LM linearity and other tests for STECM
Posted: Mon Apr 15, 2013 12:36 pm
by mskare69
is there a Rats code for LM linearity tests and how to estimate Nonlinear Error-Correction models (as in Nonlinear Error-Corection Models for Interest Rates in the Netherlands - van Dijk, P. Hans Fransen, 2000, Nonlinear Econometric Modeling in Time Series: Proceedings of the Eleventh International Symposium in Economic Theory, Cambridge University Press.
Marinko
Re: LM linearity and other tests for STECM
Posted: Wed Apr 17, 2013 2:03 pm
That would be done using
@RegSTRTest. The dependent variable in the regression is the difference in y; the explanatory variables are constant and lagged differences of x and y and lagged z (cointegrating relation), and the threshold variable is z (with some delay).
Posted: Wed Apr 17, 2013 3:44 pm
by mskare69
what changes in the @RegSTRTest code (which lines) should be made to be able to perform such a test?
Marinko
Posted: Wed Apr 17, 2013 4:08 pm
None. It's all the prep work of estimating the cointegrating relation and running the error correction regression.
Posted: Fri Apr 19, 2013 5:33 am
by mskare69
Any help on how could I do it also for STVECM not just for STECM?
Fondly,
Marinko
Posted: Fri Apr 19, 2013 9:29 am
The STECM test is just a simple modification of the STAR testing procedure. A joint test would be quite a bit more complicated. Do you have a reference for that?
Posted: Fri Apr 19, 2013 10:59 am
by mskare69
Will this do the work for STECM?
cal(a) 1800:1
open data lrcpi.xls
data(format=xls, org=column) 1800:1 2012:1 LR CPI
set y = LR - LR{1}
set y1= y{1}
linreg y1 1800:1 2012:1 z
# constant y{1 - 4} CPI{1-4}
@RegSTRTest(z d=1 to 6)
Posted: Fri Apr 19, 2013 11:02 am
by mskare69
for the STVECM - test and estimation I have a reference and Gauss code here
Vector Smooth Transition Regression Models for US GDP and the Composite index of Leading Indicators. In Journal of Forecasting, Vol. 23, No. 3, 2004, pp. 173-196
with the paper and the Gauss code
http://www.um.es/econometria/Maximo/
Fondly,
Marinko
Posted: Fri Apr 19, 2013 11:46 am
mskare69 wrote:Dear Tom,
cal(a) 1800:1
open data lrcpi.xls
set y = LR - LR{1}
set y1= y{1}
First, the syntax is all wrong---RATS doesn't use 1 - 4, it uses 1 to 4 in the lag fields on the regression. z doesn't look like a cointegrating relationship; in fact, as it's written, it will be zero since you have lagged y as the dependent variable and one of the explanatory variables. What's supposed to be cointegrated with what?
Posted: Fri Apr 19, 2013 12:37 pm
by mskare69
Hope this looks better
cal(a) 1800:1
open data lrcpi.xls
linreg LR / z
# constant CPI
set DLR = LR-LR{1}
set DCPI = CPI-CPI{1}
linreg DLR
# constant DCPI z{1}
@RegSTRTest(z{1} d=4)
Posted: Fri Apr 19, 2013 2:01 pm
mskare69 wrote:Hope this looks better
cal(a) 1800:1
open data lrcpi.xls
linreg LR / z
# constant CPI
set DLR = LR-LR{1}
linreg DLR
As I described earlier, the test is done by running the regression in the error correction form: dx on lags of dx and dy, one lag of z and a constant, in other words something like:
linreg DLR
# constant z{1} DCPI{1} dlr{1}
then the test (for delay of 4 on z) is done with
@RegSTRTest(threshold=z,d=4)
Posted: Fri Apr 19, 2013 2:18 pm
by mskare69
Thanks for the help, regarding STVECM I mentioned in the previous post would be great to have a RATS program running in since no many program can.
Fondly,
Marinko
Posted: Fri Jan 06, 2017 2:13 pm
Fondly,
Marinko
The Camacho paper is not a STVECM---he rejects cointegration right off the bat. Instead, it's a Smooth Transition VAR. There's an example of
that in the Martin-Hurn-Harris book. An STVECM would be similar except that you need to add a (lagged) disequilibrium term to the regressor list.
