The estimation of SVAR
Posted: Mon Oct 31, 2011 7:28 pm
Hi there!
I found that sometimes different coefficient estimates are obtained when using cvmodel instruction to estimate the non-recursive SVAR. The situation is most troublesome particularly when I want to obtain the standard errors for those coefficient estimates which were obtained early by doing more piters in the preliminary estimation.
For example, in the output file attached, I estimate the model first by "cvmodel(parmset=kimroubi,pmethod=genetic,piters=1000,iters=2000,factor=afactor) vmat ab" and obtain the coefficient estimates which are closest to reasonableness. But when I reduce the number of piters to 100 in order to obtain the standard errors for those coefficent estimates, I found it's very hard to obtain the same coefficient estimates.
Could you please help me to solve this problem?
Code, data and output files are attached
Best Regards
Best Regards
