Restriction with SUR model(AIDS case)
Posted: Fri Dec 16, 2011 10:10 am
by eigenjin
I am totally newbie in RATS, I have not much knowledge on RATS.
I am going to estimate the Almost Ideal demand system with SUR method.
to consistent with the economic theory, the demand system satisfied the symmetric and homogeneity condition
For example. in case we have a 4 equation such as
eq1 = const +1 p1 +2 p2 +3 p3 +4p4 + log(TE/P)
eq2 = const +5 p1 +6 p2 +7 p3 +8p4 + log(TE/P)
eq3 = const +9 p1 +10 p2 +11 p3 + 12p4 + log(TE/P)
(I deleted last equation to estimate)
restriction is that sum(1:4)=1 , sum(5:8), sum(9:12) : homogeneity
and 2=5, 3=9, 7=10 : symmetric condition
To do this, I set the equation
equation eq1 w1
# constant lp1 lp2 lp3 lp4 lTP
equation eq2 w2
equation eq3 w3
equation eq4 w4
sur(iterations=100) 3
# eq1
# eq2
# eq3
My question is following
I know the "equate" option in SUR model. I have read that reference manual.
It is not clear the description in the reference manual.
Can you explain more about how to impose the symmetric and homogeneity restriction on it?
Re: Restriction with SUR model(AIDS case)
Posted: Fri Dec 16, 2011 12:12 pm
You probably want to look at the CONSUMER.RPF example (page UG-141 in RATS v8) which uses NLSYSTEM rather than SUR. Even though the model itself is linear, it's easier to handle the constraints by using the non-linear setup.
Posted: Fri Dec 16, 2011 2:42 pm
by eigenjin
I appreciate your comments.
It is very helpful
