previously.
With the following code, I would like to normalize the third variable (INT) to increase by 1 initially, as the effect of the first shock.
For the second shock, I do not want to normalize anything.
Could you please give me suggestions on how to perform this?
Sincerely,
Tim
If you want the 3rd shock to hit the 3rd variable with size one, add:
compute i3=i3/i3(3)
If you don't want to rescale the 2nd, leave i2 alone.
Posted: Tue Sep 08, 2009 10:26 am
by TL
Thank you very much for your reply. I am sorry to ask you again.
Under the following line in the original code
compute i1=p*v1
I have added the following code (for the 1st shock to hit the 3rd variable with size one)
compute i1=i1/i1(3)
I got the following message
## SX20. Expected , Here
>>>>compute i1=i1/i1(3)<<<<
I am not sure whether I have added such code at the right place or I might do something wrong. Could you please give me suggestions?
Sincerely,
Tim
     OPEN DATA All_4_Thailand.xls
    CALENDAR 1989 2 12
    compute missc=1.0e+32
    data(format=xlS,org=columns) 1989:2 2008:11 CPI Y INT SS FF PP
    set CPI = CPI*100.0
    set Y   = Y*100.0
    set SS  = SS*100.0
    set FF  = FF*100.0
    set PP  = PP*100.0
    system(model=varmodel)
    variables Y CPI INT PP FF SS
    lags 1 to 6
    deterministic constant
    estimate(noprint,resid=resids)
    dec vect[strings] vl(6)
    compute vl=||'Real GDP','Consumer Prices','Interest Rates',$
          'Real Exchange Rates','Financial Sector Index Real Stock Prices','Market Index Real Stock Prices'||
    compute n1=10000
    compute n2=10000
    compute nvar=6
    compute nstep=60
    compute KMAX=5
    compute hstart = 1995:1
    compute hend   = 1999:12
    compute nhor   = hend-hstart+1
    dec vect[series] upaths(nvar) u(nvar) onesteps(nvar) base(nvar) baseplus(nvar)
    dec vect[series] upathsa(nvar) baseplusa(nvar)
    clear upaths
    clear upathsa
    dec symm s(6,6)
    dec vect v1(6)      ;* For the unit vector on the 1st draw
    dec vect v2(5)      ;* For the unit vector on the 2nd draw
    dec vect v(6)     ;* Working impulse vector
    compute sxx    =%decomp(%xx)
    compute svt    =%decomp(inv(%nobs*%sigma))
    compute ncoef  =%rows(sxx)
    compute wishdof=%nobs-ncoef
    dec rect ranc(ncoef,nvar)
    * Most draws are going to get rejected. We allow for up to 1000
    * good ones. The variable accept will count the number of accepted
    * draws. GOODRESP will be a RECT(nsteps,nvar) at each accepted
    * draw.
    declare vect[rect] goodresp(1000) goodfevd(1000)
    declare vect[rect] goodrespa(1000) goodfevda(1000)
    compute ones=%const(1.0)
    source forcedfactor.src
    declare vector hk(nvar)
    declare vect[rect] goodhist(1000) goodhista(1000)
    compute accept=0
    infobox(action=define,progress,lower=1,upper=n1) 'Monte Carlo Integration'
    do draws=1,n1
        * responses.
        compute sigmad  =%ranwisharti(svt,wishdof)
        compute p       =%decomp(sigmad)
        compute ranc    =%ran(1.0)
        compute betau   =sxx*ranc*tr(p)
        * Use static forecasts over the period for historical decomposition to get the
        * residuals. Use dynamic forecasts over the same period to get the base forecast
        * series for the historical decomposition.
        forecast(model=varmodel,from=hstart,to=hend,results=onesteps,errors=u,static)
        forecast(model=varmodel,from=hstart,to=hend,results=base)
        * This is changed to unit shocks rather than orthogonalized shocks.
        impulse(noprint,model=varmodel,decomp=p,results=impulses,steps=nstep)
        gset irfsquared 1 1     = %xt(impulses,t).^2
        * Do the subdraws over the unit sphere. These give the weights on the
        * orthogonal components.
