Den Haan JME(2000)
Posted: Tue Jul 05, 2011 11:59 am
This is a replication for Wouter J. den Haan(2000), "The comovement between output and prices,"
Journal of Monetary Economics, vol 46, no 1, 3-30, which analyzes the comovement of series using multi-step forecast errors in a VAR.
- bmfor4.rpf
- Program for monthly model
- (5.02 KiB) Downloaded 1722 times
- month1.txt
- Monthly data file
- (100.54 KiB) Downloaded 1615 times
- bqfor.rpf
- Program for quarterly model
- (4.9 KiB) Downloaded 1660 times
Re: Den Haan JME(2000)
Posted: Fri Apr 27, 2012 9:30 am
by mskare69
I'd like to replicate den Haan 2000 figures and tables but with the last code (2011) I get just one final graph named figure2a. How can I get other figures from the Haan paper (what changes in the code I need?)
Fondly,
Marinko
Posted: Fri May 06, 2016 3:01 pm
by luching
I would like to check the interpretation of the correlations calculated by this routine. I think the correlations only refer to contemporaneous correlations at different horizons. But they don't/can't reflect lead-lag correlations between the variables. If I want to calculate lead correlations (i.e. correlation of x today with y tomorrow), can I do so by computing the correlation between the forecast error of x at time t and that of y at time t+1? Any hint will be of great help.
Posted: Fri May 06, 2016 5:59 pm
You would just need to change the # ... in this to reflect different values of J (which are the number of forecast steps). Note that you lose a possible "J" value when mismatch the horizons.
do j=1,ncov
cmom(corr,center) startl endl
# gdperrors(j) perrors(j)
compute corrs(j)=%cmom(1,2)
Posted: Fri Jul 15, 2016 10:42 am
by luching
Hi Tom, I am now trying to loop this for many models. I took the procedure outside of the VAR model specification, tried various things (local/global etc.). But I keep getting this message. Could you please help?
## CP17. PROCEDURE/FUNCTION Must be Initial Statement in a Compiled Section
>>>>procedure <<<<
## OP3. This Instruction Does Not Have An Option
>>>>procedure <<<<
Posted: Fri Jul 15, 2016 10:48 am
I can guess that you have an unclosed DO loop before the procedure, but I can't tell without seeing the entire program.
Posted: Fri Jul 15, 2016 10:57 am
by luching
Thanks Tom. The code is attached. For now, I am simply asking the code to estimate the same model twice. I will eventually look this over different models.
* Replication of Wouter J. den Haan(2000), "The comovement between
* output and prices," Journal of Monetary Economics, vol 46, no 1, 3-30.
* Quarterly data, multivariate VAR.
* Program to estimate a VAR, and calculate K-step ahead within sample
* forecasts, and their correlations. This imposes a unit-root and
* estimates the VAR in first-differences, but calculates the errors for
* the levels. It includes bootstrapped standard errors.
* Revision Schedule:
* Based upon version written by Wouter den Haan and posted on his web site.
* March 2010. Revised by Tom Doan, Estima
* a. Switched to use MODEL data type
* b. Changed loop control to do just a single FORECAST for
* each evaluation.
* c. Wrote procedure to calculate the correlation statistics
* for a given model
open data C:\Correlations\USA.xlsx
calendar(q) 1950
data(format=xlsx,org=columns) 1950:01 2015:01 loggdp bcon
set lgdp2 = loggdp
set bcon2 = bcon
set trend = t
set trend2 = t*t
*set lgdp = lgdp2 - lgdp2{1}
*set bcon = bcon2 - bcon2{1}
*set lgdp = lgdp2
set bcon = bcon2
filter(type=hp, tuning=1600) lgdp2 / temp
set lgdp = lgdp2-temp
*seed 112597
compute sss = 1998:1
compute eee = 2015:1
compute ncov = 60
compute nboot = 500 ;* 2500
compute nlags = 4
* This is specific to a model estimated in first differences
* where the variables of interest are the first two.
procedure ForecastCorrs start end
option model model
option integer ncov 50 ;* Number of forecast steps
option vector *corrs
local integer startl endl
local integer time j
local vect[series] forecasts
local vect[series] gdperrors
local vect[series] perrors
local series actualy
local series actualp
* Assume to evaluate over the full regression range unless
* the user overrides.
