Bootstrapped Confidence Intervals VECM
Posted: Fri Sep 16, 2011 10:27 am
by cecedi
Dear all,
I try to modify the replication WinRATS codes of King et al (1991)'s article.
With regard to the "Error Decomposition of Variance", my question is how to compute the bootstrapped 95-percent confidence intervals for the results in the last step = 48 (or generally, for each step if possible).
This is my codes and my data:
calendar(q) 1975:1
allocate 2010:4
open data USA_data.xls
data(format=xls,org=cols)
print /
log M0reel / lM0reel
set creditreel = credit/cpi*100
log creditreel / Lcreditreel
set istockreel = istock/cpi*100
log istockreel / Listockreel
set ihousereel = ihouse/cpi*100
log ihousereel / Lihousereel
* Define the error correction equations
equation(coeffs=|| -0.905,      -0.062,     0.036,      1.000,  -0.714||) coint
#  LREVENUREPH LISTOCKREEL LIHOUSEREEL LCONSOMREPH CONSTANT
* Define the atilde matrix
compute atilde=$
||1.0  ,0.0  ,0.0|$
  0.0  ,1.0  ,0.0|$
  0.0  ,0.0  ,1.0|$
  0.905,0.062,-0.036||
* Lag Select
@varlagselect(lags=6,crit=sbc)
# Lrevenureph Listockreel Lihousereel Lconsomreph
@varlagselect(lags=6,crit=aic)
@varlagselect(lags=6,crit=hq)
* Estimate the cointegrated VAR
system(model=vecms)
variables Lrevenureph Listockreel Lihousereel Lconsomreph
lags 1 to 2
ect coint
estimate(noprint)
* Get the long run response matrix
impulse(model=vecms,factor=%identity(4),results=baseimp,steps=200,noprint)
compute lrsum=%xt(baseimp,200)
* Compute a factor
compute d=%ginv(atilde)*lrsum
@forcedfactor(force=rows) %sigma d f
* Error decomposition (table 5)
errors(decomp=f,model=vecms,steps=48,$
   labels=||"Permanent 1","Permanent 2","Permanent 3","Transitoire"||)
You will find herewith my data
Best regards
Re: Bootstrapped Confidence Intervals VECM
Posted: Wed Sep 21, 2011 5:33 pm
BOOTVECM.RPF will do a bootstrapping analog to the KPSW4.RPF program file which does error bands in a VECM using Monte Carlo integration (rather than bootstrapping).
Posted: Fri Oct 14, 2011 10:24 am
by cecedi
Thanks Tom Doan for your help,
However, my need is to compute the error band (confidence intervals) of Error Decomposition of Variance derived from the Instruction "Errors".
I do here my bootstrapped (relying on Bootvar.rpf program file) to compute the confidence intervals of Error Decomposition of Variance (for the last step). I post here my WinRATS codes and my data.
I have 4 variables in the system. There are 3 permanent shocks corresponding Upper and Lower (1, 2, 3); and 1 transitory shock corresponding Upper and Lower (4). Because I have to make the sum of the 3 permanent shocks in only one that represents the permanent components, so I have to make the sum = Upper 1 + Upper 2 + Upper 3 ; and the problem is that this sum exceeds to 1.
Is it normal ? Can I present the confidence interval Upper exceeding to 1 in my paper? If not, what is the solution for this problem?
Many thanks
Best regards
Posted: Fri Oct 14, 2011 11:51 am
Conventional "standard error" bands aren't a good idea for the error decomposition. The error decompositions are very asymmetrical, particularly near the boundaries---standard error bands are appropriate only when a distribution is at least approximately normal. Instead, use bootstrap quantiles as your measure. Note, by the way, that the point estimates can often be outside even fairly wide confidence bands. For instance, if the point estimate of an impulse response is near zero, the point estimate of the variance share will be near zero as well. The draws for the responses will generally be at least somewhat non-zero, leading to small, but positive variance shares. This type of behavior for bootstrapping and Monte Carlo with highly non-linear functions is described in Sims and Zha(1999), "Error Bands for Impulse Responses", Econometrica, vol 67, no. 5, pp 1113-1156.
Posted: Thu Aug 21, 2014 6:37 am
by shimarats
hi,dear tom
i want show me bootstrapped confidence intervals svar model. i run svar model after that i need to impulse responses with confidence intervals .please give code of bootstrapped confidence intervals in svar model.thanks so much .
Posted: Thu Aug 21, 2014 9:57 am
shimarats wrote:hi,dear tom
The advantage of bootstrapping is that you can use the same basic bootstrap for structural as well as conventional VAR's. Just adapt BOOTVAR.RPF to your model and re-estimate the structural part inside the draw loop. (Note that this thread is about bootstrapping a VECM, so it's more complicated than a straight VAR).
