Panel error-correction model using Arellano-Bond GMM
Posted: Mon Aug 15, 2011 2:53 am
since I would like to estimate a dynamic panel error-correction model with lagged dependend variables, I used arellano.rpf listed in RATS Procedures and Examples. Furthermore, I applied the procedure ABLags to create more appropriate instruments:
I got the following output:
Why appears this error message? Using levels instead of differences as instruments
even leads to
and
By the way, what's the meaning of the J-specification? And how are the Skipped/Missing values calculated?
Thanks a lot in advance for your help!
Frauke
cal(panelobs=30,a) 1978
all 25//2007:1
open data ecm_e.xls
data(org=columns,format=xls) 1//1978:1 25//2007:1 e y ect
@ABLags de abe 1982:1 2007:1
@ABLags dy aby 1982:1 2007:1
instrument abe aby
linreg(title="Arellano-Bond",instruments,optimalweights,lwindow=panel) de
# de{1} dy{1} ect{1}
## REG10. First 1 Instruments Are Linearly Dependent Over Regression Range
Linear Regression - Estimation by Arellano-Bond
Dependent Variable DE
Panel(30) of Annual Data From 1//1979:01 To 25//2007:01
Usable Observations 700 Degrees of Freedom 697
Total Observations 749 Skipped/Missing 49
Mean of Dependent Variable 0.0048527319
Std Error of Dependent Variable 0.0377267319
Standard Error of Estimate 0.0321541828
Sum of Squared Residuals 0.7206223578
J-Specification(526) 28442.182007
Significance Level of J 0.00000000
Durbin-Watson Statistic 1.937421
1. DE{1} 0.314689636 0.029855723 10.54035 0.00000000
2. DY{1} 0.209647179 0.015282492 13.71813 0.00000000
3. ECT{1} -0.459251404 0.022413273 -20.49015 0.00000000
@ABLags e abe 1982:1 2007:1
@ABLags y aby 1982:1 2007:1
## REG10. First 27 Instruments Are Linearly Dependent Over Regression RangeCode: Select all
Significance Level of J 1.00000000Thanks a lot in advance for your help!
Frauke
