Conducting a LB-Q test in a GARCH model using MAXIMIZE
Posted: Thu Jun 07, 2012 3:58 pm
by Masafumi
I am trying to estimate a multivariate GARCH model with restrictions using MAXIMIZE command.
Then I have been wondering how I can conduct a LB-Q test by applying the @bdindtests procedure to the model I estimated.
(This is my first time using RATS.)
I got some results from what I tried, but they do not seem correct.
Thus I would very much appreciate it if you could tell me how I can conduct @bdindtests in a model using MAXIMIZE.
I am pasting my program below.
Thank you so much in advance for your help, and I am eagerly awaiting your reply.
All the best,
Masafumi
_________________________________________________________________________
* Estimation using MAXIMIZE
* The initial few lines of this set the estimation range, which needs to be done
* explicitly, and the number of variables. Then, vectors for the dependent
* variables, residuals and residuals formulas are set up. The SET instructions
* copy the dependent variables over into the slots in the vector of series.
compute gstart=2000:01,gend=2011:12
compute n=3
dec vect[series] y(n) u(n)
dec vect[frml] resid(n)
set y(1) = R_ADV
set y(2) = R_EAC_K
set y(3) = R_KEN
* This is specific to a mean-only model. It sets up the formulas (the &i are
* needed in the formula definitions when the FRML is defined in a loop), and
* estimates them using NLSYSTEM. This both initializes the mean parameters, and
* computes the unconditional covariance matrix. If you want more general mean
* equations, the simplest way to do that would be to define each FRML separately.
dec vect b(n)
dec vect beta(n)
nonlin(parmset=meanparms) b beta
do i=1,n
   frml resid(i) = (y(&i)-b(&i)-beta(&i)*y(&i){1})
nlsystem(parmset=meanparms,resids=u) gstart gend resid
compute rr=%sigma
* The paths of the covariance matrices and uu' are saved in the SERIES[SYMM] names
* H and UU. UX and HX are used to pull in residuals and H matrices.
declare series[symm] h uu
declare symm hx(n,n)
declare vect ux(n)
gset h  * gend = rr
gset uu * gend = rr
* This is a standard (normal) log likelihood formula for any multivariate GARCH
* model. The difference among these will be in the definitions of HF and RESID.
* The function %XT pulls information out of a matrix of SERIES.
declare frml[symm] hf
frml logl = $
    hx = hf(t) , $
    %do(i,1,n,u(i)=resid(i)) , $
    ux = %xt(u,t), $
    h(t)=hx, uu(t)=%outerxx(ux), $
    %logdensity(hx,ux)
* Positive definite parameterization (BEKK,EK)
* This enforces a positive definite covariance matrix by writing the covariance
* matrix evolution as
*   V(t) = C'C + A'u(t)u(t)'A + B'V(t-1)B
* Note that the parameters are not globally identified: changing the signs of all
* members of C, A or B will have no effect on the function value. Using
* PMETHOD=SIMPLEX to begin is quite important with this setup, to pull the
* estimates away from zero before starting the derivative-based methods.
dec rect   var(n,n) vbr(n,n)
dec packed vcr(n,n)
nonlin(parmset=garchparms) vcr var vbr
nonlin(parmset=restrictions) var(2,1)=var(3,1)=var(3,2)=0.0 vbr(2,1)=vbr(3,1)=vbr(3,2)=0.0
frml hf = $
  hx=h{1},uux=uu{1},$
  %ltouterxx(vcr)+%mqform(uux,var)+%mqform(hx,vbr)
*  Initialize c's from the decomp of the covariance matrix
compute vcr = %decomp(rr)
compute var = %mscalar(.05) , vbr = %mscalar(.05)
maximize(parmset=meanparms+garchparms+restrictions,pmethod=simplex,piters=5,method=bfgs,iters=100) logl gstart gend
*Applying the @bdindtests procedure to the result
	set KEN_Z1 = resid(1)/sqrt(hx(1,1))
	set KEN_Z2 = resid(2)/sqrt(hx(2,2))
	set KEN_Z3 = resid(3)/sqrt(hx(3,3))
	@bdindtests(number=40) KEN_Z1
	@bdindtests(number=40) KEN_Z2
	@bdindtests(number=40) KEN_Z3
Re: Conducting a LB-Q test in a GARCH model using MAXIMIZE
Posted: Thu Jun 07, 2012 5:39 pm
Use the "Code" button to put a large chunk of program into a scrolling zone. It makes the post easier to read. (I already fixed yours-that's for the future).
The problem is here:
HX is used as a temporary during the calculations, and just has the last period's covariance matrix. What you want is to use the H series of matrices:
set KEN_Z1 = resid(1)/sqrt(h(t)(1,1))
set KEN_Z2 = resid(2)/sqrt(h(t)(2,2))
set KEN_Z3 = resid(3)/sqrt(h(t)(3,3))
Posted: Fri Jun 08, 2012 11:31 am
by Masafumi
I heartily appreciate your quick response. It worked perfectly.
One more question--my current program had only constants in the mean equation, but I would like to structure the mean equation as a VAR model with restrictions.
In particular, I want to have a mean equation such as:
x(t) = alpha + beta' x(t-1) + u(t)
where x(t) is a 3x1 vector and the autoregressive terms beta = (beta11, beta12, beta13 | beta21, beta22, 0 | beta31, 0, 0).
I tried to get it done based on my current program, but it did not go well apparently because I couldn't figure out how I can structure "beta' x(t-1)" in the equation above:
dec vect alpha(n)
dec rect beta(n,n)
nonlin(parmset=meanparms) alpha beta
nonlin(parmset=meanrestrictions) beta(2,3)=beta(3,2)=beta(3,3)=0.0
do i=1,n
   frml resid(i) = (y(&i)-alpha(&i)-beta(&i)*y(&i){1})
nlsystem(parmset=meanparms+meanrestrictions,resids=u) gstart gend resid
compute rr=%sigma
I also looked at the example of VARMA GARCH model you posted, but it does not put restrictions.
Thank you so much again, and I am looking forward to hearing from you.
All the best,
Masafumi
Posted: Tue Jun 12, 2012 10:08 am
You would need to expand this:
do i=1,n
out to something like:
do i=1,n
frml resid(i) = (y(&i)-alpha(&i)-beta(&i,1)*y(1){1}-beta(&i,2)*y(2){1}-beta(&i,3)*y(3){1})
