Properties of VAR Residuals
Posted: Sat May 19, 2012 10:32 am
by AhmedSahlool
I am searching for a procedure that tests the properties of VAR residuals; autocorrelation, normality, cross equations correlation.
I would like to use these properties to detremine the number of lags of the VAR model as I have a limited number of data.
Thank you
Re: Properties of VAR Residuals
Posted: Sat May 19, 2012 4:23 pm
AhmedSahlool wrote:Hi,
Thank you
@MVQSTAT does the multivariate Q test for autocorrelation (which includes both self and cross)
@MVJB does a multivariate Jarque-Bera test. Though I wouldn't recommend basing decisions about lag length on the J-B statistic, since adding lags does nothing directly to affect the normality of residuals.
Posted: Sun May 20, 2012 3:42 pm
by AhmedSahlool
The VAR that I estimate has non constant variances.
I read that the MVQSTAT is not consistent in this case, are there other alternatives?
Thank you
Posted: Sun May 20, 2012 5:22 pm
AhmedSahlool wrote:The VAR that I estimate has non constant variances.
Thank you
The West-Cho test will handle the autocorrelations. If you don't have much data, a generalization of that to a multivariate process would probably have rather bad properties.
