ADFAutoSelect—Selection of Lag Length for ADF Test
Posted: Fri Aug 29, 2008 10:00 am
@ADFAUTOSELECT is a procedure for selecting or aiding in the selection of the number of lags in an ADF test. It offers four different criteria for selection, and (optionally) can produce a table which includes all of them, or it can (silently) choose the lag length based upon a specific choice for the criterion. However, it is not so much designed for producing a final ADF test as it is for choosing the lag length for use in later calculations. The table produced by the PRINT option includes the ADF test, but this is an ADF test using only the data range permitted by the maximum number of lags, not the range that would be used for an ADF test for that specific number of lags. If you're just trying to do an ADF test and you know which selection criterion you want to use, use the @DFUNIT procedure instead.
Detailed description
Example
Sample Output
Example
* Greene, Econometric Analysis, 6th Edition
* Example 22.3 and 22.4 from pp 754-756
open data tablef5-1.txt
calendar(q) 1950
data(format=prn,org=columns) 1950:01 2000:04 year qtr realgdp realcons $
realinvs realgovt realdpi cpi_u m1 tbilrate unemp pop infl realint
set loggdp = log(realgdp)
* ADFAutoSelect does a sequence of DF tests and displays a table of
* criteria which can be used to select the lag length. The final column
* has the test statistic. This differs from the one in the stand-alone
* DFUNIT because ADFAutoSelect uses only the data points allowed when 14
* lags are included, while DFUNIT (by default), uses the maximum range
* allowed with the number of lags used on it.
@adfautoselect(maxlags=14,det=trend,print) loggdp
@dfunit(lags=1,det=trend) loggdp
@ppunit(lags=4,det=trend) loggdp
* KPSS test (example 22.4)
@kpss(lags=10,det=constant) loggdp
@kpss(lags=10,det=trend) loggdpCode: Select all
Information Criteria for ADF Lag Lengths, Series LOGGDP
Lags AIC BIC HQ MAIC ADF
0 -9.274 -9.223 -9.253 -9.275 -1.700
1 -9.399 -9.330* -9.371* -9.365 -2.444
2 -9.400* -9.315 -9.366 -9.351 -2.674
3 -9.391 -9.288 -9.350 -9.348 -2.513
4 -9.386 -9.266 -9.338 -9.353 -2.301
5 -9.389 -9.251 -9.333 -9.368* -2.024
6 -9.382 -9.228 -9.320 -9.354 -2.129
7 -9.372 -9.200 -9.302 -9.344 -2.091
8 -9.362 -9.173 -9.285 -9.337 -2.007
9 -9.357 -9.151 -9.273 -9.324 -2.128
10 -9.347 -9.124 -9.257 -9.310 -2.167
11 -9.337 -9.097 -9.240 -9.304 -2.079
12 -9.343 -9.085 -9.238 -9.323 -1.822
13 -9.334 -9.060 -9.223 -9.318 -1.733
14 -9.326 -9.035 -9.208 -9.307 -1.789
