Skalin Terasvirta JAE 1999 (STAR models/Nonlinear Causality)
Posted: Thu May 31, 2012 2:49 pm
These are replication files for (part of) Skalin and Terasvirta(1999), "Another Look at Swedish Business Cycles, 1861-1988", Journal of Applied Econometrics, vol. 14, no 4, pp 359-78. They fit LSTAR or ESTAR models to long annual data for quite a few Swedish macro data series and do a "non-linear" causality test, testing the null that a second series doesn't enter into the STAR model (either linearly or through its own STAR effect). This only does a few of the series, but demonstrates the techniques required.
stjae1999.rpf
Estimation of STAR models
(5.25 KiB) Downloaded 1677 times
staje1999causal.rpf
Causality tests
(2.82 KiB) Downloaded 1520 times
st-data.dat
Data file
(31.98 KiB) Downloaded 1526 times
descript.pdf
Data dictionary
(12.09 KiB) Downloaded 1636 times
Re: Skalin Terasvirta JAE 1999 (STAR models/Nonlinear Causal
Posted: Mon Jun 24, 2013 11:13 am
by adrangi
Hi Tom. I used this procedure successfully. However, I'm perplexed by the inconsistency of the chi-squared values (too small) and almost zero P-values for all lag lengths in the final causality tests. The P-values don't match the Chi-sq values produced by the procedure. What am I missing? Thanks for any help. Bahram
Posted: Mon Jun 24, 2013 6:55 pm
adrangi wrote:Hi Tom. I used this procedure successfully. However, I'm perplexed by the inconsistency of the chi-squared values (too small) and almost zero P-values for all lag lengths in the final causality tests. The P-values don't match the Chi-sq values produced by the procedure. What am I missing? Thanks for any help. Bahram
Those are F's not chi-squares.
Posted: Thu Jun 27, 2013 7:02 pm
by adrangi
Thanks much. I see. So, restrictions are being tested. I'll review the program again. Thanks. Bahram
Posted: Fri Jun 28, 2013 10:07 am
adrangi wrote:Thanks much. I see. So, restrictions are being tested. I'll review the program again. Thanks. Bahram
Sure. It's doing a standard causality test, but on linearized products of lags of the tested variable and the threshold variable.
Posted: Sat Dec 23, 2017 9:27 pm
by adrangi
Hi Tom. I've used this procedure for nonlinear causality multiple times with success. However, tonight I'm getting error messages on the computation of ndf. I'm attaching that portion of the program and the error message. please have a look and maybe you can offer a solution. Thanks much. Enjoy the XMAS holidays. Best, BA
Posted: Mon Dec 25, 2017 7:55 am
It looks like you have a serious problem with your XTEST variable---offhand, it looks like it's constant. When you have a problem, the first thing to do is always to check the data (AFTER any transformations), and the second is to take the NOPRINT option off the regressions.
Posted: Mon Dec 25, 2017 9:53 pm
by adrangi
Hi. Thanks Tom. will check the data and take the noprint out. Best, BA
