Thanks for response Tom. In my case, however, I have a little bit different situation. I have a full sample of 1287 days. I use 511 days as a sample period to estimate AR(1)-GARCH(1,1) coefficients. After that I
roll the regressions with moving window of 511 to obtain AR(1)-GARCH(1,1) coefficients for the following 777 days (forecasting period).
Here is the code for what I've done so far:
OPEN DATA "C:\Documents and Settings\admin\Desktop\teze.RAT"
CALENDAR(D) 2006:1:3
DATA(FORMAT=RATS) 2006:01:03 2010:12:08 RT
smpl 2 511
garch(p=1,q=1,reg,resids=u,hseries=h) / rt
# constant rt{1}
***Testing standardized residuals
set ustd = u/sqrt(h)
set ustdsq = ustd^2
correlate(qstat,number=40,dfc=1,title="LB Test") ustd
correlate(qstat,number=40,dfc=2,title="McLeod-Li Test") ustdsq
stats ustd
***Rolling GARCH
compute width=511
dec vect[series] coeffs(5)
do gend=width,1287
if gend==width
garch(p=1,q=1,reg,resids=u,hseries=h,noprint) gend-width+2 gend rt
# constant rt{1}
else
garch(p=1,q=1,reg,resids=u,hseries=h,initial=%beta,hessian=%xx,noprint) gend-width+2 gend rt
# constant rt{1}
compute %pt(coeffs,gend,%beta)
end do gend
After that, according to the reference you gave, I should have the following:
* GARCH with normal residuals
garch(p=1,q=1,equation=ar1,hseries=h,resids=u)
* Forecast the variance using @GARCHFORE and the series itself using
* UFORECAST.
@garchfore(steps=777) h u
uforecast(equation=ar1,steps=777) fret
* Use SSTATS to accumulate the mean and variance over the forecast period.
sstats 512 1287 fret>>ret1 h>>ret1h
disp "5% VaR, 1 day horizon on 10000000" -10000000*(ret1+%invnormal(.05)*sqrt(ret1h))
Does it make sense?
Contrary to that I have found one code from my professor, which is not complete though. Thus I cannot follow it properly. It's completely different from Tsay code and that confuses me.
Here it is:
nonlin(parmset=garchparms) vc=.1 va=.84 vb=.14
frml resid = x1
frml hf = vc + va*h{1} + vb*u{1}**2
frml logl = (h(t)=%ovcheck(hf(t))),(u(t)=resid(t)),-.5*(log(h)+u**2/h)
linreg(noprint) x1 / u
# constant
compute vc=.5,va=.7,vb=.2
set h = %seesq
maximize(parmset=garchparms,method=bfgs,robusterrors,iters=10,noprint) logl gstart gend
set ce = u/sqrt(h)
order ce secondt lastt
compute perc1=secondt+40
compute perc5=secondt+200
compute perc95=secondt+3800
compute perc99=secondt+3960
compute s_cband1=ce(perc1)
compute s_cband5=ce(perc5)
compute s_cband95=ce(perc95)
compute s_cband99=ce(perc99)
do tim0=4000,7999
compute tim1=tim0+1
compute ht(4000)=h(4000)
compute ut(tim0)=x1(tim0)
compute ht(tim1)= vc + va*ht(tim0) + vb*ut(tim0)**2
compute obser5=s_cband5*sqrt(ht(tim1))
compute obser95=s_cband95*sqrt(ht(tim1))
compute obser1=s_cband1*sqrt(ht(tim1))
