Page 1 of 2
Extracting the residual series from MGARCH-M model
Posted: Sun Nov 25, 2012 11:56 am
by msrahman
I am using following Multivariate GARCH instruction to estimate a GARCH model. I want to extract the estimated residual series stored in rv. Could you please guide me about how to do this?
garch(model=garchm,mv=bekk,presample=cv0,$
rvectors=rv,hmatrices=h,$
uadjust=%pt(eps,t,rv(t)),hadjust=%pt(sqrth,t,%sqrt(%xdiag(h(t)))),$
pmethod=simplex,piters=20,init=%beta)
Re: Extracting the residual series from MGARCH-M model
Posted: Sun Nov 25, 2012 3:48 pm
See page UG-302 in the Version 8 User's Guide. Those are doing standardized residuals, but you can do the same thing without the standardization.
Posted: Tue May 19, 2015 10:06 am
by econo
I am trying to extract Standardized residuals (RATS 8.0):
system(model=var1)
variables O C
lags 1
compute cv0=%sigma
garch(p=1,q=1,model=var1,mv=CC,variance=varma,pmethod=simplex,piters=5,hmatrices=Varmah, MVHSERIES=VarmaHmatrix, rvectors=Varmarv,presample=cv0,uadjust=%pt(eps,t,Varmarv(t)),hadjust=%pt(sqrth,t,%sqrt(%xdiag(Varmah(t)))),$
  pmethod=simplex,piters=20 ) gstart gend O C
but face this error:
## OP3. This Instruction Does Not Have An Option UAD
>>>>sample=cv0,uadjust=<<<<
Posted: Tue May 19, 2015 10:25 am
UADJUST and HADJUST were added with RATS 8.1. There were many additional changes to GARCH with 9.0. I would suggest that you update to v9.
Posted: Tue May 19, 2015 10:54 am
by econo
the only way is updating?
how can I get the residuals?
Posted: Tue May 19, 2015 11:37 am
In effect, yes. You can't estimate the model without the new options---they were added precisely to make a model like this (a VARMA-GARCH-M) tractable. And if you can't estimate the model, you can't get the residuals.
Posted: Tue May 19, 2015 11:46 am
by econo
I mean, with this code I can estimate the model
garch(p=1,q=1,model=var1,mv=CC,variance=varma,pmethod=simplex,piters=5,hmatrices=Varmah, MVHSERIES=VarmaHmatrix, rvectors=Varmarv)
Now I have the hmatrices, I can get the sqrt of it.**
if I can get the residuals of this GARCH function, then I have the standardized residuals!
{ I dont know how to find SQRT in RATS but code in R is as follow
a.eig <- eigen(a)
a.sqrt <- a.eig$vectors %*% diag(sqrt(a.eig$values)) %*% solve(a.eig$vectors)
Posted: Tue May 19, 2015 12:14 pm
The GARCHMV.RPF example with your version 8 has code for computing multivariate standardized residuals. (Note that there are an infinite number of ways of standardizing a multivariate set of series with each generating a somewhat different set of diagnostics). With version 9, there's a STDRESIDS option which computes it directly. Note that VARIANCES=VARMA has nothing to do with the "VARMA" (mean model) used in the original example in this thread.
Posted: Tue May 19, 2015 3:02 pm
by econo
garch(p=1,q=1,model=var1,mv=CC,variance=varma,pmethod=simplex,piters=5,hmatrices=Varmah, MVHSERIES=VarmaHmatrix, rvectors=Varmarv ) gstart gend O c
open copy 2.xls
copy(data,format=xls,org=columns)  /Varmarv
## SX22. Expected Type SERIES[REAL], Got SERIES[VECTOR[REAL]] Instead
>>>>columns) /Varmarv<<<<
How can I save the residuals?
Posted: Tue May 19, 2015 3:22 pm
Even if that would work (it won't because RVECTORS produces a SERIES[VECTOR] which COPY doesn't handle), of what use would the non-standardized residuals from a GARCH model be? Those won't be all that different from the residuals from estimating the VAR without the GARCH errors. Compute the standardized residuals using the method shown in your GARCHMV.RPF program and you can apply COPY to them.
Posted: Tue May 19, 2015 3:41 pm
by econo
Do you mean this code?
* Estimates for a BEKK with t errors, saving the residuals and the
* variances (in the VECT[SERIES] and SYMM[SERIES] forms), and using them
* to compute the empirical probability of a residual (for Japan) being
* in the left .05 tail.
garch(p=1,q=1,mv=bekk,pmethod=simplex,piters=10,distrib=t,$
   rseries=rs,mvhseries=hhs) / xjpn xfra xsui
compute fixt=(%shape-2)/%shape
set trigger = %tcdf(rs(1)/sqrt(hhs(1,1)*fixt),%shape)<.05
Posted: Tue May 19, 2015 4:16 pm
No. You don't have version 9 (and that's a completely different calculation anyway). There's a GARCHMV.RPF in your examples folder which works with version 8. GARCHMV.RPF is also described in your User's Guide (Example 9.2) as is the process for obtaining standardized residuals (section 9.8.2). In the code below, the ZU are the multivariate standardized residuals. (Z1, Z2 and Z3 are univariate standardized residuals, which aren't as useful diagnostically).
garch(p=1,q=1,pmethod=simplex,piters=10,$
   hmatrices=hh,rvectors=rd)  / xjpn xfra xsui
set z1 = rd(t)(1)/sqrt(hh(t)(1,1))
set z2 = rd(t)(2)/sqrt(hh(t)(2,2))
set z3 = rd(t)(3)/sqrt(hh(t)(3,3))
@bdindtests(number=40) z1
@bdindtests(number=40) z2
@bdindtests(number=40) z3
* Multivariate Q statistic. This requires transforming the residuals to
* eliminate the time-varying correlations.
dec vect[series] zu(%nvar)
do time=%regstart(),%regend()
end do time
Posted: Wed Jun 17, 2015 10:37 am
by econo
Now it gives me this error:
Error was evaluating entry 2355
Posted: Wed Jun 17, 2015 10:52 am
by econo
TomDoan wrote:it won't because RVECTORS produces a SERIES[VECTOR] which COPY doesn't handle[/i].
to export errors vector, I used this code
EWISE rd(t) = X(t)
## SX11. Identifier X is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>>EWISE rd(t) = X(<<<<
still doesn't work :(
Posted: Wed Jun 17, 2015 11:07 am
I assume this is with your program adapted to your data set. You would have to attach the whole program for us to tell. Which instruction/loop is causing the problem? (Do Show Last Error on the Edit menu).
