Conditional variance of SWARCH models
Posted: Thu Jul 05, 2012 6:12 am
by zy761
I'm using the replication file of Hamilton and Susmel(1994): Autoregressive Conditional Heteroskedasticity and Changes in Regime to do the SWARCH model. I was able to obtain the result. This program gives us the residuals and squared residuals. However, I cannot find how to get the conditional variance in the ARCH equation. Can anyone help me how to get the conditional variance? Many thanks in advance!
Re: Conditional variance of SWARCH models
Posted: Thu Jul 05, 2012 11:15 am
This calculates the one-step-ahead prediction for the variance and graphs it. (It works for either normal or t---the comments on this apply to putting it at the end of the HS_SWARCH_TL32.RPF program.)
* Calculation of one-step-ahead predictions for the variance (bottom
* panel in figure 3). This weights the variance calculations in the
* branches by the predictions of the probabilities of the branches at t
* given t-1.
function OneStepVariance time
type real OneStepVariance
type integer time
compute OneStepVariance=0.0
do i=1,nexpand
compute h=1.0
do k=1,q
compute h=h+a(k)*uu(time-k)/gv(%MSLagState(i,k))
end do k
compute h=h+d0*%if(u(time-1)<0.0,uu(time-1)/gv(%MSLagState(i,1)),0.0)
compute OneStepVariance=OneStepVariance+h*gv(%MSLagState(i,0))*pt_t1(time)(i)
set sigmahat gstart gend = sqrt(OneStepVariance(t))
set lower = -2.0*sigmahat
set upper = +2.0*sigmahat
spgraph(vfields=2,footer="Figure 3 (Top and Bottom Panels)")
graph(hlabel="Return")
# y
graph(hlabel="SWARCH-L(3,2)") 2
# upper
# lower / 1
Posted: Thu Oct 10, 2013 9:27 pm
by zy761
Could you post another example of variance estimation for the Dueker's regime switching GARCH case? I have tried to duplicate and revise your above example to Dueker's code, but it does not seem to work. Appreciate your help a lot! Thanks.
Posted: Fri Oct 11, 2013 9:53 am
That seems to be my program, not yours. It would be better if you showed me what you tried to do that didn't work. It involves taking the GARCHRegimeH function and, rather than returning a VECTOR of regime variances, returning the sum of regime variances weighted by pt_t1(time)(i).
Posted: Sat Oct 12, 2013 10:36 pm
by zy761
Here is the code I wrote, but actually I am not sure how to deal with GARCHRegimeH(i). I added it at the end of the Dueker's program, and error message turns out that :
## SX15. Trying to Store into Constant or Expression. Called Parameter by Value?
>>>>e GARCHRegimeH(i)=1<<<<
Could you help me with this? Thanks!
type integer time
do i=1,nexpand
compute GARCHRegimeH(i)=1.0+msg(2)*hs(%MSLagState(i,1))(time-1)+$
msg(1)*uu(time-1)/gv(%MSLagState(i,1))+$
%if(u(time-1)<0,msg(3)*uu(time-1)/gv(%MSLagState(i,1)),0.0)
compute OneStepVariance=OneStepVariance+GARCHRegimeH(i)*gv(%MSLagState(i,1))*pt_t1(time)(i)
# y
# upper
# lower / 1
Posted: Sun Oct 13, 2013 7:51 am
As in the SWARCH case, you don't need to save each of the variances into a VECTOR when you're just doing the conditional variance. Add LOCAL REAL H, and replace GARCHRegimeH(i) with H.
Posted: Mon Oct 14, 2013 12:26 am
by zy761
Thanks Tom! It works.
