Page 1 of 4
Graph Condtional Moments
Posted: Tue Nov 12, 2013 9:05 am
by rbelhach95
Hope all is well. I have difficulty with graphing the conditional moments, please see attached code along with the data. When I use the instruction TABLE to display the data, I see that e.g rho1 shows 0 number of observations while rho2 has 427, my objective is to graph the four series m1, v1, beta1, theta1, which keeps giving me "unassigned" Your support is very much appreciated.
Rachid
Re: Graph Condtional Moments
Posted: Tue Nov 12, 2013 9:28 am
by rbelhach95
Sorry, I attached the wrong code. The right code is attached, the data still the same
Rachid
Posted: Tue Nov 12, 2013 1:23 pm
You're mixing up COMPUTEs and SETs. In
com a1 = (mux-m1)^2
com a2 = 2*(mux-m1)*((sigmaT1str)^(-1)*sigmaTx1str)*i1str
com a3 = 2*(mux-m1)*((sigmaT2str)^(-1)*sigmaTx2str)*i1strstr
com a4 = -((sigmaT1str)^(-2)*(sigmaTx1str^2)*i2str+(sigmaT2str)^(-2)*(sigmaTx2str^2)*i2strstr)
set a5 = -(d1-sigmaT1str^(-2)*(sigmaTx1str^2)*i0str)
set a6 = -(d2-(sigmaT2str^(-2))*(sigmaTx2str^2))*i0strstr
set v1 = c*(a1+a2+a3+a4+a5+a6)
those first four are all time-varying expressions, and so should be SET not COM. Similarly with the other batches of calculations.
Posted: Tue Nov 12, 2013 2:07 pm
by rbelhach95
Thanks a lot Tom for your feedback, actually I was doing that at first but it gives me unassigned, just the syntax was incorrect, added more spacing, but I I still get unassigned at graph instruction of m1, v1, etc.., I have added (tem1=e), (tem2=d1), (temp3=d2) at each set instruction for m1, v1,..., which gives no error, but I don't get any graphs displaying. Also I don't understand why rho1 shows zero observations while rho2 shows 423 which is the correct number. your feedback is highly appreciated.
Thank you
Rachid
Posted: Tue Nov 12, 2013 2:19 pm
You have a typo setting up alpha10:
aplha10=0.204003
Posted: Tue Nov 12, 2013 2:45 pm
by rbelhach95
Thanks a lot Tom, I don't know why I am getting sometimes one graph, sometimes none, I attached again the cleaned up code. Thank you so much
Rachid
Posted: Tue Nov 12, 2013 3:11 pm
Use .5 rather 1/2 in your calculations. The latter is an integer divide, and is = 0.
Posted: Tue Nov 12, 2013 3:26 pm
by rbelhach95
Thanks a lot Tom. I am not getting all the graphs like it supposed to on one page, I get the graphs of m1 and v1 but not beta1 and theta1, I don't know why, and I would like to have them on one page, please advise. Thank you
Rachid
Posted: Tue Nov 12, 2013 3:42 pm
What you have should produce a 2 x 2 matrix of graphs as soon as you get the calculations fixed. I don't see how you could get anything else.
Posted: Tue Nov 12, 2013 3:47 pm
by rbelhach95
Thanks a lot Tom, I would work on it again tomorrow and hopefully get it fixed, words cannot express really how much I appreciate your continuous support. Thank you again
Rachid
Posted: Mon Nov 25, 2013 6:38 am
by rbelhach95
Hope my email finds you well. I have attached two codes and the data file, one code is estimating the parameters I would need to graph my conditional moments using these estimates. It appears that convergence is good, however, the output for most graphs is fine with the exception of rho1 and rho2 which are the two correlation functions and therefore by construction should be between -1 and 1, but their graphs show otherwise, I scrutinized the estimation code very much, but I still don't see why I get this contradiction, could it be because the maximum I get is only local max. but logically speaking, it shouldn't, if you could look at my likelihood function and see if I need to add {} to my error function e please help. Thanks so much
Rachid
Posted: Mon Nov 25, 2013 8:28 am
I don't see why you think rho1 and rho2 are correlations by construction---the numerator seems to have very little to do with the two standard deviations in the denominator.
Posted: Mon Nov 25, 2013 9:33 am
by rbelhach95
Thanks Tom for your feedback. rho1=sigmaTx1/(sigmax1*sigmaTau1) by definition of correlation, If I understand your reply correctly, when you say the numerator and the denominator of rho1 e.g have a little in common, do you mean that the leverage effect gama31 is not related to leverage effects gama11 and gama21 for sigmax1 and sigmaTu1 , please also note that the covariance matrix is positive definite, kindly elaborate further on your earlier email. Thanks a lot
Rachid
Posted: Mon Nov 25, 2013 10:05 am
I'm saying that sigmaTX1 doesn't look like it's the covariance of the two terms whose variances are in the denominator---there are terms that don't match.
Posted: Mon Nov 25, 2013 11:51 am
by rbelhach95
Thanks Tom. could you tell me e.g one term in the covariance that doesn't match. Maybe if I redefine s1 for example as,
s1 = beta10*lambda10+beta11*lambda11*(e{1}-gama11)*(e{1}-gama21)+beta12*lambda12*temp6{1}+(alpha11*alpha31)*f1{1}^2+(alpha12*alpha32)*f2{1}^2,
will s1 be matching now d1 and k1? Thank you
Rachid
