Page 1 of 2
Multivariate Ljung-Box tests
Posted: Tue Mar 19, 2013 12:36 pm
by yli725
I use a BEKK model in my research, after estimating, I want to make sure my model was proper specified, so I applied multivariate Ljung-Box tests for both residuals for mean equation and squared residuals for variance equation. My codes are
dec vect[series] zu(%nvar)
do time=%regstart(),%regend()
end do time
set z1s = (zu(1))**2
set z2s = (zu(2))**2
set z3s = (zu(3))**2
@mvqstat(lags=6)
# z1s z2s z3s
Since the entire residual vector needs to be standardized, I want to make sure that I make it right.
Also, the user guide says that the results will be different if I choose a different facrorization. I want to know what other facrorizations I can choose.
I appreciate that your kindly help.
Re: Multivariate Ljung-Box tests
Posted: Wed Mar 20, 2013 10:07 am
What you want is to do is @MVARCHTEST applied to the standardized residuals:
end do time
@MVARCHTest(lags=6)
# zu
The two (Q test applied to the squares and the ARCH test) will do similar things to the diagonals, but the ARCH test treats the interactions correctly.
Posted: Wed Mar 20, 2013 4:07 pm
by yli725
TomDoan wrote:What you want is to do is @MVARCHTEST applied to the standardized residuals:
end do time
@MVARCHTest(lags=6)
# zu
Thank you very much, Tom.
When I appiled @mvarchtest, I noticed the degrees is 864, if my subsample's observation is only 800, does this test still valid?
Posted: Wed Mar 20, 2013 4:44 pm
end do time
@MVARCHTest(lags=6)
# zu
LAGS=6 may be a bit much, but it's still OK. It's a multiple regression on cross products of the residuals, so the potential degrees of freedom is 6 (=n(n+1)/2) x 800.
Posted: Thu Jun 30, 2016 9:20 pm
by debbysoraya
Hey Tom,
I also do var bekk garch model, and then
for the mvqstat i got
@mvqstat(lags=6)
# zu
Multivariate Q(6)= 716.02087
Significance Level as Chi-Squared(726)= 0.59700
I keep going back and forth to tr whether this number actually mean that I have a VAR problem or not, but there was no clear benchmark whether it means my model is okay, or my model is not
and I try to do the mvartch test
for lag 1
@mvarchtest(lags=1)
# zu
Test for Multivariate ARCH
Statistic Degrees Signif
206086.60 4356 0.00000
it gives me this which I think means my model is not adequate, when I try to put higher lag,
it send me this message;
The Error Occurred At Location 587, Line 55 of MVARCHTEST
C:\Users\Public\Documents\Estima\WinRATS Pro 9.1 Trial\mvarchtest.src Line 77
In this case what should I do ?
Thanks a lot!
Posted: Fri Jul 01, 2016 10:47 am
debbysoraya wrote:Hey Tom,
@mvqstat(lags=6)
# zu
I'm not sure what "VAR problem" means. However, if these are the standardized residuals from the GARCH, then this is what you want to see---there's no real sign of residual autocorrelation.
debbysoraya wrote: and I try to do the mvartch test
for lag 1
@mvarchtest(lags=1)
# zu
Thanks a lot!
If you're applying @MVARCHTEST to the standardized residuals from the GARCH, then you have a very serious problem. That looks more like the results from applying it to the residuals from a OLS VAR, where a strongly significant result would be expected if the data showed GARCH properties. More lags won't help that---if you reject at one, there isn't really a point in using more. You're probably using enough that the auxiliary regression that @MVARCHTEST does runs out of degrees of freedom.
Posted: Sat Feb 17, 2018 12:07 am
by humyra
Tom, I'm having a similar problem. The MVARCHTEST applied to zu (where zu is the stdresiduals in the BEKK GARCH command) gives a highly significant result. Does this indicate that the VAR-BEKK-GARCH model I'm using is mispecified?
Posted: Tue Feb 27, 2018 2:26 pm
humyra wrote:Tom, I'm having a similar problem. The MVARCHTEST applied to zu (where zu is the stdresiduals in the BEKK GARCH command) gives a highly significant result. Does this indicate that the VAR-BEKK-GARCH model I'm using is mispecified?
Something is. First make sure you have the serial correlation in the mean handled. Until you do that, anything you do with a GARCH model is pretty much meaningless.
Posted: Wed Feb 28, 2018 6:54 am
by humyra
How do I handle the serial correlation in the mean model?
Posted: Wed Feb 28, 2018 8:29 am
Usually a low order VAR. If that doesn't work, it usually means that you have a major structural break and can't really fit a standard GARCH model across the whole sample.
Posted: Wed Feb 28, 2018 8:42 am
by humyra
Thanks a lot Tom! I used weekly returns instead of daily and that also helped in correcting this to a large extent.
Posted: Wed Feb 28, 2018 7:57 pm
by humyra
TomDoan wrote:Usually a low order VAR. If that doesn't work, it usually means that you have a major structural break and can't really fit a standard GARCH model across the whole sample.
Tom, is it possible to estimate a structural VAR-BEKK-GARCH model is RATS? And perform the tests for detecting structural breaks?
Posted: Wed Feb 28, 2018 9:54 pm
The term "structural" in those means completely different things. "Structural VAR" in the context of a BEKK-GARCH really makes no sense---there's no sensible way to combine orthogonalization of residuals with the BEKK covariance calculations. You can do a quick check for structural breaks using the @FLUX procedure. Unless you have a specific type of break that you are expecting, a general search for breaks in a complicated non-linear model is a very complicated and time-consuming process.
Posted: Wed Sep 26, 2018 1:57 am
by sanjeev
I am trying to conduct MVARCH test on my VAR model to check first if an ARCH effect is present or not using following codes:
system(model=mvmean)
variables x1 x2 x3
lags 1
estimate (resids=resids)
@mvarchtest
# resids
However, I am getting following error message:
## SX11. Identifier RESIDS is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>>ate (resids=resids)<<<<
Is it possible you meant
%RESIDS
Common errors are
* a space before the ( in an option field
* a missing space before = in a SET or FRML
* a missing $ at the end of a long line which continues to the next
Please help!
Please reply soon!
Regards.
Posted: Wed Sep 26, 2018 10:15 am
As the message says:
Common errors are
That's your problem.
