Terasvirta 1994 STAR Models
Posted: Thu Mar 19, 2015 10:19 am
This provides two worked examples from Terasvirta(1994), "Specification, Estimation and Evaluation of Smooth Transition Autoregressive Models", JASA, vol 89, pp 208-218. These use the @STARTEST procedure to test for the presence of STAR effects; the results from that are also used to select the delay on the threshold variable (taking the delay that gives the largest test statistic). The models are then estimated using non-linear least squares.
This also includes an extension to the analysis in the paper to forecasting, both using simulations (to get the minimum mean square error forecasts for the non-linear model) and zero residual forecasting (which gives the "eventual forecasting function").
STAR (and "sharp" threshold TAR) models are covered as part of the Structural Breaks and Switching Models course. The RATS Programming Manual also devotes a large part of Chapter 3 to STAR models.
lynx.rpf
Lynx example
(2.88 KiB) Downloaded 2402 times
ger4ind.rpf
German example
(1.7 KiB) Downloaded 2347 times
lynx.dat
Data for lynx
(663 Bytes) Downloaded 2265 times
ger4ind.prn
German data
(2.07 KiB) Downloaded 2174 times
lynxforecast.rpf
Extension to show forecasts
(2.82 KiB) Downloaded 2403 times
Re: Terasvirta 1994 STAR Models
Posted: Tue Sep 25, 2018 8:48 am
by bb_poimot
May I ask whether winrats provides the code for Lin & Terasvirta (1994) Testing the constancy of regression parameters against continuous structural change, Journal of Econometrics, 62 (1994), pp. 211-228? thanks a lot
Posted: Thu Jun 05, 2025 1:51 pm
That appears to be just a repackaging of @RegSTRTest with time as the transition variable.
