Impulse response function and decomposition
Posted: Mon Nov 28, 2011 6:17 am
I have used the engle-granger 2 step to get the residuals, test residuals for stationarity, then use the residuals to create a VECM. How do I create the IRF and decomposition takign into consideration that the ECM (T-1) also influence the dependent var? i tried using the impulse function but thought otherwise. do you know what is the calculation involved in tabulating the IRF and decomposition if i am to do it manually if i can't use it using any RATS procedure? (using cholesky, residuals with one unit/standard deviation or general response)
for example, the 1st response in the IRF table was WTI{1} + coefficient from ecm{1}. however, i was not able to derive the 2nd and subsequent figures....
is it possible to use @stampdiags on linear regressions, bai-perron and other equations which you recomended to diagnose the state space model?
how do I create the DW and hetereoscedasiticty tests to compare to @stampdiags? or vice versa?
also, how do i create the Yhat for fitted values after a linear regression?
apologies for asking such minor silly questions.
Thanks once again.
Rgds,
Des
Thanks once again.
Rgds,
Des
