Using the SSTAT command
Posted: Wed Aug 07, 2013 11:02 am
by alex600
I have the following code that I am using to create rolling MGARCH regressions, I need to calculate the covariance for the four variables each time through. My SSTAT equation returns "NA". Any help will be appreciated. My code is below.
compute width=1305
do begin=2001:01,2002:01,22
lin(noprint,define=Cash1) dls1 ; # constant
lin(noprint,define=Futures1) dlf1 ; # constant
lin(noprint,define=Cash2) dls2 ; # constant
lin(noprint,define=Futures2) dlf2 ; # constant
group macro Cash1 Futures1 Cash2 Futures2
garch(noprint,p=1,q=1,rvectors=resids0,mvhmatricies=ht0,model=macro,mv=bekk, $
  iterations=500,subiterations=100,cvcrit=0.0001) begin begin+width
if %converged<>1;garch(noprint,p=1,q=1,rvectors=resids0,mvhmatricies=ht0,model=macro,mv=bekk, $
  iterations=1500,subiterations=500,cvcrit=0.000001,hessian=%xx,      $
  initial=%BETA) begin begin+width
  iterations=2500,subiterations=1000,cvcrit=0.0001,hessian=%xx,      $
  dis %datelabel(begin)
  if %converged<>1;dis 'Model did not converge'
  if %converged==1;dis 'Model converged'
  com AIC = -2.*%funcval + 2.0*%nreg/%nobs
  com HQC = -2.*%funcval + %nreg*2.0*log(log(%nobs))/%nobs
  com SBC = -2.*%funcval + %nreg*log(%nobs)/%nobs
  set OHR_euro = ht0(2,1)/ht0(2,2)
  stat(noprint) OHR_euro
  dis 'OHR Euro     '  %mean
  set OHR_urals = ht0(4,3)/ht0(4,4)
  stat(noprint) OHR_urals
  dis 'OHR URALS    ' %mean
  com s = sqrt(%variance/%nobs)
  com tratio = %mean/s
  dis 'Log Likelihood =' %FUNCVAL
dis 'T-stat' tratio '  aic = ' aic ' hqc = ' hqc '  and sbc = ' sbc
stat(noprint) dls1
com m1=%mean
stat(noprint) dlf1
com m2=%mean
stat(noprint) dls2
com m3=%mean
stat(noprint) dlf2
com m4=%mean
dis m1 m2 m3 m4
SSTAT / (m1)*(m3)*(ht0(2,4))+(m1)*(m4)*(ht0(2,3))+(m2)*(m3)*(ht0(1,4))+(m2)*(m4)*(ht0(1,3))  $
+(m1)*(dls2-dls2{1})*(dlf1-dlf1{1})*(dlf2-dlf2{1})+(m2)*(dls1-dls1{1})*(dls2-dls2{1})*(dlf2-dlf2{1})  $
+(m3)*(dls1-dls1{1})*(dlf1-dlf1{1})*(dlf2-dlf2{1})+(m4)*(dls1-dls1{1})*(dlf1-dlf1{1})*(dls2-dls2{1})  $
-(ht0(1,2))*(ht0(3,4))>>COV4
dis COV4
end do
Re: Using the SSTAT command
Posted: Wed Aug 07, 2013 11:58 am
Because SSTATS is designed to be applied to potentially multiple target expressions, it's a bit fussier about ranges than (for instance) a single STATISTICS instruction. One question is what range you actually want to use for many of those calculations. For instance, for the following:
stat(noprint) dls1
com m1=%mean
stat(noprint) dlf1
com m2=%mean
stat(noprint) dls2
com m3=%mean
stat(noprint) dlf2
com m4=%mean
dis m1 m2 m3 m4
all those STATISTICS instructions will be applied to the full available range. However, those are inside the DO loop, so I'm guessing that you really want them restricted to the same range as the GARCH instructions. You could do those with a single SSTATISTICS with
SSTATS(mean) %regstart() %regend() dls1>>m1 dlf1>>m2 dls2>>m3 dlf2>>m4
dis m1 m2 m3 m4
The final SSTATS would be revised to
SSTAT %regstart()+1 %regend() (m1)*(m3)*(ht0(2,4))+(m1)*(m4)*(ht0(2,3))+(m2)*(m3)*(ht0(1,4))+(m2)*(m4)*(ht0(1,3)) $
to take into account the lost data point due to the lags (did you want the MEAN option on that as well?)
