Page 1 of 2
Hasbrouck(1995) Information Shares
Posted: Tue Sep 24, 2013 12:58 pm
This was based upon some posts from the RATS Discussion List.
Is there rats program for Hasbrouck(1995) "One security, many markets: determining the contribution to price discovery", Journal of Finance?
If CSTAR=C(1) is the matrix of long-run multipliers for Y(t)=C(L)e(t) and F is a factor of the covariance matrix for the e's, then the long-run covariance matrix is
cstar*f*tr(f)*tr(cstar)
You can decompose the long-run variance into the fractions due to each of the orthogonal components with the following:
compute split=cstar*f
compute contrib=split.^2
compute [vector] variance=contrib*%fill(%cols(contrib),1,1.0)
ewise contrib(i,j)=contrib(i,j)/variance(i)
Row i, column j will be the fraction of the long-run variance in i due to orthogonal shock j.
A full example is provided by
hasbrouck.rpf. This does the calculation with both an empirically chosen cointegrating vector and also the theoretical cointegrating space (which has a single common trend).
- w-tb3n6ms.txt
- Data file for example
- (62.86 KiB) Downloaded 3064 times
Re: Hasbrouck(1995) Information Shares
Posted: Tue May 06, 2014 9:46 am
by jeanne
Dear all,
Is there any chance I could use this code/ the Hasbrouck method for more than two variables? I want to examine one spot and two futures markets and find out where price discovery takes place.
Thank you very much!
Jeanne
Posted: Wed May 07, 2014 10:39 pm
jeanne wrote:Dear all,
Jeanne
This actually does five, though the change to make it three is fairly clear. While not the ideal data set, this gets five annual yields from five different bond prices. The analysis starts once y1,...,y5 are constructed---in general, those would be log asset prices.
open data bondprice.prn
calendar(m) 1952:6
data(format=prn,org=columns) 1952:06 2003:12 qdate price1 price2 price3 price4 price5
* Normalize and convert to percentages
dofor s = price1 to price5
set s = 100.0*log(s{0}/100.0)
end dofor s
* Compute percentage log yields per annum
set y1 = -price1
set y2 = -price2/2.0
set y3 = -price3/3.0
set y4 = -price4/4.0
set y5 = -price5/5.0
* The cointegrating vectors are any combination of four differences. The constant
* is restriction to the CV. Since the model has known cointegrating vectors, the
* intercepts have to be computed by taking the means of the corresponding
* differences.
sstats(mean) / (y1-y2)>>mean12 (y1-y3)>>mean13 (y1-y4)>>mean14 (y1-y5)>>mean15
equation(coeffs=||1.0,-1.0,-mean12||) eq12
# y1 y2 constant
equation(coeffs=||1.0,-1.0,-mean13||) eq13
# y1 y3 constant
equation(coeffs=||1.0,-1.0,-mean14||) eq14
# y1 y4 constant
equation(coeffs=||1.0,-1.0,-mean15||) eq15
# y1 y5 constant
system(model=vecm)
variables y1 y2 y3 y4 y5
lags 1 to 2
ect eq12 eq13 eq14 eq15
estimate
compute alphaperp=%perp(%vecmalpha)
compute psi=tr(alphaperp)
* Compute Choleski factorization of sigma
compute f=%decomp(%sigma)
* Compute decomposition of long-run variance
compute split=psi*f
compute contrib=split.^2/%dot(split,split)
disp "Decomposition of Long-run variance" contrib
Posted: Mon Jun 09, 2014 5:10 am
by jeanne
I want to compute information shares for a data set of spot prices x and futures prices y.
First, I estimate this:
@johmle(lags=10,det=constant,vectors=direct,dual=dual)
# x y
compute alphaperp=%xcol(dual,1)
compute beta=%xcol(direct,1)
compute betaperp=%perp(beta)
compute cstar=betaperp*tr(alphaperp)
... and get this result:
Likelihood Based Analysis of Cointegration
Variables: X Y
Estimated from 11 to 907
Data Points 897 Lags 10 with Constant
Unrestricted eigenvalues and -T log(1-lambda)
Rank EigVal Lambda-max Trace Trace-95% LogL
0 7855.9113
1 0.0190 17.2488 19.7802 15.4100 7864.5358
2 0.0028 2.5313 2.5313 3.8400 7865.8014
Cointegrating Vector for Largest Eigenvalue
X Y
-382.867863 375.388255
0.00808 0.99192
0.00808 0.99192
However, when I use/ adjust your code for the five markets
sstats(mean) / (x-y)>>meanxy
equation(coeffs=||1.0,-1.0,-meanxy||) eqxy
# x y constant
system(model=vecm)
variables x y
lags 1 to 10
ect eqxy
estimate
compute split=psi*f
... I get this:
0.94680 0.05320
Isn't that the exact opposite of the above?
