PANELTHRESH—Testing for threshold in FE estimates
Posted: Mon Sep 12, 2011 3:47 pm
This tests a fixed effects regression for one or two breaks in a single regressor, with breaks determined by the values of another variable. This is from Bruce Hansen(1999), "Threshold effects in non dynamic panels: estimation, testing and inference" Journal of Econometrics, vol 93, pp 345-368.
The regression (with two breaks) takes the form:
y(i,t)=a(i)+x(t,i)b+z(t,i)*(q(t,i)<=gamma1)+z(t,i)*(q(t,i)<=gamma2)
This requires a separate fixed effects regression for each test setting for the break values. If q is a continuous variable, a complete search over all possible values in a panel data set could be very time consuming. As a result, you can examine a reduced number of quantiles of the values of q. It also only does an exhaustive search for the first break, then examines the second break given the first.
An example (from the original paper) is provided at http://www.estima.com/forum/viewtopic.php?f=8&t=1195.
panelthresh.src
Detailed description
panelthresh.src