Posted: Tue Aug 13, 2013 2:26 pm
by alex600
Thanks for your help. I will have to think about whether I need to adjust the mean for the lost observation.
My final calculation is as follows:
set OHR = COV4 / (ht0(2,4))
dis " OHR = " OHR
I get this
OHR = DISPLAY cannot show SERIES[REAL]
It doesn't like me dividing the covariance that I calculated (COV4) by the covariance of two of my variables ht0(2,4). Any thoughts?
Posted: Tue Aug 13, 2013 3:51 pm
You can't DISPLAY a series. Use PRINT instead.
Is COV4 supposed to be fixed across time (given an estimation interval)?
Posted: Tue Sep 03, 2013 8:49 am
by alex600
Tom,
I was headed in the wrong direction, I don need to use SSTAT, I need to calculate the covariance at each observation. My formula is as follows:
set COV4=(%beta(1))*(%beta(3))*ht0(2,4)+(%beta(1))*(%beta(4))*ht0(2,3)+(%beta(2))*(%beta(3))*ht0(1,4)+(%beta(2))*(%beta(4))*ht0(1,3) $
+(%beta(1)))*(spot2-%beta(3))*(fut1-%beta(2))*(fut2-%beta(4))+(%beta(2))*(spot1-%beta(1))*(spot2-%beta(3))*(fut2-%beta(4)) $
+(%beta(3))*(spot1-%beta(1))*(fut1-%beta(2))*(fut2-%beta(4))+(%beta(4))*(spot1-%beta(1))*(fut1-%beta(2))*(spot2-%beta(3)) $
-ht0(1,2)*ht0(3,4)
I need to multiply the intercept terms by various covariances, which are series, in the first part of the equation and then the residuals are multiplied by the covariances in the second part. I can't figure out how to multiply a whole number by each observation in the covariance series.
Marty
Posted: Tue Sep 03, 2013 10:19 am
alex600 wrote:Tom,
-ht0(1,2)*ht0(3,4)
As you have this written, COV4 will be a series generated using the elements of HT0, the SPOTx and FUTx series, and the GARCH coefficients. Is that what you want? (Note that you're missing a space between set COV4 and =).
Posted: Wed Sep 04, 2013 8:45 am
by alex600
Yes, I'm trying to create a series of conditional covariances of all four variables.
I added the space and got:
## SX22. Expected Type SERIES[REAL], Got RECTANGULAR[REAL] Instead
>>>>set COV4 <<<<
Do I need a different operator to multiply a constant by a series?
Posted: Wed Sep 04, 2013 10:13 am
No. The problem is that somewhere earlier you've done something that's defined COV4 as a matrix, rather than a series.
Posted: Thu May 08, 2014 10:17 am
by alex600
I'm working on a similar rolling MGARCH regression but I am now using observation numbers in place of dates because I have too many missing values. My problem is that the window is not moving, the start date is the same in all my regressions. My goal is to run 1-year (width=250) regressions every six months over my data set. I have posted a portion of my code below.
Marty
compute width=250
do begin=2,1252,125
lin(noprint,define=Cash1) dspot1 ; # constant
lin(noprint,define=Futures1) dfut1 ; # constant
Posted: Thu May 08, 2014 11:28 am
You have a NOPRINT option on the GARCH, so how do you know that the window isn't "moving"? (BTW, as this is written it has to be moving).
These can (and should) be outside the loop. Now as those are written they will run over the same range each time, but since you never use those, it won't matter.
Posted: Thu May 08, 2014 5:55 pm
by alex600
Thanks, my regressions are rolling properly. The new results were being added to the prior results. which looked like the window was increasing. I fixed that myself.
Marty
