Different coefficient? what is the problems
Posted: Sun Jan 08, 2012 12:58 am
First of all, Thank you for your help.
Thanks to your help, I could solve the previous problem "Restriction with SUR model(AIDS case)" problems
It works well. It produce the same coefficient which I expected.
Actually, I replicate it using RATS written by different Statistical Software. (R-language)
I do similar thing in the "Rotterdam model", too.
using same data set, and same method, nonlinsystem,
I exactly follow the introduction in the CONSUMER.RPF example (page UG-141 in RATS v8)
But estimated parameters are different from the originals.
Some of them, has the similar values, but some of them are not.
According to the Original
the estimated parameters are satisfied the economic assumption on Rotteram
for example, for all p[i,i] has the negative value,
and the marginal expenditure share (theta) have all positive sign
but the estimated parameters from RATS has the different situation
1. one of the theta is "negative" this means that it is a inferior goods.
I know that the Rotterdam model assume that the all goods are normal...
the estimated value are violate this assumption.
2. one of the p[i,i] has the positive sign.
this mean that if I compute the estimated elasticity of this good, this good will has positive sign of own price elasticity.
It is of course weird....
I am not sure what is the problem of this situation.
first of all, I am sure the estimation method of both two are same..I have double checked..
It can be proved by the AIDS cases...it has the exactly same parameter values....
But, the Rotterdam case,,,has the different parameters from the original estimation.
but...parameters in Orignal case are more reasonable thatn...RATSs case..
Any suggestion?
or Can you give any information why this kinds of thing happens...?
Any suggestion?
