VAR Forecasts
Posted: Wed Apr 24, 2013 4:28 pm
by Nabtheberliner
I'm wondering how can i change the title of this topic :maximum likelihood estimators to VAR study?
Also, according this task below:
[quote][/quote]Use the LS estimate and compute point forecasts ^y86(1),^ y86(2) (that is, the
forecast origin is the last quarter of 1968) and the corresponding MSE matrices
^Σy(1),^ Σy(2), ^Σ^y(1), and ^Σ ^y(2). Use these estimates to set up approximate
95% interval forecasts assuming that the process yt is Gaussian.
Where can i get some interesting explanations about how to compute estimated forecast MSE matrices? for h=1 it's easy but as you know the tricky point is for h=2 when i need to compute the omega matrix like in the Lütkepohl's book: New Introduction To Multiple Time Series Analysis p.99?
Thanks Tom
Re: VAR Forecasts
Posted: Wed Apr 24, 2013 4:50 pm
Nabtheberliner wrote:Hi Tom,
Start a new topic (which I already did). Don't rename an existing one since anyone looking for information on what you were doing before won't find it otherwise.
Thanks Tom
I would recommend not bothering with that. So-called "exact" calculations of standard errors for IRF's and forecasts was one of Lütkepohl's research interests, and it shows in the book. As you can see, it involves quite a bit of number-crunching. A more common way to compute the distribution of forecasts taking into account uncertainty in the coefficient estimates is with Monte Carlo integration.
Re: VAR Forecasts
Posted: Mon Jul 21, 2014 2:58 pm
by Nabtheberliner
First question is , i don't see in the interface New Topics? to create one about Impulse responses and Variance decomposition.
Concerning this topic, here my second question. On the wbesite of Estima i looked for the @Bernanke.src procedure but found nothing except bernankemihovqje1998.zip
My last question is about the in and out sample forecasts, in order to have a comparison between the series itself and the forecast.
Thanks a lot Tom for your time
Nabih
Re: VAR Forecasts
Posted: Mon Jul 21, 2014 3:17 pm
by Nabtheberliner
Sorry Tom , my last wasn't clear, i'm looking for some documents, i didn't find it in the user's guide.
N.
Re: VAR Forecasts
Posted: Mon Jul 21, 2014 3:27 pm
Did you mean to open a new thread? You just do "NewTopic".
The BERNANKE procedure is quite obsolete. It pre-dated the CVMODEL instruction. You should use that instead.
The @UFOREERRORS procedure sounds like what you want.
Re: VAR Forecasts
Posted: Wed Jun 01, 2016 12:10 pm
by Nabtheberliner
Hello Tom,
I'm trying to run a full VAR forecasting with graph applying Lutkepohl VAR forecasting progr.P.098 but it doesn't recognize the upper variable and i get an empty range on the series forecurrency(1) and the other two? the currencies file is attached
I don't see the mistake.
Thanks Tom
OPEN DATA "C:\Users\nabih\Desktop\Intro econometrics for finance\RATS data files\currenciesr.xls"
CALENDAR(D) 2002:7:7
DATA(FORMAT=XLS,ORG=COLUMNS) 2002:07:08 2009:07:07 EUR GBP JPY
set REUR = 100*log(EUR/EUR{1})
set RGBP = 100*log(GBP/GBP{1})
set RJPY = 100*log(JPY/JPY{1})
system(model=currency)
variables REUR RGBP RJPY
lags 1 to 2
estimate
FORECAST(MODEL=CURRENCY,FROM=2009:07:09,STEPS=10,RESULTS=FORECURRENCY,STDERRS=STDERRCURRENCY)
set upper = FORECURRENCY(1)+2.0*STDERRCURRENCY(1)
set lower = FORECURRENCY(1)-2.0*STDERRCURRENCY(1)
graph(footer="Forecasts of REUR") 4
# REUR
# FORECURRENCY(1)
# upper / 3
# lower / 3
set upper = FORECURRENCY(2)+2.0*STDERRCURRENCY(2)
set lower = FORECURRENCY(2)-2.0*STDERRCURRENCY(2)
graph(footer="Forecasts of RGBP") 4
# RGBP
# FORECURRENCY(2)
# upper / 3
# lower / 3
set upper = FORECURRENCY(3)+2.0*STDERRCURRENCY(3)
set lower = FORECURRENCY(3)-2.0*STDERRCURRENCY(3)
graph(footer="Forecasts of RJPY") 4
# RJPY
# FORECURRENCY(3)
# upper / 3
# lower / 3
Re: VAR Forecasts
Posted: Wed Jun 01, 2016 12:16 pm
by Nabtheberliner
Sorry the empty range is about the series upper not the forecurrency(1) as you can see
Re: VAR Forecasts
Posted: Wed Jun 01, 2016 12:37 pm
Your data end in 2009:07:07, but you're doing dynamic forecasts starting in 2009:7:9:
FORECAST(MODEL=CURRENCY,FROM=2009:07:09,STEPS=10,RESULTS=FORECURRENCY,STDERRS=STDERRCURRENCY,print)
Because there's no data in 2009:7:8, the forecasts are NA's.
Re: VAR Forecasts
Posted: Wed Jun 01, 2016 3:09 pm
by Nabtheberliner
Thank you Tom!
Just a question, why graphically is it so flat? is it normal?
Re: VAR Forecasts
Posted: Wed Jun 01, 2016 3:21 pm
If the data are returns to currency (or to stocks, or to almost any liquid financial asset), yes, the forecasts will be quite flat with a wide error band.
Re: VAR Forecasts
Posted: Wed Jun 01, 2016 4:16 pm
by Nabtheberliner
Thanks you confirmed what i thought, wasn't not sure 'cause i'm getting started with econometrics for finance.
