bjautofit
Posted: Fri Oct 28, 2011 9:41 pm
by lnw
I notice that in bjautofit AIC=-2ln+2*(p+q) but I thought it would have intercept in some cases, then %nreg would be better?
Otherwise sometimes, the manual calculated AIC may not match those from bjautofit.
Re: bjautofit
Posted: Sat Oct 29, 2011 9:50 am
lnw wrote:I notice that in bjautofit AIC=-2ln+2*(p+q) but I thought it would have intercept in some cases, then %nreg would be better?
For comparing models, you don't need to include parameters that are common to all. For instance, most descriptions of AIC for a regression model (or ARMA model) don't count the variance even though it is also an estimated parameter. However, if you compare a regression with homoscedastic errors with the same regression model with ARCH errors, you would want to include the variance in the count for the first regression to compare the two.
