How can I save output value data from Rats
Posted: Mon Jun 18, 2012 2:42 pm
Hello, I estimate comovement between two macro variables using Den Haan (2000) procedure which is available in estima website.
I mean Den Haans's paper titled comovement between outputs and prices (Journal of Monetary Economics).
The code enables me to show graphs, but I'd like to get the output, correlation coeffiients and, confidence level(99,95,90) values.
Could you let me know how to save these output values?
The following codes belong to part of computing confidence band and reporting graphs.
dec vect samesign(ncov)
do i=1,ncov
sstats(mean) 1 nboot (bootcorr(t)(i)>0.xor.basecorr(i)<0)>>samesign(i)
set c05 1 ncov = %if(samesign(t)>.95,basecorr(t),%na)
set c10 1 ncov = %if(samesign(t)>.90.and.samesign(t)<=.95,basecorr(t),%na)
set c00 1 ncov = %if(samesign(t)<=.90,basecorr(t),%na)
graph(nodates,style=bargraph,$
footer="Figure 3A Quarterly data with unit root imposed") 3
# c05 1 ncov
# c10 1 ncov
# c00 1 ncov
do i=1,ncov
# c05 1 ncov
# c10 1 ncov
# c00 1 ncov
