Transformation in a loop
Posted: Tue Jul 10, 2012 8:47 am
by Marcus
My problem: I have a number of variables for which I have calculated one-period changes. This yielded positive (some zero) and negative values for the variables. I want to code the negative values into 0's and the non-negative into 1's. Unfortunately the code below produces 1's for all entries and variables:
smpl 2000:2 2012:3
Dofor i = dlprod dlesi dlnord dlppi dlmetmins
set %s('di'+%l(i)) = %if(i.ge.0,1.0,0.0)
end dofor i
However, the below works just fine for one variable
set x = %if(dlprod.ge.0,1.0,0.0)
Any help would be gratefully appreciated. Also any suggestions on how to sum (count) the 1's and 0's over each entry would be very helpful.
Marcus
Re: Transformation in a loop
Posted: Tue Jul 10, 2012 10:40 am
by moderator
smpl 2000:2 2012:3
end dofor i
The problem is with this expression:
i.ge.0
As written, RATS is going to interpret "i" as referring to the integer-valued identification number associated with the current series, rather than the values stored in the series itself. Because series numbers are always bigger than 0, the expression is always true.
You need to do something to tell RATS to interpret i as a series, rather than as a series number. One way to do that is by adding lag notation (using lag zero since you want to refer to the current entry). For example:
set %s('di'+%l(i)) = %if(i{0}.ge.0,1.0,0.0)
Another way is to use a "type modifier", like this (note the parens around the "[series]i" expression:
set %s('di'+%l(i)) = %if( ([series]i).ge.0,1.0,0.0)
If you know the series will be defined for all entries, you could just use the %sum() function:
compute sum = %sum(%s('di'+%l(i)))
More generally, you can use SSTATS, which computes sums by default:
sstats / %s('di'+%l(i))>>sum1
For example:
dec vector sums(5)
compute n = 1
sstats / %s('di'+%l(i))>>sums(n)
compute n = n+1
end dofor i
Tom Maycock
Posted: Wed Jul 11, 2012 1:28 am
by Marcus
Thanx,
I didn't explain the summation request properly.
What I need is a sum across entries, i.e. a sum of 1's and 0's for each time period, (a vector with two columns of sums for each period).
In other words, row sums o rather than column sums.
Changed to sums(2) and tried to include a loop over j = 2000:2 2012:3 in the code below but that didn't produce what I wanted. Got two sums instead.
dec vector sums(5)
compute n = 1
compute n = n+1
end dofor i
Marcus
Posted: Wed Jul 11, 2012 10:05 am
I'm a bit confused about what you want. Is it that you want to create a series which, at time t, has the number of positive values among the five series that you're listing?
Posted: Wed Jul 11, 2012 11:12 am
by Marcus
That sounds about right. If three of the series have positive values at 1998:3, the new series, summing 1's over rows, should have a 3 for 1998:3.
Posted: Wed Jul 11, 2012 12:05 pm
This is the simplest way to do that:
set mycount = 0.0
dofor i = dlprod dlesi dlnord dlppi dlmetmins
set mycount = mycount+(i{0}>=0)
end dofor i
