Pedroni cointegration and GM-FMOLS
Posted: Mon Nov 05, 2012 9:41 pm
I attempt to perform the Pedroni cointegration test and the GM-FMOLS using RATS version 8. However, I faced several problems and I need your help.
1. My estimation model consists of at least 8 explanatory variables, but 3 of them are dummy variables. I am not sure whether I should include all 8 variables to test for the panel cointegration with Pedroni approach or I should run the test without the dummy variables. If I am not mistaken, Pedroni (1999) allow us to test for maximum 7 explanatory variables.
2. From my reading, I understand that if the panel dataset are cointegrated. I should estimate the relationship between the variables of interest using GM-FMOLS. However, some of the studies include dummy variables in their GM-FMOLS model, while some other studies exclude the dummy variable and they include the dummy variables only in the short run. I’m a bit confused about this.
Here, I hope to get a feedback from you all as soon as plausible.