Posted: Fri Jun 13, 2014 12:41 pm
Thanks for pointing that out. I corrected the code for the first example (the one that used @JOHMLE).
Posted: Wed Jul 09, 2014 7:23 am
by jeanne
Has anyone here tried to compute the modified information share model (MIS) proposed by Lien and Shrestha in the Journal of Futures Markets (2009) in RATS?
Any help will be greatly appreciated!
Posted: Wed Jul 09, 2014 3:03 pm
Isn't that the same thing but with:
* Compute Cholesky factorization of sigma
replaced with an eigenvalue-based factorization
eigen(dmatrix=identity) %sigma * f
Posted: Sun Mar 22, 2015 3:20 pm
by leewoo
Hello. everyone.
I have a question about Hasbrouck(1995) Information Shares code.
open data w-tb3n6ms.txt
calendar(w) 1958:12:12
data(format=free,org=columns) 1958:12:12 2004:8:6 tb3mo tb6mo
* With empirically determined cointegrating vector
@johmle(lags=5,det=constant,vectors=direct,dual=dual,loadings=ll)
# tb6mo tb3mo
* Compute long-run multiplier for a single cointegrating vector
* Note: cstar omits a constant multiplier, but that has no effect
* on the calculations of proportions
compute alpha=%xcol(ll,1)
compute alphaperp=%perp(alpha)
disp "contrib" contrib
compute var= cstar*f*tr(f)*tr(cstar)
disp "variance1" var
disp "variance2" variance
and I display the variance
variance1
0.00759 0.00767
0.00767 0.00776
variance2 0.00759 0.00776
Then I get
0.96255 0.03745
0.96255 0.03745
but It's different my calculation.
0.00731/0.00759=0.96310935 0.000284/0.00759=0.03744203
0.00747/0.00776=0.96262887 0.000291/0.00776=0.03744330
I attach hasbrouck equation.
am I wrong?
Posted: Sun Mar 22, 2015 7:10 pm
What's wrong is comparing full precision calculations (the ones done with RATS) with calculations done with intermediate values rounded to 3 significant digits (the ones you did by hand). Do the DISPLAY instructions at greater precision with disp *.######## ... for instance and recompute and you'll see. Note that the percentages due to each shock have to be identical.
The two ways of calculating the variance: summing the rows of contrib (which is what the RATS code is doing), and taking the diagonals of the full covariance matrix (what you're doing) are identical.
Posted: Mon Jul 09, 2018 8:30 am
by sheriared
Thank you very much for sharing your RATS code for Hasbrouck(1995) Information Shares. I am learning your code and I have got a question. I wonder if you could kindly enlighten me on this.
When you set y2 y3 y4 and y5, why do you divide them by 2, 3, 4, and 5, respectively?
Best
Liya
Posted: Mon Jul 09, 2018 9:29 am
The bond prices in the data set are the effective price of a zero-coupon bond of a particular maturity, so that's how you would compute the per annum yield of each.
Posted: Mon Jul 30, 2018 11:07 am
by sheriared
Could you please tell me how to specify the optimal lag using @varlagselect function?
OPEN DATA "C:\Users\lshenb\Documents\01-Work files\Research\A-study\Bitcoin\Price discovery\15min\S_BTC_XBT15.xlsx"
DATA(FORMAT=xlsx,ORG=COLUMNS) 2 6882 Spot BTC XBT
*note that the fisr entry of Spot, BTC and XBT are empty.
LOG Spot / y1
LOG BTC / y2
LOG XBT / y3
@varlagselect(crit=AIC,lags=15) 502 1001
# y1 y2
dofor i = 1 to 13
*sstats(mean) (i-1)*500+2 (i-1)*500+501 (y1-y2)>>mean12 (y1-y3)>>mean13
sstats(mean) (i-1)*500+2 (i-1)*500+501 (y1-y3)>>mean13
*equation(coeffs=||1.0,-1.0,-mean12||) eq12
*# y1 y2 constant
# y1 y3 constant
system(model=vecm)
variables y1 y3
lags 1 to 20
ect eq13
estimate(noprint) (i-1)*500+2 (i-1)*500+501
compute split=psi*f
display contrib
end dofor i
Many thanks indeed!
Posted: Mon Jul 30, 2018 11:28 am
@VARLagSelect sets %%AUTOP to the lag length selected using the chosen criterion.
Posted: Thu Oct 04, 2018 6:38 am
by sheriared
Could you please explain why betaperp is not needed in the example for bondprices with 5 variables?
Many thanks!
Posted: Thu Oct 04, 2018 1:26 pm
Beta-perp in that case is just a vector of ones.
