Can RATS program continues even it encounters error message?
Posted: Mon Aug 20, 2012 2:33 am
I have got a question to ask you. I was trying to use RATS to do some nonlinear estimations. During my grid search process, I need to specify different initial values for the parameters. As you know, some of the initial values may work and some may not. However, RATS will stop executing the loops and report an error message whenever a mistake is detected (say, a non-PSD. covariance matrix occurs due to bad initial values).
Whenever this happens, I will have to restart the program manually. This is very time-consuming. I am wondering if there is a command in RATS, as in MATLAB or EViews, which controls the maximum number of errors that RATS allows in the program. Before this maximum number is reached, RATS will not terminate the program.
Can I do this in RATS?
