GLSDetrend—local to unity detrending
Posted: Fri Aug 29, 2008 10:07 am
@GLSDETREND is a local to unity detrending routine allowing for various types of trends, including ones with a break at a known point. This includes the Elliott-Rothenberg-Stock cases (no constant, constant, constant and trend) as well as the Perron and Rodriguez cases (constant and trend with a single break). This just does the detrending, not the actual unit root test(s). For models with breaks, you need to input the break point.
Detailed description
Re: GLSDetrend - local to unity detrending
Posted: Wed Oct 14, 2009 8:41 am
by Anna
Hey Tom,
I think there is a minor mistake in that program, concerning the case of a break in the intercept only. As far as I can see, the program takes c=23 in that case, but it should actually be 13.5 as in Elliot et. al. if I understand Perron & Rodriguez correctly. They do not consider a break in the level only because this is "just a special case" of Elliot et al.'s slowly evolving deterministics (or so). If this was the case, I think Elliots c-value should be taken and not Perron & Rodriguez, right?
Best wishes
Anna
Posted: Wed Oct 14, 2009 12:14 pm
by Anna
And another question: I am wondering, why do you write this:
set yd startl endl = y-%dot(%xt(z,t),%beta)
Why not just "ut" as defined by the last linreg command?
Posted: Wed Oct 14, 2009 3:26 pm
Anna wrote:Hey Tom,
Best wishes
Anna
Although it allows for the BREAK=INTERCEPT option, it won't do it. All the BREAKs are either trend or trend + intercept.
Posted: Mon Apr 23, 2018 3:52 pm
Anna wrote:And another question: I am wondering, why do you write this:
The previous linreg is on GLS transformed data, but what's needed for yd is the calculation on the original data.