        do subdraws=1,n2
        * First Set of Restrictions - Unique Impulse Vector
           compute v1=%ransphere(6)
           compute i1=p*v1
           compute i1=i1/i1(3)
           do k=1,KMAX+1
               compute ik=%xt(impulses,k)*v1
               if ik(2)>0.or.ik(1)>0.or.ik(3)<0.or.ik(4)>0
                  branch 105
           end do k
           * Meets the first restriction
           * Draw from the orthogonal complement of i1 (last five columns of the
           * factor "f").
           compute v2=%ransphere(5)
           compute i2=%xsubmat(f,1,6,2,6)*v2
           compute v2=inv(p)*i2
           *  Second Set of Restrictions - Demand Shock
           do k=1,KMAX+1
              compute ik=%xt(impulses,k)*v2
              if ik(2)<0.or.ik(1)<0.or.ik(3)<0.or.ik(4)<0
                 branch 105
           end do k
           * Meets both restrictions
           compute accept=accept+1
           dim goodrespa(accept)(nstep,nvar) goodfevda(accept)(nstep,nvar)
           dim goodresp(accept)(nstep,nvar) goodfevd(accept)(nstep,nvar)
           ewise goodresp(accept)(i,j)=(ik=%xt(impulses,i)*v1),ik(j)
           ewise goodfevd(accept)(i,j)=(ik=(irfsquared(i)*(v1.^2))./(irfsquared(i)*ones)),ik(j)
           ewise goodrespa(accept)(i,j)=(ik=%xt(impulses,i)*v2),ik(j)
           ewise goodfevda(accept)(i,j)=(ik=(irfsquared(i)*(v2.^2))./(irfsquared(i)*ones)),ik(j)
          * Compute the historical paths of shocks to the system corresponding to the
          * <<a>> weights on the Choleski factor.
          dim goodhist(accept)(nhor,nvar) goodhista(accept)(nhor,nvar)
          compute remap=p*v1*tr(v1)*inv(p)
          do t=hstart,hend
             compute %pt(upaths,t,remap*%xt(u,t))
          end do t
          compute remap=p*v2*tr(v2)*inv(p)
          do t=hstart,hend
             compute %pt(upathsa,t,remap*%xt(u,t))
          end do t
          * Forecast over the decomposition period with those added shocks
          forecast(model=varmodel,from=hstart,to=hend,results=baseplus,paths)
          # upaths
          forecast(model=varmodel,from=hstart,to=hend,results=baseplusa,paths)
          # upathsa
          * Save the difference between the forecasts with and without and added shocks
          * (and shift them into the slots 1,...,nhor) of <<goodhist>>.
          ewise goodhist(accept)(i,j)=baseplus(j)(i+hstart-1)-base(j)(i+hstart-1)
          ewise goodhista(accept)(i,j)=baseplusa(j)(i+hstart-1)-base(j)(i+hstart-1)
           if accept>=1000
              break
        :105
        end do subdraws
        if accept>=1000
           break
        infobox(current=draws)
    end do draws
    infobox(action=remove)
    * Post-processing. Graph the mean of the responses along with the 16% and 84%-iles
    clear upper lower resp
    spgraph(vfields=6,hfields=2,subhea='Monetary Policy Shocks and Exchange Rate Shocks, Thailand')
    do i=1,nvar
        compute minlower=maxupper=0.0
        smpl 1 accept
        do k=1,nstep
           set work = goodresp(t)(k,i)
           compute lower(k)=frac(1)
           compute upper(k)=frac(2)
           compute resp(k)=%avg(work)
        end do k
        smpl 1 nstep
        graph(pattern,ticks,number=0,picture='##.##',header=+vl(i)) 3
        # resp
        # upper / 2
        # lower / 2
    do i=1,nvar
        smpl 1 accept
        do k=1,nstep
           set work = goodrespa(t)(k,i)
        end do k
        smpl 1 nstep
        # resp
        # upper / 2
        # lower / 2
    smpl
    spgraph(vfields=3,hfields=2,hlabel='Fraction of Variance Explained with Pure-Sign Approach',subhea='Subhea')
    do i=1,nvar
        smpl 1 accept
        do k=1,nstep
           set work = goodfevd(t)(k,i)
           compute frac=%fractiles(work,||.16,.50,.84||)
           compute upper(k)=frac(3)
