PRJPoisson—predicted values for a Poisson count data model
Posted: Thu Jul 10, 2008 2:02 pm
This computes the predicted values and marginal effects for a count data model estimated using DDV with TYPE=COUNT.
* @PRJPoisson( options )
* computes prediction and marginal effects for a count data model using the
* Poisson. This should be only be used after doing DDV with TYPE=COUNT.
* Options:
* XVECTOR=vector of test values for the explanatory variables. Make sure you include
* 1 for the CONSTANT.
* TITLE=title for output
* Revision Schedule:
* 07/2008 Written by Tom Doan, Estima.
procedure prjpoisson
option vector xvector
option string title
local real p
local vect ez
local integer j row
if .not.%defined(xvector) {
disp "Syntax: @PRJPOISSON(XVECTOR=xvector,other options)"
return
compute ez=exp(%dot(xvector,%beta))
report(action=define)
compute row=0
if %defined(title)
report(atrow=(row=row+1),atcol=1,span) title
report(atrow=(row=row+1),atcol=1) "Predicted Value" ez
do j=1,%nreg
if %eqnreglabels(0)(j)=="Constant"
next
report(atrow=(row=row+1),atcol=1) "Marginal "+%eqnreglabels(0)(j) ez*%beta(j)
report(action=show)