compute obser99=s_cband99*sqrt(ht(tim1))
compute s_cp5(tim1)=obser5
compute s_cp95(tim1)=obser95
compute s_cp1(tim1)=obser1
compute s_cp99(tim1)=obser99
compute n_vio(tim1)=%if(s_cp5(tim1)<=x1(tim1).and.x1(tim1)<=s_cp95(tim1),0,1)
if n_vio(tim1)=1.and.x1(tim1)<s_cp5(tim1)
compute d_vio=s_cp5(tim1)-x1(tim1)
else if n_vio(tim1)=1.and.x1(tim1)>s_cp95(tim1)
compute d_vio=x1(tim1)-s_cp95(tim1)
else
compute d_vio=%NA
compute cdeg_vio(tim1)=d_vio
if n_vio(tim1)=1.and.x1(tim1)<s_cp5(tim1) {
compute l_vio=s_cp5(tim1)-x1(tim1),u_vio=%NA
else if n_vio(tim1)=1.and.x1(tim1)>s_cp95(tim1) {
compute u_vio=x1(tim1)-s_cp95(tim1),l_vio=%NA
else {
compute u_vio=%NA,l_vio=%NA
compute l_cdeg_vio(tim1)=l_vio,u_cdeg_vio(tim1)=u_vio
if l_cdeg_vio(tim0)!=%NA.and.l_cdeg_vio(tim1)!=%NA
compute lc_consec(tim1)=1
else
compute lc_consec(tim1)=%NA
if u_cdeg_vio(tim0)!=%NA.and.u_cdeg_vio(tim1)!=%NA
compute uc_consec(tim1)=1
else
compute uc_consec(tim1)=%NA
compute zn_vio(tim1)=%if(s_cp1(tim1)<=x1(tim1).and.x1(tim1)<=s_cp99(tim1),0,1)
if zn_vio(tim1)=1.and.x1(tim1)<s_cp1(tim1)
compute d_vio=s_cp1(tim1)-x1(tim1)
else if zn_vio(tim1)=1.and.x1(tim1)>s_cp99(tim1)
compute d_vio=x1(tim1)-s_cp99(tim1)
else
compute d_vio=%NA
compute czdeg_vio(tim1)=d_vio
if zn_vio(tim1)=1.and.x1(tim1)<s_cp1(tim1) {
compute zl_vio=s_cp1(tim1)-x1(tim1),zu_vio=%NA
else if zn_vio(tim1)=1.and.x1(tim1)>s_cp99(tim1) {
compute zu_vio=x1(tim1)-s_cp99(tim1),zl_vio=%NA
else {
compute zu_vio=%NA,zl_vio=%NA
compute zl_cdeg_vio(tim1)=zl_vio,zu_cdeg_vio(tim1)=zu_vio
end do tim0
statistics(noprint) ht 4001 8000
compute c_var(k)=sqrt(%variance),c_mvar(k)=%mean
statistics(noprint) s_cp1 4001 8000
compute c_var1(k)= %mean
statistics(noprint) s_cp5 4001 8000
compute c_var5(k)= %mean
statistics(noprint) s_cp95 4001 8000
compute c_var95(k)=%mean
statistics(noprint) s_cp99 4001 8000
compute c_var99(k)=%mean
statistics(noprint) lc_consec 4001 8000
compute nlc_consec(k)=%nobs
statistics(noprint) uc_consec 4001 8000
compute nuc_consec(k)=%nobs
statistics(noprint) czdeg_vio 4001 8000
compute czc_vio(k)=%nobs
compute czt_deg_vio(k)=%mean
statistics(noprint) zl_cdeg_vio 4001 8000
compute zlcc_vio(k)=%nobs
compute zlct_deg_vio(k)=%mean
statistics(noprint) zu_cdeg_vio 4001 8000
compute zucc_vio(k)=%nobs
compute zuct_deg_vio(k)=%mean
statistics(noprint) cdeg_vio 4001 8000
compute cc_vio(k)=%nobs
compute ct_deg_vio(k)=%mean
statistics(noprint) l_cdeg_vio 4001 8000
compute lcc_vio(k)=%nobs
compute lct_deg_vio(k)=%mean
statistics(noprint) u_cdeg_vio 4001 8000
compute ucc_vio(k)=%nobs
compute uct_deg_vio(k)=%mean
compute ccoff0(k)=vc,ccoff1(k)=va, ccoff2(k)=vb
compute cband5(k)=s_cband5,cband95(k)=s_cband95,cband1(k)=s_cband1,cband99(k)=s_cband99