           compute resp(k)=frac(2)
        end do k
        smpl 1 nstep
        graph(pattern,ticks,number=0,min=0.0,picture="##.##",header="Fraction Explained for "+vl(i)) 3
        # resp
        # upper / 2
        # lower / 2
    smpl
    spgraph(vfields=3,hfields=2,hlabel='SECOND Fraction of Variance Explained with Pure-Sign Approach',subhea='Subhea')
    do i=1,nvar
        smpl 1 accept
        do k=1,nstep
           set work = goodfevda(t)(k,i)
        end do k
        smpl 1 nstep
        # resp
        # upper / 2
        # lower / 2
    smpl
    declare series upperH lowerH respH
    spgraph(vfields=3,hfields=2,hlabel="Figure 4. Historical Decomposition with Pure-Sign Approach")
    do i=1,nvar
       smpl 1 accept
          clear upperH lowerH respH
          do k=hstart,hend
             set work 1 accept = goodhist(t)(k-hstart+1,i)
             compute lowerH(k)=frac(1)
             compute upperH(k)=frac(3)
             compute respH(k)=frac(2)
             display respH(k)
          end do k
    *      compute maxupper=%max(maxupper,%maxvalue(upper))  ,min=minlower,max=maxupper
    *      compute minlower=%min(minlower,%minvalue(lower))
       display 'contributions to variable' +vl(i)
       do h=1,nhor
          display respH(h)
       end do h
       smpl hstart hend
       graph(pattern,ticks,dates,picture="##.##",header="Contribution of Monetary Policy Shocks to "+vl(i)) 3
       # respH hstart hend
       # upperH / 2
       # lowerH / 2
    smpl
    spgraph(vfields=3,hfields=2,hlabel="Figure 5. Historical Decomposition with Pure-Sign Approach")
    do i=1,nvar
       smpl 1 accept
          do k=hstart,hend
             set work 1 accept = goodhista(t)(k-hstart+1,i)
             display respH(k)
          end do k
       do h=1,nhor
          display respH(h)
       end do h
       smpl hstart hend
       graph(pattern,ticks,dates,picture="##.##",header="Contribution of Exchange Rate Shocks to "+vl(i)) 3
       # respH hstart hend
       # upperH / 2
       # lowerH / 2
Posted: Tue Sep 08, 2009 11:23 am
Since i1 is never declared, it's created as a n x 1 rectangular. If you add
declare vector i1 i2 i3
before starting the loop, it should work.
Posted: Wed Sep 09, 2009 10:25 am
by TL
I am sorry to ask you again. I have added the following code
and
compute i1=i1/i1(3)
However, the impulse response acquired does not show that the 3rd variable is hit by the 1st shock with size one. In particular, the impulse response acquired is not different from one acquired from the original code not having those two lines.
I attach you the code added those two lines.
Sincerely,
Tim
Posted: Wed Sep 09, 2009 1:17 pm
You need to pay careful attention to the difference between the v vectors, which are in rotated space, and the i vectors, which are in standard variable space. Rescaling the i vector gives you the correct loadings, but you're then using (later on) the v vector to get the impulse responses. If you change i, but not v, you get, not surprisingly, the same results as if you didn't change i. You need your weights on the impulse responses to be
inv(p)*i1, not v1. (You don't want to change v1 itself since you need the unscaled version to get the FEVD).
Posted: Thu Sep 10, 2009 11:30 am
by TL
Thank you very much for your help. I really appreciate your help.
I have changed the following code
to
compute ik=%xt(impulses,k)*inv(p)*i1
and changed the following code
to
ewise goodresp(accept)(i,j)=(ik=%xt(impulses,i)*inv(p)*i1),ik(j)
The impulse response acquired does show that the 3rd variable is hit by the 1st shock with size one. However, it seems that the dashed lines representing the 16 percent and 84 percent quantiles of the posterior distribution of impulse responses are unscaled. I am not sure if it has something to do with the spgraph section.
