Fry-Pagan JEL 2011
Posted: Wed Oct 09, 2013 4:25 pm
This is an example of the calculation of Fry-Pagan (2011) median target estimators. "Sign Restrictions in Structural Vector Autoregressions: A Critical Review," Journal of Economic Literature, vol. 49, no. 4, 938-60. The example is taken from Uhlig(2005), "What are the effects of monetary policy on output? Results from an agnostic identification procedure", Journal of Monetary Economics, 52, pp 381-419.
As noted in the comments, there is no reason that the minimum distance response has to be inside the [16-84]-ile bands at every point, and in this case, the short-run responses for non-borrowed reserves are outside of it.
uhlig fry pagan.rpf
Program file
(4.66 KiB) Downloaded 1482 times
uhligdata.xls
Data file
(96 KiB) Downloaded 1007 times
Re: Fry-Pagan JEL 2011
Posted: Thu Jun 11, 2015 11:34 am
by luching
Hi Tom, I tried implementing the Fry-Pagan minimization in a different setting. You did mention that the selected impulse might lie outside the confidence bands. On a more fundamental note, will the Fry-Pagan approach guarantee that the selected impulse satisfies the sign restrictions we impose (in all the horizons)? I suspect the minimization routine does not guarantee that, but would like to double check with you.
Posted: Thu Jun 11, 2015 12:03 pm
luching wrote:Hi Tom, I tried implementing the Fry-Pagan minimization in a different setting. You did mention that the selected impulse might lie outside the confidence bands. On a more fundamental note, will the Fry-Pagan approach guarantee that the selected impulse satisfies the sign restrictions we impose (in all the horizons)? I suspect the minimization routine does not guarantee that, but would like to double check with you.
That's correct. It chooses the impulse vector whose responses come "closest" to the median of the cloud of responses which do satisfy the constraints, but there is no guarantee that it itself satisfies those constraints.
Posted: Tue May 22, 2018 7:30 pm
by umee
Tom,
How might I alter this code to produce forecast error variance decomposition?
I tried altering it with aspects of the Uhlig (2005) code, but had no success.
Posted: Fri May 25, 2018 9:12 pm
Add this to the end. It's just a single shock, so it's just a single calculation.
* Compute the percentages of this shock in the FEVD
declare vector ones ik
declare rect fevd(nstep,nvar)
compute ones=%fill(nvar,1,1.0)
gset irfsquared 1 1     = %xt(impulses,t).^2
ewise fevd(i,j)=ik=(irfsquared(i)*(a.^2))./(irfsquared(i)*ones),ik(j)
report(action=define,title="Forecast Variance Explained by FP Shock")
report(atrow=1,atcol=2,align=center) vl
report(atcol=1,atrow=2,fillby=cols) %seq(1,nstep)
report(atrow=2,atcol=2) 100.0*fevd
report(action=format,atrow=2,picture="###.###")
report(action=show)
Posted: Sat May 26, 2018 12:43 pm
by umee
Thanks. How might I graph the FEVDs? I've tried the following, but no success.
do i=1,nvar
compute minlower=maxupper=0.0
smpl 1 accept
do k=1,nstep
set work = fevd(t)(k,i)
compute frac=%fractiles(work,||.16,.50,.84||)
compute lower(k)=frac(1)
compute upper(k)=frac(3)
compute resp(k)=frac(2)
end do k
Posted: Sat May 26, 2018 12:47 pm
Graph what? It's one shock.
Posted: Sat May 26, 2018 12:57 pm
by umee
Can I not graph the FEVD for the 1, 2, 3, ....step ahead? So for GDP, can I simple create a graph of the numbers that coincide with the FEVD.
Posted: Sat May 26, 2018 12:58 pm
by umee
I guess what I'm saying is, instead of presenting the numbers, is there a better graphical presentation?
Posted: Sat May 26, 2018 1:25 pm
It's one shock. There are no error bands. I'm not sure what a graph is doing that's not obvious from the table. (To be perfectly honest, I don't even know what an FEVD of the FP shock is supposed to be showing anyway).
Posted: Sat May 26, 2018 1:33 pm
by umee
Is it possible to calculate the error variance for each accepted draw, and then use that info to construct an error variance graph from 1 to 50 steps ahead?
Posted: Sat May 26, 2018 1:45 pm
The original Uhlig paper has FEVD's done what way. You're posting questions in a thread about Fry-Pagan.