if %defined(start)
compute startl=start
else
compute startl=%regstart()
if %defined(end)
compute endl=end
else
compute endl=%regend()
dim gdperrors(ncov) perrors(ncov) corrs(ncov)
do j=1,ncov
set gdperrors(j) startl endl = %na
set perrors(j) startl endl = %na
set actualy startl endl = %modeldepvars(model)(1){0}
set actualp startl endl = %modeldepvars(model)(2){0}
do time=startl,endl
forecast(model=model,from=time,to=time+ncov-1,results=forecasts)
* Replace forecasts of (changes) in y and p with their forecast
* errors. Then accumulate up to get the errors in log y and log p
* themselves.
set forecasts(1) time time+ncov-1 = actualy-forecasts(1)
set forecasts(2) time time+ncov-1 = actualp-forecasts(2)
*acc forecasts(1) time time+ncov-1
*acc forecasts(2) time time+ncov-1
* Record forecast errors only for the ones with actual data
do j=1,ncov
if time+j-1>%regend()
break
compute gdperrors(j)(time) = forecasts(1)(time+j-1)
compute perrors(j)(time) = forecasts(2)(time+j-1)
end do time
* Compute correlations for each forecast step
do j=1,ncov
* Estimate base model on actual data. GNP, P and DR are in differenced form.
do ser = 1,2
system(model=base)
variables lgdp bcon
lags 1 to nlags
det constant trend
estimate(noftests,noprint,resids=resids) sss eee
* Evaluate the forecast correlations at the base model
@ForecastCorrs(model=base,corrs=basecorr)
*@ForecastCorrs(model=base,corrs=basecorr) 1960:3 *
@VARBootSetup(model=base) bootvar
dec series[vect] bootcorr
gset bootcorr 1 nboot = %zeros(ncov,1)
* Redefine the boostrap system to get the deterministic variables right
system(model=bootvar)
variables %%VARResample
lags 1 to nlags
det constant trend
infobox(action=define,lower=1,upper=nboot,progress) "Bootstrapping"
do boot = 1,nboot
infobox(current=boot)
* Draw the new data
@VARBootDraw(model=base,resids=resids) sss eee
* @VARBootDraw(model=base,resids=resids) %regstart() %regend()
* Estimate the VAR on the bootstrapped data
estimate(model=bootvar,noprint) sss eee
@ForecastCorrs(model=bootvar,corrs=bootcorr(boot),ncov=ncov)
end do boot
infobox(action=remove)
* For each forecast horizon, compute the percentage with the same sign as
* the base correlations.
dec vect samesign(ncov)
do i=1,ncov
sstats(mean) 1 nboot (bootcorr(t)(i)>0.xor.basecorr(i)<0)>>samesign(i)
set c05 1 ncov = %if(samesign(t)>.95,basecorr(t),%na)
set c10 1 ncov = %if(samesign(t)>.90.and.samesign(t)<=.95,basecorr(t),%na)
set c00 1 ncov = %if(samesign(t)<=.90,basecorr(t),%na)
graph(nodates,style=bargraph,$
footer="Figure 3A Quarterly data with unit root imposed") 3
# c05 1 ncov
# c10 1 ncov
# c00 1 ncov
end do ser
Posted: Fri Jul 15, 2016 11:35 am
You need to put a source for the varbootsetup.src file outside the loop. It pulls in multiple procedures, so it can't be included implicitly.
Posted: Fri Jul 15, 2016 12:34 pm
by luching
Thanks much, Tom. It works now.
Posted: Wed Jul 26, 2023 11:43 am
by edolson1983
Am I correct that the recent
"Datta, Deepa D., Benjamin K. Johannsen, Hannah Kwon, and Robert J. Vigfusson. 2021. "Oil, Equities, and the Zero Lower Bound." American Economic Journal: Macroeconomics, 13 (2): 214-53"
in their online appendix ([
https://www.aeaweb.org/articles?id=10.1257/mac.20180488]) where they decompose shocks to the correlation using Variance decompositions are essentially doing the same thing as the Haan (2000) paper referenced in this thread?