I attach you the code changed as above.
Sincerely,
Tim
Posted: Thu Sep 10, 2009 12:19 pm
That looks correct. Why would you think the bounds are for unscaled responses?
Posted: Fri Sep 11, 2009 7:21 am
by TL
I am asking this because I see literature normalizing the impulse response to increase the variable by one and also showing probability bands corresponding to such normalized responses.
Nevertheless, it is fine if we would not have scaled bounds following scaled impulse responses.
I would like to thank you very much for all your help and suggestions. I really appreciate your kindness.
Thank you very much.
Sincerely,
Tim
Posted: Fri Sep 11, 2009 9:29 am
I'm confused. I just ran your program and it gives perfectly reasonable-looking bands. Why do you think it's wrong?
Posted: Sat Sep 12, 2009 6:50 am
by TL
It is my mistake.
I have run my program again and, as you said, it gives perfectly reasonable-looking bands.
I am sorry for this.
Thank you very much for all your help and suggestions. I really appreciate your kindness.
Sincerely,
Tim :D
Posted: Wed Oct 07, 2009 11:26 am
by bearlotus
Dear Tom:
I am following the sign restriction code of identifying multiple shocks simultaneously. But as you can see from the attached code and data, it works well for identifying two shocks, but does not work when I want to identify three shocks. I am wondering if there is something wrong with the restrictions I impose or some other things not work properly?
Has anyone who want to identify more than two shocks meet this kind of problem?
Also, it seems it matters as to which shock is first identified. If so, is there any rule about what kind of shocks should be identified first?
I would appreciate any advice from you. Thanks a lot!
Lian
Posted: Wed Oct 07, 2009 1:21 pm
anlian wrote:Dear Tom:
Lian
It looks as if you're not doing anywhere near enough subdraws. You have to remember that this is blindly picking directions in 7-space. If you're lucky, you'll get a draw which meets your first criterion about 10% of the time. With n2=500, that means that you have only about 50 shots at picking the other two directions. Try something more like n2=5000 or n2=10000. The subdraws don't take that long.
Posted: Wed Oct 07, 2009 1:41 pm
by bearlotus
[/quote] It looks as if you're not doing anywhere near enough subdraws. You have to remember that this is blindly picking directions in 7-space. If you're lucky, you'll get a draw which meets your first criterion about 10% of the time. With n2=500, that means that you have only about 50 shots at picking the other two directions. Try something more like n2=5000 or n2=10000. The subdraws don't take that long.[/quote]
Dear Tom:
I dodn't think the problem is the number of subdraws, I tried n2=500000, but it quickly gives me the error message:
## MAT13. Store into Out-of-Range Matrix or Series Element
The Error Occurred At Location 0151 of %SVDZEROS
Line 14 of %SVDZEROS
Line 47 of FORCEDFACTOR
Line 45 of loop/block
So does it mean the program can only work for identifying two shocks? Also it seems if I reverse the order of the two shocks that is identified, the results will differ. Would you please explain why this will happen?
Thank you so much for your helps,
Lian
Posted: Wed Oct 07, 2009 4:17 pm
Doing (potentially) millions of singular value decompositions revealed a minor problem in the %SVDECOMP function. The attached revision to the forcedfactor procedure will take care of that. You might also want to look at Todd Clark's code for doing the Rubio-Waggoner-Zha approach.
forcedfactor.src
(4.97 KiB) Downloaded 1229 times
Posted: Thu Oct 08, 2009 8:13 am
by bearlotus
Dear Tom:
Thank you very much! It is great help!
Lian
TomDoan wrote:Doing (potentially) millions of singular value decompositions revealed a minor problem in the %SVDECOMP function. The attached revision to the forcedfactor procedure will take care of that. You might also want to look at Todd Clark's code for doing the Rubio-Waggoner-Zha approach.
forcedfactor.src
